Old 08-07-2020, 10:08 PM #1
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
Easiest way to remove front strut?
Is this the fastest/easiest way in your opinion to get a front strut out? If I use this method can removing the steering tie-rod end be avoided?
1. Disconnect sway bar at the end link
2. Jack up truck
3. Remove wheels
4. Unbolt the strut
5. Use a bottle jack to take pressure off bottom strut bolt and remove strut bolt.
6. Use the bottle jack some more to push the control arm assembly down more and remove strut.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:49 PM #2
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
All I did for my rig was the 3 top bolts and the bottom bolt. Wiggled right out without any issues.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 08:24 AM #3
Oh that’s good to know! I see all these posts about people separating the tie rod end from the knuckle and unbolting the lower ball joint. Even the service manual doesn’t call for that.
Old 08-08-2020, 08:59 AM #4
BetterontheMtn BetterontheMtn is offline
BetterontheMtn is on a distinguished road
I happen to have a tie rod removal tool, so used that and had zero issue getting the shock/spring out without needing the extra jack. I had the truck supported on a jack stand and the hub hanging free. Going back together I found a 3 foot pry bar did the trick getting the bottom bolt lined up.
If nothing else, find Timmy's video in the thread stickied up top, I watch his videos before any job I've tackled so far.
BetterontheMtn is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 09:07 AM #5
itskohler's Avatar
itskohler's Avatar
It might have been easier to get back in if I disconnected all of that, but with a little patience and a pry bar I was able to get it back without issue. Definitely have a helper available to shove the bottom bolt in when its lined up.
Old 08-08-2020, 10:32 AM #6
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
You might be confusing folks disassembling/assembling the shock and spring in the vehicle vs just removing the shock and spring as a unit.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 11:19 AM #7
To clarify in all of my posts I am talking about removing the entire strut assembly as a unit.
Old 08-10-2020, 05:17 PM #8
As long as the swaybar is disconnected, you should be able to just use a pry bar to for the suspension arms down to get the shock assembly in/out. You put it above the top arm and below the pivot of the top arm and push down, shouldn't be too hard.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
front , jack , method , remove , strut
Easiest way to remove oil pan? cardana24 3rd gen T4Rs 24 01-23-2019 05:25 AM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
Easiest way to level front and do new front struts Ducman 4th Gen T4Rs 23 09-13-2011 12:59 PM
what is the easiest way to swap out front and rear diff gears?! 924runnerSR5 Classic T4Rs 40 04-20-2011 12:12 AM
front strut t4r4life 3rd gen T4Rs 4 02-09-2010 02:51 AM
