Old 08-04-2020, 03:45 PM #1
bigjim bigjim is offline
bigjim is on a distinguished road
Failed emissions for the 3rd time
I have a 99 2wd 4runner with appx 262K miles on it.
in 2018 NOx was around 0.9 GPM, the max in CO is 2.0 GPM.
2020 rolls around and i have to restest.
Test 1: NOx = 2.082 = fail
Test 2: NOx = 2.27xx = fail
before the test I
--Premium gas
--replaced air filter
--cleaned MAF
--ran seafoam through it
Test 3:NOx = 2.17xx = fail
before the test I
--Ran Guaranteed Pass in tank
--replaced upstream O2 Sensor
--replaced cracked air filter to throttle body boot
--half tank premium gas ran through before the test and tested with less than 1/4 tank
Not sure what else to try aside from a new cat.
Any suggestion on a direct fit replacement?
All the other levels are good
Thanks
bigjim is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 04:33 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Maybe try a product called Cataclean. It gets mixed reviews but many have had a positive result so it's worth a shot before dropping big coin on a catalytic converter. Amazon.com: Cataclean 120019 Cataclean - The Original Liquid Science - Complete Engine, Fuel & Exhaust System Cleaner: Automotive
Old 08-04-2020, 04:36 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Use regular gas. Vehicle was designed around regular gas so premium isn't really helping anything.
Old 08-04-2020, 05:07 PM #4
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
What are the rest of the readings besides Nox?
Nox is created by high combustion temps. Some things that can cause high nox are:
Lean fuel conditions (vacuum leaks, bad or poor injector spray patterns, etc)
Carbon build up in combustion chamber/piston (causes slightly higher compression # causing higher exhaust temps)
Bad cat/cats, 21 year old cats have probably exceeded their service life to be honest. Expensive to replace, but if they are toast, they should be replaced.
You can try all the snake oil out there to get you to pass, but it's best to fix issues that are present.
Also what state are you in? Be aware that you 4runner may be put on the gross polluter list if the emissions are double what is permmited for the 4runner.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 05:14 PM #5
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
I disagree. With my 5 speed, using "regular" which is 85 octane here, at low RPM / high load (IE lugging it) you can hear the detonation. I've run 91 in it since noticing this early on after buying it. I attribute this low octane detonation to accounts of others I read that have head gasket problems.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 05:23 PM #6
Real Name: Patrick
Real Name: Patrick
With higher elevation areas then yes, but elsewhere I stand by using regular gas when called for. With a manual you can lug anything with any gas enough to ping.
Old 08-04-2020, 05:25 PM #7
HC GPM = 0.2109 .......Colorado Limit=1.2
CO GPM = 3.4626........Colorado Limit=15
CO2 GPM = 445.0452.....Colorado no limit
NOx GPM = 2.1749......Colorado Limit=2.000
I am tempted to just spend the 250 on an Eastern Catalytics cat
1999 Toyota 4Runner 3.4L V6, with California emissions Eastern Direct-fit Federal EPA-Compliant Catalytic Converters - FREE SHIPPING - Lowest Price Guaranteed!
BTW i only have 1 cat, the front one
Thanks
Old 08-04-2020, 06:00 PM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Not a bad price and warranty. I'd go for it....
Old 08-04-2020, 06:35 PM #9
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
High NOx means your chamber temps are high.
You should flush your coolant system, refill with 50/50 and maybe put in some water wetter.
You should run a tank of gas with a full bottle of Seafoam, maybe 2 tanks with full bottles to clean out any carbon.
Make sure you don't have any vacuum leaks, change your fuel filter, clean the IAC, MAF, and replace O2 sensor. Anything that would cause it to run lean.
When was your timing belt replaced. Any chance timing is off?
Correct plugs installed?
What oil you running and when was it changed? Maybe run some Marvels to remove sludge.
When was the fuel filter changed.
Thermostat installed correctly?
You need to cool the combustion chamber some and prevent pre-ignition.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 09:15 AM #10
It is due for a timing belt change, just didn't want to replace it if it wasn't going to pass.
I ordered the Eastern cat from the link above, I'll put that in and see what happens.
O2 sensors are new
MAF was already cleaned
Oil is full synthetic no idea what brand
Thanks
Old 08-05-2020, 09:51 AM #11
You might be running lean on a cylinder or two from a clogged injector.
Put a double dose of Techron in it.
fail , nox , replaced , tank , test
Failed emissions help please 5280nrg 3rd gen T4Rs 31 12-10-2012 07:49 PM
94runner failed emissions test skinny Classic T4Rs 3 05-29-2012 06:03 AM
failed emissions '91 lolon00b General Discussions 2 07-28-2011 02:05 PM
89 4runner failed emissions Oval311 Problems & Warranty Issues 1 03-11-2011 02:49 AM
Failed Emissions MoboHaji Classic T4Rs 2 06-23-2005 12:25 AM
