Old 07-24-2020, 09:10 AM #1
jack.hanks02 jack.hanks02 is offline
jack.hanks02 is on a distinguished road
Lower ball joint bolts stuck in knuckle
I managed to get the ball joints out, but like so many others with rust, 3 of the bolts remain in the knuckle.
What are the proven methods to get these out? My plan right now is vice grips, pb blaster, and heat.
Sent from my PH-1 using Tapatalk
jack.hanks02 is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 09:25 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Heat and an air hammer if you have one
Old 07-24-2020, 09:32 AM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I have had great luck with a BUTANE torch on these smaller type bolts. Just remove the knuckle and put it in a vise so you don't end up torching the CV-Axle or setting the bearing grease on fire. I have seen BOTH done, and let me tell you CV axle grease burns black and nasty.
I would heat the bolts themselves until the are red hot with the point of the butane torch. Then put cold water to "shock" the metal. Hit the knuckle with a ball peen hammer a few times on the knuckle around the bolt. DON"T Attack them with vise grips. You should be able to bust most of the rust loose with a few sessions of PB blaster, then heat, then hammering, then cold water. Rinse and repeat and you can probably turn them with a pair of pliers.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 09:50 AM #4
OpenYota's Avatar
OpenYota OpenYota is offline
OpenYota is on a distinguished road
OpenYota's Avatar
I wish you all the best on your future endeavors...
I recently broke a NEW bolt replacing my ball joints the other day with my torque wrench.
I have tried PBblaster and vice grips on it to no avail.
A mobile mechanic is coming out tomorrow to sort out the problem and get the new bolt out of the knuckle, when he finishes the job I'll ask him what he did to remove it and will let you know if you're still having the issue.
OpenYota is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 10:17 AM #5
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Get some MAP gas, and heat bolts up until they're red. Then you should be able to unscrew them with a pair of vise grips. If that doesn't work heat them up again, and this time hold a candle to the threads where the thread go into the spindle. The heat will draw the wax in, and will help to loosen the bolt from the rust.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 12:47 PM #6
Mike
I got a map gas torch, but the flame is way too big. Risk burning the cv boot. Trying to avoid taking the knuckle off. Mostly because if I do I'll probably find other shit that needs replaced Lower ball joint bolts stuck in knuckle.
Thinking I will try my little butane torch and go buy a bigger one if needed.
Good to know about the candle.
Old 07-24-2020, 12:48 PM #7
Damn, this is what I am hoping to avoid! Did you over torque or should I adjust my specs?
Interested in your results! And how much he charges.
Old 07-24-2020, 12:49 PM #8
Sounds like a plan. I will try it without removing the knuckle first and go from there. Maybe I will be lucky but highly doubtful Lower ball joint bolts stuck in knuckle
Old 07-24-2020, 02:20 PM #9
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
The only difference between the MAP gas torch & propane torch is the fuel. Flame will be the same size, and map gas will get hotter. Butane really isn't a very effective source for heat when trying to remove a rust bolt. You can put a leather glove between the spindle and cv boot to help not melt the boot.
For the record, you can also heat the lower side of the spindle rather than thread portion that's sticking out. This will also keep the flame away from your cv, and still get the rust bolt plenty hot.
Over torque on these bolts will cause them to snap off.
Mike
Old 07-24-2020, 04:06 PM #10
Mike
Yeah I just got a bernzomatic kit that came with map gas. I just wish I could adjust the flame size coming out.
I was also considering putting something in to block the cv boot. Good call on the leather glove!
I can't find my damn cheap ass butane torch anyway, but if I do I will try it first for curiosity's sake.
Old 07-24-2020, 04:22 PM #11
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
No way that should happen. I'd double check the spec you were using or you need a new torque wrench.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 07:51 PM #12
OpenYota's Avatar
OpenYota's Avatar
I was torqueing to 59ft-lb’s...
it was a brand new Harbor freight torque wrench so I learned my lesson on using those tools.
Going to upgrade it.
Old 07-24-2020, 07:59 PM #13
OpenYota's Avatar
OpenYota's Avatar
Talking
I torqued to spec(59ft-lb) but I think my new Harbor freight torque wrench is crap so I think that was the issue.
I’ll let you know tomorrow afternoon
Old 07-24-2020, 09:16 PM #14
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
The '02 manual, at least, shows 37 ft-lb.
Lower ball joint bolts stuck in knuckle-lbj-jpg
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 07-24-2020, 10:15 PM #15
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I found that discrepancy when I was doing my lower ball joint replacement a few months ago. I have attached the same section out of the 2000 manual. The part numbers for the lower ball joints don't change across the model years for the 3rd gen. When I did mine I went to 59lb-ft, and I didn't feel like I was anywhere near needing to worry about stripping or breaking anything.
Lower ball joint bolts stuck in knuckle-2000-4runner-lbj-png
Skulking is offline   Reply With QuoteReply With Quote
ball , bolts , grips , knuckle , plan
Front lower ball joint attachment and steering knuckle wont align Xhado 5th gen T4Rs 19 04-30-2018 10:32 PM
Lower Ball Joint Replacement Questions, Tacoma Parts, and Securing Bolts. TheFriZ 3rd gen T4Rs 7 06-13-2014 09:26 AM
lower ball joint stuck freshley 3rd gen T4Rs 7 07-24-2012 06:28 PM
