Old 07-31-2020, 06:55 PM #1
Mudflaps's Avatar
Mudflaps Mudflaps is offline
Real Name: Chris
Mudflaps is on a distinguished road
Mudflaps's Avatar
Real Name: Chris
P0420......but what causes it?
Maybe I'm a fool, sorry if that's the case.
But I'll cut to the chase. I'm throwing a P0420 code that shows up every now and then on my 01 Limited. I live in state that doesnt do smog testing . I'm wondering if this is actually a problem with my cat reaching the end of it's like (221,xxx mi) or is this just a weird 02 problem. I don't have countless dollars to throw at the problem and replace parts until I found the right one such as I would like to......so can I dodge this problem easily buy zeroing in on ONE particular issue...or....what?
Help. lol
*My clock still works*
Mudflaps is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 07:26 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Any exhaust leaks or 02 gaskets leaking? Especially near the cat converter.
Besides leaks can be a faulty O2 sensor or a bad cat.
They also make a cat clean additive for your gas that can clean a clogged cat.
However, if the cat is screened burned out. Then the cat will need to be replaced.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 07-31-2020, 07:41 PM #3
19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough 19963.4lsr5 is a jewel in the rough
For me it was antifreeze.
Even a small amount where you only top off your overflow tank once every few months will cause it.
Cats donít really ware out under normal use. Overheating from missfireís will melt them.
I have the OEM cat that at 230,000 ish miles started giving me the dreaded 420 code. I tried everything including a rear O2 simulator.
When it became obvious I had an issue with antifreeze consumption I ended up rebuilding my spare engine. I decided to listen to a few sites about what causes the 420 code and put the same cat back on. The O2 readiness monitor set on my first drive to work. Itís been fine ever since.
Old 07-31-2020, 10:06 PM #4
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
It can be caused by bad O2 sensors, cats, MAF, or other problems, but is mostly caused by exhaust leaks around the cat or the O2 sensors.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 229,000 miles. F**K Janet Mills
MaineRunna is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 10:41 PM #5
OpenYota OpenYota is offline
OpenYota is on a distinguished road
I have the same code.
Mine is being caused by my bad gasket in the flange connecting the cat convertor to the exhaust pipe.
Mine is making a ticking sound and I can also feel exhaust air coming out of it so I would say check first for leaks in your manifold all the way down to your tail pipe.
But like others have said it can be caused by a few other things but keep your fingers crossed it isn't the cat convertor!
Best of luck
2001 4Runner SR5 4x4
OpenYota is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 11:56 PM #6
Thebeastlives Thebeastlives is offline
Thebeastlives will become famous soon enough Thebeastlives will become famous soon enough
Mine was the cat failed and once replaced at 275k the prb was fixed.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 01:59 AM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is on a distinguished road
Devbot's Avatar
Real Name: Devan
Mine was thrown by a bad O2 sensor receiving like 4v or something. If you can, check with your OBD how much power they're getting, iirc it should be 12v. Can't go wrong with working small and starting from there.
Forewarning: they're known to be rusted on beyond belief and often halfway brazed to the exhaust. I'd recommend spraying a bunch of PB on them and letting them soak for a while (helps if they're warm too when you loosen them) but don't be shocked if you gotta buy new nuts. Maybe get some beforehand if you have no other ride.
Y2K Highlander 3.4L auto @ 285k and climbing
Old 08-01-2020, 08:54 AM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
My 01 and others on here have mentioned if we drive 1-10 mph, usually while off roading, for just a mile or two and Bam, there is it pending 0420, like clockwork, everytime. My state does smog test and it passes every year.
I can drive for tens of thousands of miles but one slow speed mile or two and there it is....
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 08-01-2020, 09:38 AM #9
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
Thumbs up
I haven't been able to pin down any places with exhaust leaks, at least as far as I can see. There could possibly be a crack or something up close to the manifolds, I never stopped to think that the error code could have actually been caused by a LEAK.
This i'm curious about. You mean your engine was ingesting coolant somewhere through the system, or just a being below a certain amount in the cooling system is causing this code to pop up.
Best of luck
You know, my girl's youngest son is like Rain Man and can pick up on tiny things that I'm too deaf or otherwise distracted to notice, and pointed out a very minor ticking sound........I'm starting an investigation in that area.
Thanks a LOT for all the quick responses and help. I'll go attack this task list and report back
Old 08-01-2020, 09:39 AM #10
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
You know, I did start to notice this popped up directly after wheeling, but it had been doing it on and off since I bought the truck lol
Old 08-01-2020, 11:13 AM #11
The 96 engine I put in my 97 was ingesting antifreeze from a bad cylinder. What I thought was a bad head gasket ended up being far worse and required me to rebuild the engine I pulled out of the 97.
countless , p0420 , problem , throwing , weird
P0420, what happens if you do nothing? HappyHooligan 3rd gen T4Rs 3 12-11-2019 03:20 PM
P0420 2ndhandyotaman 3rd gen T4Rs 35 03-17-2018 10:39 AM
Help p0420 wrestler157 4th Gen T4Rs 2 10-26-2011 02:26 PM
p0420 mikeya 3rd gen T4Rs 10 10-03-2011 12:37 AM
P0420 - Replaced A/F after P1130/1135 a few months ago... now P0420 low ?? Bank 1 Headly 3rd gen T4Rs 19 01-23-2011 08:52 PM
