Old 08-09-2020, 01:37 PM #16
kyrin kyrin is offline
kyrin is on a distinguished road
Just to get dirt away from a connector to loosen up? Compressed air
kyrin is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 10:28 PM #17
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Wow. Someone reading this thread is going to be more confused then when they started. I am going to add my own thoughts just to make things worse. A lot of good products are mentioned, but they have to be used the right way and a lot of time these posts don't explain that.
First, nine times out of ten the connector is not stuck, you just haven't succeeded in disengaging which ever diabolical locking device Toyota engineers installed on that plug. This is not a shot at anybody...I am talking about my own experience. Make sure you are doing it right, and not trying to separate something that is really one piece. Go get the right tool you were too lazy to look for at the beginning and really squeeze that locking thing and don't get blocked by any ridges on the side and try again also using the right tool to separate at the same time. Get help if you need it. Sometimes it just takes three hands. Usually, it will amaze you by how it flies apart when you find the secret.
If it really is stuck, (rare) I will use a penetrant like PBBlaster to help get it apart. Then, clean the contacts with DeOxit or CRC Contact cleaner or whatever and blow it out with compressed air. Do it again if it needs it. Then dielectric grease on top to protect it. Do not use conducting grease unless it is a ONE wire terminal, like a car battery. Then you can use Fluid film, Vaseline or terminal grease or whatever. I use Vaseline. Dielectric grease does not interfere with metal-to-metal connections. Don't listen to anyone who says different. I've been using it for forty years.
My Backyard Frame Swap
harness , lubricant , removing , time , wiring
Anyone know what this wiring harness is? Bimmer-Bob 5th gen T4Rs 14 08-21-2018 07:43 AM
Wiring air on board switch to Amazon wiring harness. Btmannin Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-18-2018 03:33 PM
Where can I get a wiring harness for a '97 JNYD401 3rd gen T4Rs 4 04-27-2015 10:30 PM
4th gen wiring harness. coyoteslayer 4th Gen T4Rs 5 04-16-2015 01:24 PM
1st Gen Cab wiring harness Ricky O'Shea Classic T4Rs 2 12-08-2014 03:32 PM
