Old 08-07-2020, 08:48 AM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Battery > alternator check out
My replacement alternator has finally arrived and I will be putting it in this week-end.
However, I only know what Haynes Repair Manual says. So, I would appreciate it if guys will confirm the following.
A fully charged new battery, with engine OFF, should read aprox 12.4- 12.6 volts. With the engine ON, the voltage at the battery should read 13. - 14.6
Additionally, the headlights should get BRIGHTER when the engine is rev'ed up ?
If all of the above check out, can I assume that the alternator is correctly charging the battery ???
Any other thoughts you may have would be greatly appreciated.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 09:21 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
A good, well charged battery, sitting overnight, should be At Least 12.7 in the morning.
A new, well charged battery overnight is typically more like 13.3-13.5.
Charging can vary, at least on mine (original alt at 326k), using Torque I can watch it waver anywhere from 12.9 to 13.8, but hey its nearly 20 yrs old and never rebuilt/replaced.
Mind gets No brighter when revved, and no dimmer when engine is shut down.
I just use cheap ol' $49 walmart 2 yr batts btw....last 3 yrs in texas heat....
Old 08-07-2020, 11:38 AM #3
Engine running and nothing else on you should read anywhere from 13.5 to 14v at the battery posts.
Get a cig lighter volt meter.
Old 08-07-2020, 12:59 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
If your battery is in good order then you should be seeing 14.2 to 14.4 volts at start up. Anything less than 13.4 volts under load at idle(AC, Defrost), fully warmed up, is a problem.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 01:13 PM #5
I never heard of a cigarette lighter volt meter. How does it work ?
Old 08-07-2020, 01:27 PM #6
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Battery volts can vary depending on the brands. When the cars on the volts will always be 13v+ but when its off it depends on the battery. My autozone agm is 12.6 when fully topped off while an optima will be over 13v when full.
The cig plug volt meter is just a small device you can plug into the cig plug and it shows your voltage. To get exact voltage read from the battery. The tiny wires going to the cig plug will drop the voltage down slightly
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 01:29 PM #7
alternator , battery , check , engine , read
Bad battery or alternator? StreetCreeper 3rd gen T4Rs 41 11-12-2019 03:48 PM
Battery or Alternator? ty7466 3rd gen T4Rs 5 08-01-2014 12:33 PM
Can you check what voltage your alternator is putting to the battery? chayos00 4th Gen T4Rs 9 04-11-2014 07:09 PM
Battery? Alternator? Zackadeez 3rd gen T4Rs 10 11-23-2013 04:13 PM
Battery or Alternator? Krystle Classic T4Rs 0 11-30-2009 07:41 PM
