Old 07-31-2020, 10:22 AM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
99 front tall coil height vs Tundra coil vs OME 880/881
I own a 1999 3rd gen 4runner with tall coils. I just installed OME 906 coils with Bilstein 5100 24-249966 for the rear and Im at 22" hub to fender.
Now the front..... Im running 265/70/16 now, but will soon install 265/75/16.
With the old stock shock and 99 coil my front sits at almost 21".
It would be nice to sit at 21.5" with 0.5" of rake or at 22" for it to be even.
I want the front to be more soft than the rear and I'm trying to stay away from spacers. I will be running Bilstein 24-248730 4runner specific shocks for the front.
Initially I would like to install new 99 coils with Bilstein for front, but feel it may be too low.
Would second perch bring me closer to 22"?
Are the Tundra coils taller than 99 coils?
Are 880 OME shorter than 99 and tundra coils?
Are the 881 way too stiff for the front end?
Any feedback is greatly appreciated!
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 10:42 AM #2
Front Coil Lengths
Not sure how the left/right specific coil heights affect overall height?
Also, not sure of the front vehicle height using Bilstein 24-248730 4runner specific shock when paired with the below coils and their adjustable perches.
Im trying to get 21.5" or just under 22"
99 tall front coils
14.72" Left
14.48" Right
Tundra front coils
14.88" Left
14.63" Right
OME 880
14.37"
OME 881
14.76"
Old 07-31-2020, 12:26 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
99 talls will be the softer than ome or tundra coils therefore a softer ride. If you are going to be pairing 99 talls with adjustable bilstein front shocks then you can change heights as needed. I would probably start on the 2nd notch from bottom and drive around for a couple months and then measure your hub to fender again after everything settles.
Left side coils are taller to compensate for additional weight of the 4wd components and gas tank on the left side.
Old 08-02-2020, 12:15 PM #4
Great. Thank you!
Would the 99 coils have a shorter life than the 880 or 881?
Is it better to have the left and right side specific coil vs the OME at one height?
Could I run the Bilstein 5100 4runner specific coil with 880/ or 881?
If so, would the 5100 with 880/881 give me the same front adjustable height as the 99 coils?
I would prefer the softness of the 99 coils, but they are much more pricey than the 880/881. If I could get the same front end height from the 880 and they are not too crazy stiff, I may consider the 880 vs 99 coil because of price.
Im running 906 in rear with Bilstein 5100 4runner specific shocks.
Thank you very much for your wonderful feedback.
Old 08-02-2020, 12:17 PM #5
Im running stock front bumper.. but if I came across a reasonably priced ARB, I would probably install it in a heart beat.
Thanks
Old 08-02-2020, 02:24 PM #6
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
Another option would be using 5th gen springs for the front. I put them on all 4 corners with cheapo KYB Gas-A-Just, 21.75 on both fronts, 22.75 in the rears. Got mine from the classifieds here for under 200 shipped for all 4, might get lucky and find someone that only wants shipping covered.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 09:41 AM #7
Real Name: Patrick
Real Name: Patrick
Originally Posted by hawkcharmer View Post
Great. Thank you!
Would the 99 coils have a shorter life than the 880 or 881? Either option would last a long time with stock weight in the front
Is it better to have the left and right side specific coil vs the OME at one height? That's personal preference. If you use OME springs and want to adjust the left/right uneven height then you can use trim packers to level it all out.
If so, would the 5100 with 880/881 give me the same front adjustable height as the 99 coils? You can run bilstein 5100 shocks with OME, but most companies that sell this combo only use the bottom perch on the 5100's. Try searching "OME 5100"
I would prefer the softness of the 99 coils, but they are much more pricey than the 880/881. If I could get the same front end height from the 880 and they are not too crazy stiff, I may consider the 880 vs 99 coil because of price. Moog is a good (cheaper) alternative for 99 talls. You'll want the Moog front springs for a 1999 4wd Limited 4Runner.
On a separate note, 99 talls and OME 880/881's will sag and bounce a lot if you put an ARB front bumper on it. You would need a front coil spring with a higher spring rate like OME 882's or bilstein 6112's.
Answers in bold.
Old 08-03-2020, 07:44 PM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Does anyone know where I can find an actual chart of spring rates and lengths for the different coils out there?
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 01:46 AM #9
Originally Posted by Bad Luck View Post
Answers in bold.
Thank you very much
Would the Moog front springs work well with Bilstein 5100 (4runner specific)
Which perch would you recommend?
Thanks again
Old 08-04-2020, 08:00 AM #10
itskohler's Avatar
itskohler's Avatar
Thank you very much
Thanks again
1st perch is what theyre designed for.
Old 08-04-2020, 09:09 AM #11
Real Name: Patrick
Real Name: Patrick
Thank you very much
Thanks again
Moog springs work well with Bilstein 5100's. I would start on either the 1st or 2nd perch and drive around for a couple weeks and check your hub to fender measurements. You may need to adjust the fronts to match the rear or whatever height you are going for in the front.
Old 08-04-2020, 09:12 AM #12
Real Name: Patrick
Real Name: Patrick
Here's one for OME springs: Cruiser Outfitters Scroll down for standard units.
Old 08-31-2020, 11:23 AM #13
Decided to go with Tundra front coil
I just installed OME 906 springs/ Bilstein 5100 24-9966 for the rear. Im now trying to decide on the correct shock for front. Im going to use new front Tundra coils with a spring rate around #600.
Should I purchase Bilstein 5100 24-261415 (99-06 Tundra firmer valving) or the 4runner specific front shock Bilstein 5100 24-248730? Will the firmer valved shock be too much for the 3rd gen 4runner? Need to purchase asap. Thank you
Old 09-28-2020, 03:59 AM #14
JUICE222 JUICE222 is offline
JUICE222 is on a distinguished road
I would go with the Tundra Bilstein shocks if i were running Tundra coils. I have 4runner specific Bilstein shocks paired with OME 880 fronts and 906 rear coils. Ride is soft and comfortable.
JUICE222 is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 04:34 AM #15
AlblineStar808 AlblineStar808 is offline
AlblineStar808 is on a distinguished road
Pics of the side profile? Wondering if it’s level height?
AlblineStar808 is offline   Reply With QuoteReply With Quote
bilstein , coil , coils , front , ome
Tundra Coil/LC coil lift advice. VA07 3rd gen T4Rs 12 08-28-2013 12:08 PM
Tundra OEM coil isolator required for coil swap? 01t4rnr 3rd gen T4Rs 3 11-22-2012 05:05 PM
whats the closest OME coil to achieve same height as LC coil? cordrayj1 3rd gen T4Rs 9 05-25-2012 09:54 PM
