08-04-2020, 08:37 PM
4000 lbs winch enough?
Hey guys,
I have a question about the best option for a winch. I don't wheel very often or hard but I like the utility of having a winch. I'm stuck on how strong of a winch I need. It seems like most people are using 8000lbs +.
My question is... will a 4000-5000 lbs winch be enough? My plan is to keep a snatch block handy (to double my power when needed) and a winch rope extender to compensate for the lost length. The reason I want a low power winch is because of their compact size, weight, and cost.
Or should I just buy a 8k winch lol.
Let me know your thoughts,
thanks!
Reason: title change
08-04-2020, 09:53 PM
Real Name: 3 Bears
Real Name: 3 Bears
the smitty built 10k with synthetic is a very good wench.
08-04-2020, 10:13 PM
+1. Yes, the Smittbilt is a Chinese manufactured winch, but I think it is possibly the best bang-for-buck winch out there. 10k w/ synthetic line is plenty, or 12k if your budget allows and your bumper can fit it (it's not that much more)
Edit: OH YEAH, and a lifetime warranty on smittybilts
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
08-04-2020, 10:19 PM
Yup for sure the smittybilt winches look really good but It looks like if I put a 4000 lbs winch instead of a 10000 lbs ill save over 50lbs of weight.
Also I should have mentioned that I'm planning to put it under the stock bumper, so compact size is also an important factor. Do you think 4000lbs + snatch block will be enough?
08-04-2020, 10:31 PM
Maaan you really need to look up Albert Pigman on Facebook (AMP'd UP, LLC)
He makes a great winch plate for the stock 99-2002 bumper.
People have put a Smittybilt 12k behind the stock fat-lip bumper, easy with his plates
08-05-2020, 12:18 AM
I have owned many winches and pulled out/dug out more cars that I rememer. It all depends on what your stuck in.
If your stuck in deep mud a 5k winch may struggle but 3/1 pully system would help for sure just take more time( wit will get you out of 99% consdition also).
I honestly do not carry a winch anymore as I mostly drive dry desert /sandy conditions and I just drive smart and im good. The only time I have ever needed one was in the mud and im just smarter now. Most times I needed one I never had enough cable/rope to reach anything anyways.
( yeah I know I can make a dead man or somthing but I was never in super need and just callled for help)
My advice is is forget the winch unless your planning to really pushing the conditions in mud. A simple bottle jack and some rocks can get you out of any sand. Or better yet but some max tracks.
I just dont want to carry all that weight all the time for very little use.
08-05-2020, 12:29 AM
I built and installed a front tow hitch on my 97. I carry a 5000 lb harbor freight winch in a large tool bag that I through in the back when I'm going anywhere near a mountain or trail. I can put the winch on the front or the back. I've used with and without a snatch block several times pulling other vehicles out without a problem. You have be careful not to overload it.
I probably should have bought the 9000 lb, but I did not want handle the extra weight when installing it on the tow hitch.
08-05-2020, 02:02 PM
Unless you have the extras already, I'm sure that a 4k winch + snatch block + line extender is going to cost more than just a simple 8k winch...
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
08-05-2020, 02:12 PM
I'm definitely on the same page as this guy here. If you have none of the other items, I would just go 8k winch and be done with it. By the time you got the other gear you really aren't saving any money. If weight is the main factor, then figure out what your threshold for weight is and get the biggest winch that fits that criteria. I am just picturing being stuck, having my 4k winch to use, and it still won't get me unstuck from my situation when the time comes. It's your call, but I would go 8k or better everyday!
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
08-05-2020, 05:16 PM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Hey guys,
thanks!
I just put a 10K smitty on the front of my truck. have not had a chance to test on her yet. I have owned a couple of cheaper lesser powered winches before. don't under rate your winch and think you can make up for the loss with force multipliers. if your running the winch at it's limit it will overheat and or wear out much faster. been there done that.
1997 Sketchy SleepyDad build
mounting them and getting it all setup is a pain but it's worth it to size the winch to the truck outright. IMO. as an extra if possible get one with the wireless remote it's the bomb.
Reason: because disco lives on
08-05-2020, 05:38 PM
A single snatch block does NOT double your pulling power.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
08-05-2020, 05:47 PM
But it doubles the pulling force minus minor frictional losses. Just takes twice as much line to do the same work.
08-05-2020, 06:11 PM
Real Name: 3 Bears
Real Name: 3 Bears
what....wait....he makes a plate to put a winch behind the fat limp...wow...wait...i need more info like ...now as this could change my plans big time
08-05-2020, 06:51 PM
I fully understand the physics behind it. A single snatch block WILL double the pulling force because it provides a mechanical advantage. Obviously the winch isn't getting more powerful!
08-05-2020, 06:56 PM
Real Name: 3 Bears
Real Name: 3 Bears
sorry ...not meaning to thread jack, but the facebook listed above replied and has no idea what we are talking about'
its kind of related as it deals with winch stuff
edit: there is a Amp'd llc...not amp'd up llc...the first makes t shirts....my error
