Old 07-19-2020, 09:59 AM #1
Kamikaze6rr Kamikaze6rr is offline
Kamikaze6rr is on a distinguished road
Ghost overheat
My daughter's 1996 sr5 will drive all day no issues. Some days though we get a gurgling sound from the radiator/overflow. When we here this and try to start after coming back car won't start. The entire time the temp gauge shows normal. I have a Zeus obd reader and moved from my 2000 to hers and no rpm or temp showing at all on the gauge.
On start the fan is running fast and then slows as it warms up.
The radiator cap looks like the 2000
Flushed the coolant couple weeks ago. No bubbles in system
Radiator is black top so relatively new but definitely not stock.
First time this happened was reaching the top of Wiseman.
Patience got her started. No problem for 70 mile return trip. Highway and then when we got home let it idle after all that highway driving. No gurgles and started every time after. This is what made me flush the coolant to be safe
Then weeks later, yesterday, she just get her license. Drive to Ultra and then to work. Maybe 30 mins tops driving and when she went to leave work, wouldn't start. Waited a few and started and then came home. She called me and said it did the same like at Wiseman.
What could this be?
Kamikaze6rr is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 10:38 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by Kamikaze6rr View Post
... Some days though we get a gurgling sound from the radiator/overflow. When we here this and try to start after coming back car won't start. ...radiator cap looks like the 2000
...What could this be?
I think the two symptoms are not related but you never know. the dash guage is far from accurate, it won't go to red until the engine coolant is near 300, nog good. Get yourself the $5 version of torque pro, an odb2 blue tooth connector and you'll have accurate engine fluid temps but given its a 96 not so such, so someone on here with a similar model yr will probably chime ine.
If the age of the radiator cap is in question, I would replace with a new one, especially if there is 'gurgling', its cheap protection so just do it soon.
The hard to start after warmed up, driven and parked a little while, could be again could be the fuel pump. The pump has a one way valve, if that valve is failing but again that just a hunch. Could also be fuel injectors leaking after sitting. Experts where are you?
Old 07-19-2020, 11:01 AM #3
Ghost overheat
All 3 4Runners I bought had broken rad caps when I bought them.
When you remove the cap is antifreeze touching the bottom of the cap?
Are you adding coolant to the expansion tank on occasion?
gauge , start , started , temp , time
Hesitation/ overheat 4runnerWiniarski23 3rd gen T4Rs 5 09-05-2018 08:33 PM
Is it possible for to overheat without any issues? dallison 3rd gen T4Rs 28 06-07-2017 04:21 PM
a/t fluid overheat atalarico 3rd gen T4Rs 100 07-10-2016 09:16 PM
Overheat again firebiz16 4th Gen T4Rs 6 12-23-2011 05:41 PM
!!!!!!overheat!!!!!! HiluxSurfBMX 4th Gen T4Rs 26 02-25-2005 09:10 AM
