Old 07-19-2020, 11:12 AM #16
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Brillo,
Thanks for the reply.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 11:50 AM #17
19963.4lsr5 19963.4lsr5 is online now
Originally Posted by pluton View Post
If possible, could you tell us the part # or description of the Super Bright product you used? I ask because awhile back, I installed their brightest LED bulbs in the back up lights, and while they are brighter than stock, they are not bright enough to see anything more than about 5 or 6 feet behind the vehicle through the tinted glass.
I do not have the exact bulb I bought. I got it from the thread that talked about the dash led bulbs. I used his link.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 07-19-2020, 01:17 PM #18
It was StreetCreeper that I got the info from.
Old 07-19-2020, 10:50 PM #19
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Thanks!
pluton is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 10:02 PM #20
Fountainhead's Avatar
Fountainhead Fountainhead is offline
Fountainhead is on a distinguished road
Reverse lights, why relay...
Setting up auxiliary reverse lights, I keep seeing a relay is required. If the trailer connection allows for reverse lights on any trailer, isn't the system already configured for trailer light. If so and adding LED aux light why a relay if not towing and connect to that circuit?
2015 TE w/KDSS, Gray. And, I understand. Ergo, Toyota.
Fountainhead is offline   Reply With QuoteReply With Quote
Old 09-27-2023, 04:10 PM #21
Is your trailer connector correctly wired for a trailer reverse connection? The standard plug is just a 4-flat without that wire. Also, that wire is normally used for reverse lockout on surge brakes, not lights, so it doesn't have a high current requirement and often (maybe always) won't have any extra relay in place.
Check the power requirements of the lights you are going to use - you might just be able to tap your existing reverse wires.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
back , include , relay , thought , thread
Auxiliary fuse box in back kolelt 3rd gen T4Rs 20 06-29-2016 12:45 AM
Auxiliary Lights Wiring Help KimIsAGuy 3rd gen T4Rs 17 09-05-2014 12:15 PM
Question on Hella auxiliary light wiring Phx994Runner 3rd gen T4Rs 9 06-03-2012 11:21 PM
Auxiliary back-up light installation on '03 djw717 4th Gen T4Rs 4 06-20-2008 07:04 AM
Auxiliary Lights 4Run97 4th Gen T4Rs 4 01-01-2007 12:17 PM
