Old 07-28-2020, 11:10 PM #31
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Originally Posted by Traveler74 View Post
Yes, I will be doing an oil pressure test but I have to wait for Amazon to deliver the test gauge and the new oil pressure sensor. In the meantime I'll do the flush and see what happens.
But, even before that, I must wait for my new alternator to be delivered.
PS; What is YMMV ?
If you see anything below 4.5 psi at idle (oil all warmed up), then I would try the flush but I would think that pulling the pan would get you further ahead to discovering whether a good initial cleaning would be the best course of action.
Any lower motor noise by the way?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 11:31 PM #32
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
These flushes are all fairly aggressive and last resort-ish. No way I’d be doing one before checking my oil pressure with a gauge. Do your proper diagnosis first, the flush may not be needed and may cause harm.
Think of putting on a cast before the x-ray, backwards logic.
You mentioned that the oil pressure light came on AFTER you did an oil change. Cause and effect, I’d be thinking about that. Might be coincidence, might not be.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 02:09 AM #33
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
2 symptoms.
Oil light at idle and oil dark after 20 miles.
Filter is downstream of the sensor, so not likely the issue.
Thinner oil should make for less pressure than thicker oil, so 10w40 isn’t likely the cause.
I’d run cheap filters till your done flushing at least.
You can look in the oil fill cap for sludge. Generally you’d do that before purchase, not after.
I run Marvel for the last 250 - 500 miles before an oil change if I want to clean an engine.
For your case I think I’d pour in a quart of marvel and then run the engine with no load at a high enough rpm to keep the light off. Every once in a while let it idle and see if light comes on. Do this for about 10 minutes. Then let sit overnight and then repeat the run test.
Assuming light still comes on, then drain the oil and pour in 2 gallons of diesel. Let that sit overnight and then drain and replace filter and fill with cheap 10w30 or 5w30 and start it up and check light.
If no light, then dump in a half quart of marvel and run it for 500. Then do an oil change with good oil and filter.
If still a light, then get a pressure gauge, and/or get invasive with the oil pan and oil pump.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 03:09 AM #34
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
LittleCaesar, I am deaf, or nearly so. But my friend assures me that he can't hear any unusual engine noises what-so-ever. No knocking, pinging, thumping, grinding, clicking or tapping. Just the sound of a perfectly running engine. During the trial run , prior to buying, we both were impressed with it's power and smoothness. The truck ran like a scalded cat. Oh, and no dashboard warning lights prior to the oil change.
On it's 2nd day on the road, all hell broke loose. 1st, the car died on the freeway; it was running on battery power alone. The brand new battery had worn down to the point where even the flashers would not work. Luckily for me there was an Auto Zone at the foot of the off ramp. I had Auto Zone recharge the battery and test the alternator. They said, "positively the alternator was bad". During that alternator test was when I first noticed the oil light come on at idle, but NOT when I increased the RPM's. Yes, the oil level was right where it should be.
I can't imagine that the two things are in any way connected. But, I suppose anything is possible.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 03:44 AM #35
I'm sure you are correct. However, I am no ones idea of a mechanic and according to Haynes Repair Manual, the following is necessary before removing the oil pan: remove front stabilizer bar, remove exhaust assembly, remove front crossmember, remove the A/C compressor, remove alternator, remove the crankshaft position sensor from the timing cover, remove the left and right stiffener plates, remove the transmission brace. Only then can the pan be dropped for cleaning the pan and oil pick-up tube.
I appreciate your advise, but doing all of that is WAY over my head.
Old 07-29-2020, 04:09 AM #36
When I replace the alternator, I will double check the RPM's in gear and at idle. The old alternator was not charging the battery.
Your low rpm at idle could be your low oil pressure. My rebuilt engine on a hot 95 degree day after driving 22 city miles home from work had about 8-9psi at idle in park at 750rpm with 5w30.
Old 07-29-2020, 06:37 AM #37
Hmm. Darn good point. I had not thought of that. As soon as I get the new alternator in, that will be the 1st thing I check. Thinking along those lines, I seem to recall that when I cleaned the MAF with CRC MAF cleaner, the idle speed did indeed drop a tad. Thank you very much.
Old 07-29-2020, 08:01 AM #38
No unusual sounds is good news. In the best situation here, it may just be that the sensor went bad.
I remember on the other board Yotatech a guy had a 99 that had close to zero pressure at hot idle. He pulled the oil pan, found that the pick up screen was clogged, unclogged it, did two flushes, and drove it for a number of year there afterwards.
Old 07-29-2020, 08:09 AM #39
Mudflaps's Avatar
Mudflaps Mudflaps is offline
Real Name: Chris
Mudflaps is on a distinguished road
Mudflaps's Avatar
Real Name: Chris
BG 109
I use it regularly on my S Series Saturn to keep the oil rings unstuck.
In fact all BG products are awesome.
I'm fascinated by this stuff, I've heard whispers about it before but never knew what it was. I'm also fascinated by the $40 a quart price on Amazon. What's this stuff made of, and how does it work?
*My clock still works*
Mudflaps is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 08:19 AM #40
The IAC is known for getting crap in it and sticking.
Old 07-29-2020, 08:22 AM #41
Look on eBay for it or call some local dealerships. Most carry BG products.
I lucked out one time at the Toyota dealer and the BG distributer happened to be there. I bought it off his truck cash for half of what I paid on eBay. I think 5 a can. I have enough to last a good while and his business card in my wallet for next time.
Old 07-29-2020, 11:53 AM #42
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Hadn't thought of it...?
https://www.toyota-4runner.org/3520292-post13.html
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 01:09 PM #43
I'm not sure what the manual is smoking, but the pan is right there after the under cover / skid plate is removed:
On a 4WD, the diff is right there and a huge pain to remove:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-29-2020, 03:48 PM #44
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Haynes manuals are about as accurate as youtube conspiracy theories. Are some of them true? Sure, but you have no idea what's true and not. Haynes manuals do make good fire starters though
Old 07-29-2020, 04:48 PM #45
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Originally Posted by Dieselchessy View Post
2 symptoms.
This sounds perfect.
plcfcng is offline   Reply With QuoteReply With Quote
clean , engine , flush , oil , safest
Engine flush question Jasonredwood 3rd gen T4Rs 2 08-23-2014 05:50 AM
BG Engine Flush / Transmission flush scrhew 3rd gen T4Rs 19 09-11-2013 05:44 PM
Engine Flush Methods nilson Maintenance/Detailing 3 06-13-2011 06:22 PM
Switching from mineral to synthetic engine oil. Flush? paraordnance 4th Gen T4Rs 4 05-22-2009 11:55 PM
cpu chip, exhaust, engine flush ,gas mileage 96runner Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-06-2004 07:26 PM
