Old 07-22-2020, 01:50 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Looking for a good repairman in San Antonio or Austin
I’m looking for a good repairman to diagnose and service the transmission of my 4Runner. It’s running fine. But it’s never been serviced. All the stealerships only do tranny flushes. I would like to find someone who does a drain and fill. Thanks.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 02:15 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Don’t want to hit up Faye and her chickens? She knows how to wrench, and would let her turn them all day on my 4runner.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 02:40 PM #3
spartacus's Avatar
spartacus's Avatar
You can just drain the atf pan fluid and refill it with the same amount a few times and it will stay fresh. More recently I've taken the advice of a few on here and drain and refill atf, when I do every other oil change . I consider it money well spent.
I have done drain and fill with my seven year old as an helper It is easy to do a drain and fill your self @mtbtim has some good videos.
https://www.google.com/url?sa=t&sour..._rG1ipFY8TlJ8u
Old 07-22-2020, 04:13 PM #4
Satter's Avatar
Satter's Avatar
She’s no longer taking appointments.
Old 07-22-2020, 05:24 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
In Austin, if you like to bring your own fluids/parts (might want to consider the filter too if not serviced in a Long time) this guy will do the labor very well: Mohammad at Auto 7 Tech (3601 W Parmer Ln, Austin, TX 78727), (512) 873-9354.
He does good, honest work, fixed first time.
Another gent I've used for nearly 30 yrs, very trustworthy, won't do work that isn't needed, is Paul at Rational Automotive, (12129 Roxie Dr, Austin, TX 78729), (512) 345-5266; now this gent is like most mechanics, he supplies all parts/materials.
They both charge about the same, sometimes Mohammad is less expensive. Luck.
Old 07-22-2020, 09:46 PM #6
Thepedigree13 Thepedigree13 is offline
Thepedigree13 is on a distinguished road
I like Summit Automotive in San Antonio. The owner Chad is reasonable, always quick service, and I've never had a bad experience there. It's on Bandera Road, NW side of town.
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
Thepedigree13 is offline   Reply With QuoteReply With Quote
Old 07-22-2020, 10:23 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Dude, if you have the space to work on your rig and some basic tools, do yourself a favor and take on the challenge and turn some wrenches. Doing a drain and refill of the trans pan is as simple as it gets. You unscrew a drain plug and drain the fluid into a container. You put the drain plug back in with a new crush washer and you refill the system. If you drain the fluid into a container with graduated level marks, you'll have a good idea exactly how much you drained out. Usually around 4 - 4.5 quarts.
@spartacus gave you some good advice. Do a drain and refill of the pan and maybe time it with your next engine oil change. At your next engine oil change, do another drain and refill of the trans pan. Then do it one more time at your next engine oil change and the fluid will be in pretty damn good shape.
Doing the fluid renewal gradually is safer for a trans with an unknown service record.
From then on, do an ATF drain and refill every other engine oil change or somewhere around every 10k miles. I've done this with both of my 3rd Gens and a Blackstone oil analysis confirmed my ATF was in great shape.
Old 07-22-2020, 11:11 PM #8
Wraytex Wraytex is offline
Wraytex is on a distinguished road
Check into Kosub Transmission Service, they do excellent work and are pretty reasonable. I've had my 07 Ram in there and would definitely go back.
Wraytex is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 11:08 AM #9
Satter's Avatar
Satter's Avatar
Thanks, chief. I’ll look into those.
good , it’s , repairman , stealerships , tranny
2016 4Runner Trail Edition Austin/San Antonio - $35k kjohnson129 For Sale: Vehicles 1 08-14-2019 09:27 AM
San Antonio/Austin recommended dealer? ryn996 5th gen T4Rs 36 01-07-2015 03:08 PM
Good day to all from San Antonio Texas. JoshTaylor New Members 7 07-02-2012 06:31 PM
Good Mechanic in San Antonio? faber Classic T4Rs 1 11-27-2010 10:32 AM
Leather & Vinyl repairman here BigBlueGen2 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-19-2005 11:28 PM
