Old 07-30-2020, 10:56 AM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Front wheel studs
I did my tundra brake upgrade and my 17” steel wheels do not have enough off set so the caliper rubs. I do not want to run thick wheel spacers as I have long travel. I’m looking to buy something like these
But then I need to use a little bit longer longer wheel studs because I am not comfortable with the amount of thread engagement for the lug nut.
Anyone know of a longer wheels stud that fits?
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 12:18 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Have you looked into ET lug nuts? That might help you get the thread engagement you need without messing with the studs themselves. Plus if you ever changed your wheels down the road you don’t have extra long studs to deal with.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 12:35 PM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I ended up going with ARP Extended Length studs #100-7715
And Muteki open face lugs
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 12:49 PM #4
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
Same studs^ different lugs but similar.
I also ran my pushthrough centercaps through the spacer and wheel which is the closest to hubcentric as i could get with thin spacers. No issues or vibrations so far
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 01:53 PM #5
Twisted Sid's Avatar
Twisted Sid Twisted Sid is online now
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
How much does it hit? Can you shave down the caliper a little with a flap wheel?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is online now   Reply With QuoteReply With Quote
Old 07-30-2020, 02:20 PM #6
Shit, $100 in studs wonder if there is a dorman option, looks like they are Lexus iS300 studs. I’ll be running 5/8 studs soon after I get a few things done and would love to not spend another $100 on something that’s not permanent
Thank you
Old 07-30-2020, 07:54 PM #7
Well doesn’t look like anything is available that I could find with the .558 Knurl. Front wheel studs
Old 07-31-2020, 12:40 PM #8
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Try hereLonger extended wheel studs
Old 07-31-2020, 03:47 PM #9
Just ordered the ones from the wheel adapter place. Hope they arrive in a decent amount of time. I’ll do the Dorman next if these don’t work.
Thank you for the link.
Old 08-06-2020, 11:30 PM #10
Size reference stock and the wheel adapters place in the linked thread above
Old 08-08-2020, 06:37 PM #11
Ran into a little snag... the knurl is alittle bigger on these studs even though they are not supposed to be. They are .566 or so and stock is .558 and the press fit is just to tight so I’m going to open up the holes on the hub with a .550 reamer.
Old 08-15-2020, 09:27 AM #12
Got it all taken care of using the wheeladapter.com longer studs, a .550 reamer for the stud holes in the hub and a .250” spacer off the shelf from oriellys.
I’d probably use a smaller reamer if I had to do it over though the studs could be alittle tighter in the knurl just for a little more piece of mind but I have checked torque in the lung nuts a few times and they are holding at 85 ftlbs
front , longer , studs , wheel , wheels
Length of rear wheel studs Vs front(spacers install) benztech82 4th Gen T4Rs 22 06-21-2023 08:01 PM
Front Wheels Studs Too Short For Wheel Spacers Pekoe1111 3rd gen T4Rs 3 04-05-2020 01:04 AM
longer front wheel studs for spacers chipsahoy 3rd gen T4Rs 2 03-27-2020 09:01 PM
Lug nut and wheel studs help! 4RunnerKyle 3rd gen T4Rs 3 01-21-2015 06:32 PM
wheel studs/front davidtaylorcam Classic T4Rs 0 04-06-2009 09:13 AM
