Old 07-25-2020, 06:19 PM #1
bbqlvr bbqlvr is offline
Real Name: M.R.
bbqlvr is on a distinguished road
Real Name: M.R.
Tailgate window and regulator brackets
Hello folks. This post is for experts that have tackled tailgate window/regulator jobs. Searched but could not find what I’m after. Rear window had fallen into tailgate. Took apart tailgate window from regulator and came to find out that rust had gotten the better of the nuts found in the plastic bits found “glued” to the bottom of the the tailgate window. All 6 nuts had managed to “fall out” of their seats within the plastic pieces.
I managed to loosen 3 out of 6 bolt/nut pairs and the other 3 are corroded too badly to separate. I have attached relevant pics.
My question is: Can I source new nuts and reuse the 2 plastic bits “glued” to the bottom of the tailgate window?
The 6 nuts were originally moulded and fixed in the plastic. Should I attempt to use automotive window adhesive to hopefully get the new nuts to seat permanently into the 2 plastic pieces?
Thanks to Josh from this forum group I have a new to me regulator that I plan on swapping over. The original had some parts that were badly corroded to the point of causing the window to fall off the rails and into the tailgate hatch.
Tailgate window and regulator brackets-3291e3bf-e128-4eac-84b8-f595fcf768c1-jpg  Tailgate window and regulator brackets-7ff4358a-89e6-4cfd-9bdb-e8dd9ca8eddc-jpg  Tailgate window and regulator brackets-6e710560-4dcf-4896-a975-7a2467e3e0b3-jpg  Tailgate window and regulator brackets-6fe9e43b-2b25-4496-90be-7bb2186297d1-jpg
2000 LTD, 2nd gen. TRD Supercharger with all supporting mods., upgraded Bilstein suspension, Tundra brake upgrade, Magnaflow SS exhaust, TRD CAI
2016 TE, bone stock
bbqlvr is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 09:59 PM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I would imagine that bolting them to the regulator with nuts and bolts would be possible but not easy, gluing the nuts in place may be the way to go. I have a couple extra rear windows without this problem if you decide to replace.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 09:00 PM #3
Real Name: M.R.
Real Name: M.R.
This post is more for others that end up with similar issue. So I managed to successfully repair the rear window. Originally I thought of replacing the 2 plastic pieces attached to the bottom of the tailgate window. After being quoted what I consider to be *uck You prices ($90 a piece) from the stealership I decided to tackle this on my own. I ended up cleaning out all the rust, etc. out of each of the 6 holes in those 2 plastic pieces. One of the holes became bigger in the process. Not surprising none of the holes maintained their original mold that was intended to properly seat the nuts. As such I ended up using JB Weld to build up the bigger hole. Once that was set I again used JB Weld and seated 4 of the original nuts and 2 replacement nuts (that I sourced from local hardware store). I was happy with the final result and proceeded to put everything together. I applied Fluid Film in hopes that I will never have to encounter this job again. Damn you rust!
Once again thanks to Josh from this group for supplying me with all the parts needed.
2016 TE, bone stock
Old 01-07-2024, 01:04 AM #4
Frankyhollywood Frankyhollywood is offline
Frankyhollywood is on a distinguished road
Hey,
This happened to me just recently, I had been looking for a post about this with these pictures, so Thanks you.
I was curious what size you used for the nuts and bolts ?
Any help would be welcomed,
Thanks
Frankyhollywood is offline   Reply With QuoteReply With Quote
nuts , plastic , regulator , tailgate , window
2004 T4R: Need Tailgate Window Regulator & Rotor dpaskoff90 4th Gen T4Rs 4 06-30-2017 04:06 PM
2005 4runner tailgate Regulator!!! dirtball44663 New Members 0 11-21-2014 09:54 PM
Tailgate Window Regulator Installation sx4runner87 Classic T4Rs 7 01-30-2011 11:06 PM
Passenger Window Off Track? Window Regulator? REO3 4th Gen T4Rs 1 01-05-2011 02:28 PM
Spring on tailgate regulator thorrinn123 Classic T4Rs 12 11-30-2010 01:01 AM
