Old 09-08-2020, 08:29 PM #16
ambush ambush is offline
ambush will become famous soon enough
Originally Posted by DAWG NATION View Post
Did that ^ sort out the vibrations for you?
Also OP did you find a solution?
Sorry for late reply.
Well no. It is still there. I literally did the inner tie rods and LCAs on both sides.
same. I will change the bushings on the sway bar end links (they are cracked up pretty bad). I did an alignment of course after replacing the inner tie rods. Aftermarket ones had my steering wheel way off!!
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 11:50 PM #17
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Probably not the sway bar bushings, take your sway bar off for a day and see.. just drive careful if you do..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 12:27 AM #18
HiHoStevo HiHoStevo is offline
HiHoStevo is on a distinguished road
I am looking forward to your solution... I purchased a non-lifted 1998 with 98,000 miles on it... it has aftermarket wheels and Pathfinder tires and I have had them to 5 different shops for balancing, but still have vibrations at highway speeds.
I had a mechanic look the car over when I bought it, but perhaps I need him to do a deeper search in the suspension parts. Right after purchase the Toyota dealer informed me of a recall that was about 12+ years old that the previous owner never did... replaced all of the shocks for free.
There are only Two Theories on how to Successfully argue with a female..., unfortunately neither one Works!
HiHoStevo is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 02:58 AM #19
Wikano's Avatar
Wikano Wikano is offline
Wikano is on a distinguished road
Wikano's Avatar
Bigger tires and 231mm tundra brakes blew through my 20 year old oem LCA bushing and trashed new aftermarket LC Arms/bushings within a year. You'll feel it in the steering wheel and when doing any hard braking if it is your LCA bushings. This can often be mistaken for OTR failure or alignment problems. I would go for Whiteline Poly bushings in our OEM Lower Control Arms.... believe me aftermarket LCAs can be good for a little while but they will mess up your LBJ and possibly tie rods/steering rack by transferring braking force to them (causing your steering vibes/pull). You will need a 12 ton press, bottle jack, and a propane torch but it's not so bad of a job once you learn a few tricks.
98 4runner, 5speed, 2.7L 3rz, 370,000 miles, 2x4, OEM Elocker, 4.30 gears, ToyTec Ajustable Coilovers wit 500lb spring and lots of other goodies.
Wikano is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 03:51 PM #20
ir0nma1den ir0nma1den is offline
ir0nma1den is on a distinguished road
Dropped it off at a mechanic and was told the vibrations and noise was from the rear wheel bearings. Quoted $600 to do both. Doesn't seem like a job I can really tackle without the right tools and a garage. I think I might do it, thoughts?
ir0nma1den is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 04:28 PM #21
T4topher's Avatar
T4topher's Avatar
Gunna be hard with out a garage.. but for the cost of the shop doing it you could basically buy the tools and the parts for the same amount or less. If you haven’t watched Timmy the toolmans video on it already that’s a good place to start.
Old 09-29-2020, 12:14 AM #22
Mushroom_Toy Mushroom_Toy is offline
Mushroom_Toy is on a distinguished road
I still feel like the tires have a little to do with it, especially if you know one of the tires already has a bulge. Age, wear and brand have a lot to play into it. It does happen Im sure, but Ive never had a wheel bearing that made noise in a certain speed range but not at slow to medium or high speed as well. And generally both wouldnt be bad at the same time unless the issue stemmed form the axle seals going bad first, but you could tell that if you pulled rear abs wheel sensors and checked them for gear lube on the sensor and in the housing.
Mushroom_Toy is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 10:38 AM #23
texadelphia texadelphia is offline
texadelphia will become famous soon enough
I can imagine the noise coming from wheel bearings but I'm skeptical of vibration. I'm also having vibration issues around 60-70 mph and just replaced wheel bearings last week and it hasn't gone away. I think it's either the 10 year old tires or something in the front end. Maybe LBJs.
That said, if it is wheel bearings, I pulled my axles myself, bought replacement parts, and took them to an automotive machine shop to have everything removed and pressed on. It basically cost me $60 per axle plus parts. I bought my parts from a dealership so it was like $340 in parts but if you're willing to wait you can find the stuff cheaper online and save $100. I consider myself an average mechanic at best and the job wasn't too bad with normal hand tools. Hardest part was getting the damn return spring on the brakes. Haha. I relied heavily on mtbtim's videos for the axle rebuild and brake job.
If you do use OEM axle seals be sure you have the shop flip the inner retainers like mtbtim recommends. If I wouldn't have had them flipped, the inner seal lip would have been dangerously close to the bevel on the retainer.
EDIT: I replaced my bearings because I found that the seals were leaking, not to try to fix vibrations.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 12:18 PM #24
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
Also, check your rear LCA/UCA bushings.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 12:36 PM #25
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Reading through all the replies many of us have had issues with vibrations for one reason or another.
These trucks are now 20+ years old with lots of miles so there are many possibilities as bushings wear out and crack, suspension/steering components wear out and alignments change.
Best is to start with the basics which many times are the lowest cost possibilities and go from there.
Careful inspection of the tires/wheels followed by a quality Road Force wheel balancing of all 4 wheels would be my starting place.
Once that’s done if still a problem if your not comfortable doing yourself find a quality shop to inspect your suspension bushings and steering components.
Odds are you’ll find the problem.
I’d do the above before replacing the rear axle bearings unless you have leaky seals as than go for it as the repair is needed anyway.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 02:14 PM #26
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
^ I would definitely start with this ^.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 03:57 PM #27
plcfcng's Avatar
plcfcng plcfcng is online now
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Something to try is put it up on jack stands pointing in a safe direction and bring it up to speed and see if you can isolate the vibration. If you are in two wheel drive and it goes a way then you can look at the front eg driveline. If the vibration happens in two wheel drive then look to tires driveline.
plcfcng is online now   Reply With QuoteReply With Quote
Old 09-29-2020, 09:33 PM #28
This makes sense but man, it'd be scary getting up to 60 mph on jackstands!
Sent from my moto x4 using Tapatalk
Old 09-30-2020, 01:50 AM #29
T4topher's Avatar
T4topher's Avatar
Exactly what I was thinking, 60-70 mph on jack stands sounds super sketch lol. Like others I’d highly recommend starting with a road force tire balance, pretty sure these trucks are somewhat sensitive to tires that are out of balance. Make sure they have a road force machine before you go, I don’t think all shops have it.
Old 09-30-2020, 02:27 AM #30
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
Properly placed jack stands on the axle tubes will allow you to safely run up engine and drive train to the desired speeds. There are many variables driving down roads that include slowing for another driver, wash board road and others while trying to evaluate where the vibration is coming from makes it much more difficult.
mph , play , rear , u-joint , vibrations
New Member, Help!; 70mph and that's it. UberWagen Classic T4Rs 7 04-21-2014 08:49 PM
what is your RPM at 70mph? Insight Mike 3rd gen T4Rs 21 01-14-2013 11:06 AM
Vibrations at 70mph mtravis8 3rd gen T4Rs 3 07-16-2012 03:42 PM
Lot of shaking at about 70mph 97T4RL 3rd gen T4Rs 19 02-29-2012 02:35 PM
Trouble getting above 70mph changedsoul 3rd gen T4Rs 5 11-18-2011 01:37 AM
