Old 08-03-2020, 12:30 PM #1
4runnerWiniarski23 4runnerWiniarski23 is offline
Real Name: Al
4runnerWiniarski23 is on a distinguished road
Real Name: Al
Exhaust leak at flange
Hey guys been lurking more than posting. Recently developed a leak at my flange, secondary cat, flange towards front. I've been trying to come up.with a way to just eliminate that secondary cat completely..
Any test pie? Straight pipe options? 3rd gen is 2 1/4 pipe right? Any other ideas besides replacement bolt in?
2001 sr5
Thanks
4runnerWiniarski23 is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 12:31 PM #2
Real Name: Al
Real Name: Al
This section
Exhaust leak at flange-82db0459-957b-474e-9666-ac16a6d6586b-jpg
Old 08-03-2020, 02:14 PM #3
TheDurk's Avatar
TheDurk TheDurk is online now
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Did you consider a new gasket? Fixed mine....
My Backyard Frame Swap
TheDurk is online now   Reply With QuoteReply With Quote
Old 08-03-2020, 11:29 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
You live in NY (or at least your post tag says that) so you're under strict smog rules like out here in CA. If you try an eliminate the cat, I'm pretty sure you won't pass. If you leave the leak, also pretty sure you won't pass since the sniffer will detect the excess oxygen in the exhaust pipe.
Magnaflow sells 50-state legal catalytic converters starting at $200 if it's the body of the cat that's failing (repairing the casing is not smog approved). If it's just the exhaust pipe, weld it shut or use JB weld to clog up the crack or hole.
326WHP 347TQ
Old 08-04-2020, 10:55 AM #5
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Try some gaskets. Leaks do set Cat effiency codes, will for sure set codes if you remove it.
cat , flange , leak , pipe , secondary
exhaust crossover flange nut mendozer 3rd gen T4Rs 13 04-01-2021 04:12 AM
Differential flange leak fix this weekend gaber6 4th Gen T4Rs 13 06-15-2020 09:22 PM
Exhaust flange rust? Northern 4Runner 5th gen T4Rs 0 08-07-2017 10:39 AM
2002 4Runner pinion leak & flange movement. HELP xcmountain80 3rd gen T4Rs 0 10-17-2016 06:31 AM
Installing exhaust flange Mantree General Discussions 0 02-01-2016 04:27 PM
