Old 08-02-2020, 07:34 PM #1
Stereww Stereww is offline
Real Name: Andrew
Stereww is on a distinguished road
Real Name: Andrew
2000 4Runner for parts for a 1997 4Runner.
Considering purchasing a 2000 4Runner to use as a parts car for my 1997 4Runner. Was wondering if anything has done something similar. I would like to use the center cupholders, which I know is a popular mod. Also the steering wheel, the powered seats which I think I just have to wire into the windows, the bumpers and fender flares. It is a limited so I'm a little concerned about the bumpers. Just wondering if anyone has done something similar and what all is and isn't compatible. I know the transmission and TC are different. Could probably take the engine though.
Thanks
Sent from my Pixel 3 XL using Tapatalk
Stereww is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 07:58 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thanks
Wiring has some differences. I am sure it can be done but 1999 thru 2002 have the communication multiplexer bus in them 1996 thru 1998 do not.
So going to need to trace and build some circuits for your seats etc worst case.
Old 08-03-2020, 01:41 AM #3
Real Name: Andrew
Real Name: Andrew
I thought I read somewhere that you could just write them into the wiring for the electric windows. Only problem will be that they won't work when the car is off.
Old 08-03-2020, 01:43 AM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Thanks
The Limiteds have fender flares that tie in with the body cladding on the doors. They will not be compatible with an SR5. The bumpers will also have the flair end caps that would then need to be removed because they won’t match up to your 97. The bumpers will bolt up if you wanted to use them but they’d have holes in them where the flare caps were removed. At least that’s the case for the front bumper. The rear flare is actually part of the mud flap but bolts on through the bumper but you get the idea.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 08:49 AM #5
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Technically the transmission is a little different (different valve body) but it will definitely work in your 97 without changing anything. I installed a 99 tranny in my 97, everything bolts up/plugs in fine with no issues. It's the 01/02 trannys that don't work with the earlier years because of the lack of a kick down cable.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 10:35 AM #6
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
There are so many things to use off a parts car. When something breaks esp weird small stuff you just walk over to the parts car and pull it off. As long as you have room for it and no one to get on your case about it its so worth it
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 07:45 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can do what I did and swap the limited doors, front fenders, bumpers and rear limited flares onto a Sr5.. you have to drill holes or glue on the section that is right above the rear wheel wells. I just drilled and bolted them into my sr5. Then you have attach the plastic molding on the rockers. Then if you want them. Put the limited Running boards on too. ;-)
4runner , bumpers , parts , similar , wondering
1997 bumper on a 2000 4runner WRfarmer 3rd gen T4Rs 2 01-31-2019 09:44 PM
FS: 1997 4runner $2000, Dayton, OH 97'runnerSR5 For Sale: Vehicles 0 07-20-2017 01:47 AM
1997 SR5 for sale for parts $2000 in Richmond, Ky BigSlim For Sale: Vehicles 12 02-03-2016 03:48 PM
1997 4runner parts bgngranada 3rd gen T4Rs 2 05-27-2015 08:38 AM
WTB 1997-2000 4Runner 4X4 SR5 in SoCal freakinmoeron Classifieds - buy & sell (no commercial ads please) 2 04-06-2010 09:09 PM
