Old 07-18-2020, 09:23 AM #1
rockdaddy80 rockdaddy80 is offline
rockdaddy80 is on a distinguished road
Engine heating up w/ new radiator, coolant good.
My 1997 Limited V6 gave me the pink milkshake last summer which I caught immediately and replaced radiator and all fluids. Put a new Carquest radiator in with standard Penzoil coolant at that time 12k ago. All has been fine the past 12 months, truck always has and still runs normal operating temp which is a needle width below halfway on the temp gauge. Twice now at idle sitting still for more than 5 minutes the temp gauge creeps up and will go to red unless I cut engine off or start moving. If I start moving it dives back to normal quick. I realize this has been in air temps of 85-90 degrees, parked on blacktop, but still doesn't seem right. The only mod I have done is the rear seat heater core bypass, which I did 4 months ago and was done properly. My 2000 SR5 V6 never did this on a 14 year old radiator. Any advice appreciated!
2000 T4R SR5 V6 4WD - sold @ 198k
2004 T4R Sport Edition V6 4WD - sold @ 175k
1997 T4R Limited V6 4WD - daily driver @ 267k
rockdaddy80 is offline   Reply With QuoteReply With Quote
Old 07-18-2020, 10:13 AM #2
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
So it’s overheating at idle?
Obviously check your coolant levels, but this is classic fan clutch stuff. Replace the fan clutch and call it a day.
aontkos is offline   Reply With QuoteReply With Quote
Old 07-18-2020, 10:16 AM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
You need a new fan clutch.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-18-2020, 10:27 AM #4
19963.4lsr5 19963.4lsr5 is online now
Yep clutch fan time.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 07-18-2020, 04:11 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
When you changed out the coolant from the milkshake, was there any residual oil left in the coolant system? It could also be causing issues if there's some still left. It will be easy to spot, it will be in your overflow reservoir as well as on the top of the radiator under the cap before you start it. A coolant flush product might help.
Also agree on the fan clutch not engaging like it should.
326WHP 347TQ
Old 07-18-2020, 04:17 PM #6
Saturns have a oil in coolant issue and there is a specific way to remove the oil. It does effect the heat transfer according to Saturn.
Old 07-18-2020, 11:08 PM #7
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Check your thermostat first. Could be gunked from the milkshake.
Old 07-19-2020, 10:59 AM #8
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Well the fan clutch is easy enough to see. Pop the hood and see if the fans spinning at idle and does is spool up when you rev the engine.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
ago , engine , gauge , radiator , temp
Weird coolant heating issues but not overheating? JWaldz 3rd gen T4Rs 41 06-08-2020 07:55 PM
Lower radiator hose isn't heating up giro Classic T4Rs 7 07-31-2018 05:42 PM
FS: NEW 3rd gen 4Runner Toyota Radiator, Radiator Cap, Coolant - SF Bay Area, CA - $ TxnBluDvl For Sale: T4R Items 2 04-08-2017 03:23 PM
The curious case of the over-heating radiator — that doesn't over-heat StreetCreeper 3rd gen T4Rs 10 06-26-2015 12:11 PM
Engine heating up with a/c on azhawk22 Classic T4Rs 19 08-25-2011 11:19 PM
