Old 07-22-2020, 12:35 PM #1
jeech jeech is offline
jeech is on a distinguished road
Rear Axle Seal Leak Caused by Fixing the Other Side?
I recently had a shop fix a rear axle seal that was leaking on the passenger side. Now my driver side is leaking. Is it likely that the work they did caused the driver side to begin leaking? I probably should have done both at the same time, but was of the opinion that if it ain't broke, don't fix it, since I didn't see any evidence that both should be done at the same time.
jeech is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:42 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I’d say no. Unless they pulled the other side for reference.
It makes sense that if one seal has aged out the other is not far behind it.
Make sure diff breather is working correctly.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:46 PM #3
silverbullet4 silverbullet4 is offline
silverbullet4 is on a distinguished road
The other one was probably bound to go soon.
silverbullet4 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 12:47 PM #4
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
This. It's probably pure coincidence and timing that the other side failed after getting the one side done. Those parts were wearing at the same rate, simultaneously
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 01:06 PM #5
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
Agreed, they tend to fail relatively close to one another (mine did within 12 mos).
But I second the diff breather suggestion, it's cheap and easy to replace (and relocate if you haven't and dabble in water crossings) and will ensure it's not causing excess pressure build-up within the axle itself (which would, in turn, cause seals to fail).
eleven14 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 01:08 PM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I too suspect diff breather and an old seal.
Possible, diff breather was plugged yet excess pressure blowing out the seal that was already shot. YOu fixed that, pressure had no place to go but the other older weak seal
Old 07-23-2020, 07:33 PM #7
Thanks guys. I'll check the diff breather this evening.
Old 07-24-2020, 09:49 AM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Good thing to check. I try to replace everything in Pairs if I can. If I need 1 CV axle, I'll go ahead and replace the other and keep the original as a spare. If I need a headlight bulb, I just replace both and throw the extra in the glove box. I have found that when one side goes, the other side is not far behind, so I just started to get ahead of it and do both sides.
It's not unusual for the Axle seal to go at this mileage, and if 1 is bad, it's likely the other was close to on it's way out.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 07:59 PM #9
wecoyote97 wecoyote97 is offline
wecoyote97 is on a distinguished road
did you do the bearing and races in the rear axle when you did your seals.
seal leaking on a yota dif are a early sign your wheel bearings are starting to fail. replace the races bearings and seals and the problem will go away. but also make sure the diff breather is working as well.
i did mine on my runner 4 years ago at 260km\
wecoyote97 is offline   Reply With QuoteReply With Quote
axle , driver , leaking , side , time
Rear axle seal leak dereky 4th Gen T4Rs 28 12-01-2021 10:08 PM
Rear axle seal leak ARunner 4th Gen T4Rs 2 05-27-2015 08:33 PM
So...rear axle seal leak on driver side! (07 V8) thenuka 4th Gen T4Rs 3 04-16-2015 06:51 PM
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Help with Rear axle Seal leak!! fightman80 3rd gen T4Rs 20 05-03-2013 06:40 AM
