Old 07-21-2020, 08:51 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Can't Install Brake Drum
Ok, I'm completely stumped. Usually, people have problems removing the drums. For some reason, I can't put the passenger side drum back on. The brake pads are extending too far out.
Oddly, the brake pads don't look centered related to the backing plate. The pad closest to the front of the truck appears to be much closer to the edge and perhaps rotated a little lower vs the aft brake pad.
I have screwed the brake adjustment screw all the way in an attempt to make room between the brake pad and drum, but no luck.
Any ideas?
Can't Install Brake Drum-img_20200721_205510-jpg  Can't Install Brake Drum-img_20200721_205533-jpg  Can't Install Brake Drum-img_20200721_205548-jpg
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 09:07 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Any ideas?
Give us some pictures. Did you watch Timmy the Toolmans rear brake video? Might have some pointers or at least something to compare to.
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 10:04 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yeah, and the video just so happens to feature @JZiggy too.
Old 07-21-2020, 11:59 PM #4
Hey Timmy, funny that you would chime in. I was actually taking the axle out to check that the bearing seal was seated properly. I noticed some grease/oil on my inner tire. I had used your video last fall to do the job (GREAT video BTW). I also checked that the seal was riding on the retainer ring. It was exactly 5mm in which is just about the middle. Did another grease test just to make sure. I made sure I reversed the ring and I exchanged the inner ring with the outer ring. Everything looked good! Then went to put the drum on and well...here I am. I started watching your video above earlier today. But got side tracked.
Thanks for everyone chiming in!
Manual Transmission
Old 07-22-2020, 12:06 AM #5
Pics added!
Manual Transmission
Old 07-22-2020, 12:25 AM #6
JZiggy's Avatar
JZiggy's Avatar
Pics added!
One side of the wheel cylinder (right side) looks way extended. Maybe you can try to center the shoes more to help the drum fit? I often put a carpenter clamp like a quick-grip at the center of the two shoes and squeeze them together to get things to center up.
Old 07-22-2020, 12:49 AM #7
Thanks JZiggy.
I'm watching the end of Timmy's brake video right now (with you adjusting the pads). I see what you're talking about. Is that normal to have one of the cylinder's sticking out so far? I'm wondering if it's shot. How would I determine if it's no good?
I'm guessing i should make sure there isn't too much brake fluid in the reservoir?
Manual Transmission
Old 07-22-2020, 01:09 AM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Looking at your pics, I think your issue is you don't have the star wheel adjuster seated properly in the left shoe. The star adjuster has a slot in it that slides into another slot on the shoe. If it's not lined up properly, the shoes will stick out further. Make sure that star adjuster is lined up right and I bet that solves your issue of getting the drum on.
Old 07-22-2020, 07:33 AM #9
Thanks Timmy. I'll take a look. Hopefully it's something as easy as that.
Manual Transmission
Old 07-22-2020, 08:03 AM #10
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
This is the first thing I noticed. If the piston isn't centered in the wheel cylinder I think it's likely that you'll run into problems. That means one of your shoes is extended further than it should be.
I'm sure the video got you on the right track.
aontkos is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 10:30 AM #11
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I’m with these guys.......that right side piston in the wheel cylinder is not positioned properly.
May have to relieve pressure by cracking bleeder to reposition.
I’m thinking you disconnected the wheel cylinder when you pulled the axle to confirm no leaky seal?
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:22 PM #12
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I ran into the same issue a couple years ago when I was changing my rear brake shoes. Had everything done and couldn't get my drum back on. Messed around with the adjusting wheel then noticed my wheel cylinder looked weird. As I was trying to center/compress my wheel cylinder so it looked more normal I noticed a small amount of brake fluid leaking out of the rubber boot. My guess is at some point in removing/installing parts I damaged the wheel cylinder because it wasn't leaking before. All is good now. Double check that it's not leaking before you put everything back together.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:28 PM #13
They will push out of the wheel cylinder if you remove the shoes. They make a spring clamp to keep the pistons inside the wheel cylinder during maintenance.
Old 07-22-2020, 02:47 PM #14
HAPPY to report the drum is back on! I had to compress the right side piston. luckily, all it took was a screwdriver inserted from the top to pry the piston back into its housing.
one other question. I saw the video's technique for using the e-brake to get the self-adjustet to the right position. prior to this, I had noticed I had to pull my ebrake all the way up to keep my truck from rolling. should I adjust the cable in the center console before resetting the auto adjuster or would u do the auto adjuster first?
I FRIGGIN LOVE THE 4RUNNER COMMUNITY. I literally fear the idea of getting anothet truck....someday. 241,000 and still plugging away. just wish I had more power for hauling my black series dominator trailer up big hills. (aware of supercharger; keep contemplating)
Manual Transmission
Old 07-22-2020, 03:07 PM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You shouldn't have to adjust the cable at the console. Just keep pulling the e-brake over and over again until you get 7-9 clicks from the handle.
brake , drum , pad , pads , room
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Drum Brake Help rcrick 3rd gen T4Rs 42 01-03-2015 01:05 PM
What is this on my brake drum? BradB 3rd gen T4Rs 4 07-31-2011 11:23 PM
correct install of drum brake adjusters? Blueman2 3rd gen T4Rs 13 07-12-2011 12:08 PM
85 Brake drum nofe3o2 Classic T4Rs 12 08-31-2010 10:55 PM
