Old 07-29-2020, 04:37 PM #1
lucidberries lucidberries is offline
lucidberries is on a distinguished road
ARB Bumper questions!
Hey guys, I have a few questions surrounding the bumper on my 2000 4runner.
I have had the truck for about 4 months now. After some research turns out the aftermarket front bumper is actually for a newer Tacoma (SAHARA BUMPER ARB SAHARA BUMPER I believe) and I think it looks great.
Fitment is good and the previous owner painted the chrome top bar with rocker-guard/bed liner and that is exactly what I would have done as well.
I had a turn signal burn out and when I went to replace it seems the 10mm nuts are seized and the bolt is turning with the nut due to some corrosion. ( the light assembly needs to be replaced I guess? Does anyone know where to order one? I am in Canada)
I am wondering if it is worth it to remove the whole bumper, sandblast, and powder coat? I really like the look and want to keep it but hoping the rust isn't too bad and have to break something to replace the lamps.
On the outside, there are tiny patches of very light surface rust starting but mostly it is just the inside. Not really sure how to remove the light assembly though if it is seized... Maybe something I missed? Thanks!
lucidberries is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 03:07 PM #2
Anyone have experience with this before? lol
Old 09-29-2020, 03:46 PM #3
tripped38 tripped38 is offline
tripped38 is on a distinguished road
Does the light socket not twist out so you can replace the bulb? If not I would soak that in penetrating oil for a few days and then see if you can make progress.
But to me... it looks like those sockets would either twist off or pop some clips and come off.
Good luck. And I love the look of that bumper!
tripped38 is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 12:18 PM #4
nissanh nissanh is offline
Clean the thread with a wire brush. Apply WD-40. Grab the end of the bolt with a locking plier and back out the nut.
Old 10-01-2020, 10:23 PM #5
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Interesting, doesn't look like arb bumper to me
Old 10-02-2020, 10:43 AM #6
I did try this briefly but started chewing the threads and really didn't want to destroy anything before sourcing a replacement.
Old 10-02-2020, 10:48 AM #7
Thanks! I think it looks really unique.
So the white housing in the first picture is the part that contains the turn signal lamp and as far as I can tell the entire black insert (the 3 bolts) needs to come out to access the turn signal or the fog lamp...
Old 10-02-2020, 10:49 AM #8
haha well, it says ARB on it and looks identical to the SAHARA model I linked in my original post.
Old 10-02-2020, 10:57 AM #9
fog light looks like the 2 screws need to be taken out for access. and probably a twist off design. I have never been into one, but thats what it looks like to me. I would use wd-40 or something for the bolts and really start soaking them.
I have the older version of the ARb bumper sitting on some saw horses about to get cleaned up and installed! Cannot wait!
Old 10-02-2020, 11:07 AM #10
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
I dealt with this just this week on my ARB bumper.
I ended up having to "delete" one of the bolts on each side with a grinder to get the assembly apart. Unfortunately it doesn't look like there's any way to replace the bolts in the plastic housings, they're molded in.
It's a horrible design. I reassembled it with two bolts on each side, and it seems to be solid. I used a ton of antisieze on reassembly, hopefully the other hardware doesn't freeze up.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 01:39 PM #11
-Rob
Thanks for posting. That is kinda what I feared. I would grind them off but not sure if I would be able to find a replacement or somehow fabricate a way to remount... Agreed sh*t design.
arb , bumper , light , remove , rust
CBI bumper questions 3rdgenfan 3rd gen T4Rs 2 02-11-2016 03:07 PM
DIY bumper questions swapmeet General Discussions 15 01-27-2015 02:51 PM
Bumper questions greenmonkey 4th Gen T4Rs 7 02-08-2012 06:25 PM
Bumper Questions REV1 3rd gen T4Rs 3 08-22-2005 09:08 AM
