Old 08-10-2020, 12:38 PM #16
This is what I used in the past to push that sleeve back to allow the Alt to slide in.
Old 08-10-2020, 12:54 PM #17
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Originally Posted by Bad Luck View Post
Like 19963.4lsr5 said above, there is a slide on that pivot mounting point you are talking about that needs to be pried or hammered back to allow the alternator to squeeze in. It gets tightened back up when you tighten the bolt.
Yes, I can feel that slide. Unfortunately, it is absolutely frozen in place. No worries, however. I filed down the case at the pivot bolt point and it slipped right in. Battery is now being recharged and I'll know more later after I start the truck.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 02:14 PM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That slide should slide to properly align and clamp on the alternator. Hopefully tightening that bolt allowed the slide to clamp in enough.
gauges , oil , pressure , psi , register
Proper air pressure for Limited wheels??? iLLWiLL 4th Gen T4Rs 38 06-08-2019 12:27 AM
Proper Air Pressure for Off-Road Trails jdotlim 4th Gen T4Rs 9 06-07-2016 10:03 AM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
Proper tire pressure for 245/70/17 winters? Summit Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-28-2009 07:27 AM
Proper Tire Pressure Info Whoknows Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-18-2006 07:09 PM
