Old 07-17-2020, 12:45 PM #1
Kbuch1's Avatar
Kbuch1 Kbuch1 is offline
Real Name: Kevin
Kbuch1 is on a distinguished road
Kbuch1's Avatar
Real Name: Kevin
Help with no brakes and locked auto shifter
I have searched and read most all available threads dealing with the locked transmission and lack of brake lights.
Have checked the fuse, good.
Swapped the relay, no difference.
Removed the brake light switch, and it test as good. (The switch has a closed and open circuit that changed when the switch is closed/opened). Is there another way to test it other than continuity? Both circuits check out. Can this be the case and the switch still be bad?
No apparent wiring issues visible.
Still unable to get brakes to work, or shift without using the override.
Any other things I am missing?
Everything was fine until last night.
2000 SR5 4WD 3.4.
Any help or suggestions is greatly appreciated.
Anyone have a wiring diagram for this circuit? Please send pdf of if you can, and I can start testing it out.
Anyone in St. Louis area who has addressed this problem in the past?
Thank you.
Kevin Buchanan
Kbuch1 is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 10:07 PM #2
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Did you jump the terminals in the brake light switch connector to see if the brake lights turned on?
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 10:29 PM #3
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
A little trick I learned from the tow truck driver who towed me when my T4R broke down on the Hwy. My shift stick (auto tranny) was stuck in park and I could not get it out of park.
It took him 5 seconds to unlock it. Seriously. I asked him to please show me exactly what he did. There is a tiny hole to the right of the shifter. He had a very small flat head screw driver and he pushed it into that hole, pressed down, and easily moved the shifter to neutral. Presto ! Just like magic.
Just something to keep in the back of your head if it ever happens again.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-18-2020, 08:14 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes I think all Toyotas have that manual override next to the shifter. You push it and it will let you shift to whatever position you want even without power. It does have a little cover over it.
Old 07-18-2020, 06:25 PM #5
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Could be your NSS.
If that’s bad; it wouldn’t let the truck shift/start.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
brake , brakes , good , locked , wiring
Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement mtbtim 3rd gen T4Rs 17 09-14-2022 08:23 PM
Shifter Locked in Park TOPDECK 5th gen T4Rs 34 08-25-2021 04:28 PM
J-Shift Transfer Case Locked in 4WD (Shifter feels normal) jeremyc74 3rd gen T4Rs 13 02-24-2016 01:32 PM
brakes locked up- help dwmac64 Classic T4Rs 7 04-04-2011 04:15 PM
Locked Shifter on 2003 harleridr 4th Gen T4Rs 6 09-28-2010 01:32 AM
