Old 07-22-2020, 03:29 PM #16
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I like to turn the adjust out until I can *just* get the drum back on. Then crank it forward with a screwdriver from the access hole a few more clicks. You want the drum to drag just a little.
When its adjusted right you should be able to get good tension on the handle after 7-9 clicks like Tim said. Oughtta be able to lock the tires right up with a hard pull.
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 04:45 PM #17
psea17 psea17 is offline
psea17 will become famous soon enough
followed the video to a t. tightened adjuster. drums just barely fit on and then tightened fr behind backing plate. but when I pulled on the ebrake, no clicking. it still comes up pretty high. still think the cable doesn't have to be tightened at center console?
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 05:08 PM #18
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I don't get it, if you're able to pull the handle up pretty high, you should be hearing some clicking.
Old 07-22-2020, 05:13 PM #19
hmm, theoretically, if the cable had too much slack wouldn't that explain it? the ebrake reaches its max distance before it can supply enough tension to make the adjusters "click"?
just thinking out loud.
Manual Transmission
Old 07-22-2020, 09:18 PM #20
There is a procedure to adjust the ebrake in the FSM. It’s important to follow it.
While your drums are off grind off the lip.
Old 07-23-2020, 10:50 AM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The handle itself does the clicking. It doesn't matter if the cable is connected or not the handle should still click when you pull it up. Another thing to check for but wouldn't have anything to do with your not clicking problem is making sure the bell cranks are operating properly.
Old 07-23-2020, 10:55 AM #22
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
There was a thread that pointed out a few differences in the rear brakes between 96-00 & 01-02 that would make adjusting the rear brakes in 01-02 with the parking brake lever not possible. I haven't looked in detail how my rear brakes in my 02 operate but I'm pretty sure when I've tried, it didn't seem to adjust anything. Not a big deal since I use the adjusting wheel but can anyone confirm this?
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 10:57 AM #23
I could have sworn in timmy's video, they were pulling the ebrake with the button depressed so they could demonstrate the rear wheel adjusters 'clicking'. (and not hear the brake handle click.
Manual Transmission
Old 07-23-2020, 11:06 AM #24
You are suppose to remove the bellcrank springs and pull it until it stops. Then adjust the bolt head for an air gap of around 1/32 to 1/16”. (I forget the exact measurement) then reinstall the springs.
Then adjust the cable at the handle if you don’t have the proper klicks.
Have slight drag adjusted on the brake shoes first.
Old 07-23-2020, 11:08 AM #25
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
This is correct, I haven't watched the video but it is valid.
You mentioned that you adjusted the brakes after you put the drums on. Maybe you have them tight enough. The self adjuster star wheel mechanism will only work of the shoes are a little loose. If you have them tight enough (or too tight) you won't hear anything from the back. Once things are adjusted up properly the clicking stops.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 11:11 AM #26
brake shoes slight drag - complete
bell crank bolt clearance - check. think tim said .4-.8mm
cable handle - need to do. that's what I was wondering
thanks
Manual Transmission
Old 07-23-2020, 11:22 AM #27
Real Name: Patrick
Real Name: Patrick
The 7-9 clicks is for the parking brake handle. If your rear brakes are properly adjusted then it won't click at the adjusters when you pull the parking brake handle.
Old 07-23-2020, 11:29 AM #28
bobsmith66 bobsmith66 is offline
bobsmith66 is on a distinguished road
confirmed!
2002 here. the auto adjuster is different than shown in tim's vid.
i also found the parking brake did not auto adjust the star wheel and i had to do it manually. warning : the manual adjuster works the opposite of what appears in tim's video.
after 15 years i bought the parts to convert to the 96-00 version. works like a champ now!
bobsmith66 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 11:56 AM #29
yes, I realize that. thx
Manual Transmission
Old 07-23-2020, 12:10 PM #30
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
02 owner here....
Replaced my brake shoes when replaced rear axle seals/bearings, etc a couple weeks ago.
I adjusted the brake shoes manually by turning the star adjuster and it tightened up my emergency brakes perfectly. The e-brake lever used to have little resistance when pulling up and did little to hold the vehicle on any kind of an incline.
I also bled my brake system using a Motive power bleeder working from furthest away to closest.
My brakes actually work really well now and the pedal feels just like you would expect it to.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
brake , drum , pad , pads , room
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Drum Brake Help rcrick 3rd gen T4Rs 42 01-03-2015 01:05 PM
What is this on my brake drum? BradB 3rd gen T4Rs 4 07-31-2011 11:23 PM
correct install of drum brake adjusters? Blueman2 3rd gen T4Rs 13 07-12-2011 12:08 PM
85 Brake drum nofe3o2 Classic T4Rs 12 08-31-2010 10:55 PM
