Old 08-04-2020, 02:56 PM #16
Mighty Buffalo's Avatar
Mighty Buffalo Mighty Buffalo is offline
Real Name: Greg
Mighty Buffalo is on a distinguished road
Real Name: Greg
Originally Posted by MagusWyatt View Post
I installed a B&M 70264 about a month ago. It's the bigger of the two choices from B&M that most use for this mod.
It's twice as thick, but the face of it is more narrow. This one is rated at 14,400 BTU versus the 13,000 BTU of the smaller version, B&M 70268.
I had to remove the horn on that side to get it to fit, but I was planning on tossing the factory horns and relocating the mounts for an upcoming mod anyway. If you want to keep the horn there, there was another thread where someone mentioned they just bent the bracket forward to get it to clear successfully.
I used the same. Used the brackets that come in the kit instead of the zip ties through the AC condenser.
Mighty Buffalo is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 06:48 AM #17
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Hi,
May I know the reason for having the hot fluid travel upwards? Thanks.
Originally Posted by nissanh View Post
I know you know this but to make sure you do it right, the hot fluid must enter from the bottom barb and exit out from the top barb.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 09:04 AM #18
Originally Posted by HiluxSurf SSR-G View Post
Hi,
It pushes the air out of the cooler.
2.7l , cooled , cooler , fan , insure
New trans cooler and radiator - should I get rad for manual trans? dogbreath650 3rd gen T4Rs 3 06-06-2017 02:14 PM
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
trans cooler ceyese 5th gen T4Rs 1 07-29-2014 05:16 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
Is that a trans cooler or oil cooler in front of the AC Condensor? kn38ms 4th Gen T4Rs 8 06-05-2008 07:41 PM
