08-25-2020, 11:33 PM
Jross's Shock List
Alright, this is the first time I've tried an embedded excel thing, we will see how well it works.
Hey it works! Alright, so hopefully this helps folks out when they are trying to figure out which shocks they may want. Lastly, if anyone has any data to add please let me know so I can update my sheet.
08-25-2020, 11:52 PM
Real Name: Devan
Real Name: Devan
Tokico Blacks should be on the rear list for sure, though I don't have any information for the table other than they're $45
In fact, that's why i'm recommending it
08-25-2020, 11:53 PM
what about Fox?
08-26-2020, 12:30 AM
Okay sure, any idea who may have have more information on them?
Originally Posted by audiness
what about Fox?
I just don't know anything about them, which ones should I add? Model, specs?
08-26-2020, 01:56 AM
About your review. When you say “ass” do you mean they performed poorly, or that you judged them by seat-o-the pants feel?
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
08-26-2020, 07:23 AM
KYB Gas-A-Just shocks are currently on my t4r. Might be worth adding them as the budget option?
98 Limited - 2010 Triumph Daytona - 2017 GTI
08-26-2020, 09:20 AM
Real Name: Patrick
Real Name: Patrick
King's are progressive valving. All bilstein options (4600,5100, 5160, and 6112) are digressive. Icon's are digressive.
Measured Tundra 6112:
-Collapsed - 13.23"
-Extended - 18.35"
-Travel - 5.12"
4Runner 6112's are the same measurements as 4Runner 5100's
Tundra 5160's are an option for the rear if you swap the bottom bushing out. Part #25-261332 (not side specific)
-Collapsed - 13.84"
-Extended - 23.23"
-Travel - 9.39"
Sonoran Steel sells their Classic 1.2 Lift with either FJ80 rear shocks or Bilstein extended travel shocks for an FJ Cruiser. Bilstein shocks for an FJ cruiser are part number 33-187174.
-Collapsed - 14.91"
-Extended - 23.5"
-Travel - 8.59"
Source: 1996-2002 - Classic System 1.2 [96-02_complete] - $1,575.15 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
https://wheelersoffroad.com/shop-by-...187174-x2.html
Are you sure front icon's are twin tube and front dobinson's are mono tube? I thought it was the other way around.
Edit: To be accurate I believe you only have the standard king's listed for the front suspension. There is an extended travel version, but I am unfamiliar with the extended and collapsed lengths for them.
Edit 2: FJ80 Rear Tokico Shock
-Collapsed - 14.5"
-Extended - 23.5"
-Travel - 9.0"
Source: Wayback Machine
08-26-2020, 09:21 AM
Purely talking about ride quality in my opinion. Lol
Okay sure, do they have the same measurements as stock?
08-26-2020, 12:45 PM
-Collapsed - 13.23"
-Extended - 18.35"
-Travel - 5.12"
-Collapsed - 13.84"
-Extended - 23.23"
-Travel - 9.39"
-Collapsed - 14.91"
-Extended - 23.5"
-Travel - 8.59"
Bilstein 5100 Rear Shock Set for 2003+ 4Runner, 2007+ FJ Cruiser (33-187174 x2)
-Collapsed - 14.5"
-Extended - 23.5"
-Travel - 9.0"
Go it, I'll update the report later today
Not sure what happened but the icons should be mono and the dobinson's should be twin.
08-26-2020, 02:02 PM
Updated!
08-26-2020, 02:38 PM
Real Name: Patrick
Real Name: Patrick
Updated!
08-26-2020, 05:51 PM
Fixed, anything else?
08-26-2020, 11:28 PM
King has an extended travel 25001-151-EXT. I can measure when I get a chance.
08-27-2020, 01:37 AM
Fox 2.5" Factory Series Front Coilovers for 96-02 4Runner
FOX-883-02-023 0-2" lift standard travel
FOX-883-02-024 for 0-3" lift extended travel
Monotube
Everything I am reading says Fox are progressive, but couldn't find anything on their website about it.
$1295 on wheelersoffroad
08-27-2020, 01:05 PM
Compare info to what Sonoran Steel did years ago:
https://www.sonoransteel.com/downloa...aRearShock.pdf
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
