Old 07-23-2020, 12:28 PM #31
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Correct but did you try adjusting the rear brakes using your parking brake lever (pulling it up repeatedly)? It doesn't seem to do any adjusting the way it does for 96-00.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 01:31 PM #32
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I did not as once I installed and adjusted the new shoes there was no need to go further as the parking brake lever was working perfectly as in pull it up and it locks the brakes nicely after 5 or 6 clicks.
It was not working properly before I replaced and adjusted the shoes.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 11:30 AM #33
psea17 psea17 is offline
psea17 will become famous soon enough
Wanted to than everyone for the help. My ebrake cable was quite loose. Also just replaced the brake booster. Need to do a little reading about that now. But thanks again!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 01:16 PM #34
phattyduck phattyduck is online now
I was in a similar situation to psea17 when I got my 4Runner. My adjusters even worked, but still had too much travel at the e-brake handle. The auto adjuster 'click' is very quiet if you up in the driver's seat working the handle.
If everything is good in the back, you may still have some slack on the cable to take out using the adjuster inside under the handle. Just don't use that adjustment to fudge problems in the back. There should be just a small amount of cable slack so that you get max 'pull' on the bellcranks, etc. at the drums.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
brake , drum , pad , pads , room
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Drum Brake Help rcrick 3rd gen T4Rs 42 01-03-2015 01:05 PM
What is this on my brake drum? BradB 3rd gen T4Rs 4 07-31-2011 11:23 PM
correct install of drum brake adjusters? Blueman2 3rd gen T4Rs 13 07-12-2011 12:08 PM
85 Brake drum nofe3o2 Classic T4Rs 12 08-31-2010 10:55 PM
