Old 08-08-2020, 03:26 PM #1
Biogenic Biogenic is offline
Biogenic is on a distinguished road
Compression test question
Does it make any difference if you take your plugs out completely or if you do it one at a time? I’m about to run one on my 3rz-fe.
From what I recall it doesn’t but i just want to double check. I’ll disconnect all the plug wires and ignition coils and I I’ll floor the throttle all the way down for 5 seconds
Anyone know what’s a healthy value?
Biogenic is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 04:21 PM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
They should all be out so the motor spins faster.
Motor should be warm.
FSM says 178 psi or more with a minimum of 127 and the difference between cylinders should be 14 psi or less.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 04:28 PM #3
And a good bigger battery charger on the battery while doing it helps also.
Old 08-08-2020, 06:41 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, all the spark plugs should be out when doing a compression test. You can lose cylinder pressure various ways, out a burned up intake or exhaust valve. Out a burned up intake or exhaust seat. It could be getting past the rings. It could be getting into a coolant channel via a bad head gasket or cracked head. And, it can leak into a neighboring cylinder via a bad head gasket or cracked head. With only one spark plug out at a time, you might be losing cylinder pressure to a neighboring cylinder and it will be more apparent there is an issue if you have that neighboring cylinder's spark plug out. It will basically make the compression more accurate and will identify a problem you will further investigate by doing a leak down test.
Old 08-08-2020, 08:24 PM #5
Spark plugs out ensures maximum starter rpm to ensure an accurate test. 250rpm sticks in my head, however, that’s many engines ago.
To do it right and be accurate a cold engine test with all spark plugs out and throttle held Wide Open and then repeat hot will tell you what you need to know. If there is a big difference between hot and cold you got problems.
Old 08-09-2020, 10:28 AM #6
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Do yourself a favor, download a FSM it's easy.
Complete 4Runner Service Manual 1996-2002.pdf - Google Drive
Page EM-3 covers test for 5VZ, procedure and numbers are the same for 3RZ, might dig for 3RZ version.
Manual will give you a direction to go based on results.
Old 08-09-2020, 11:47 AM #7
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Wide open throttle and disconnect the fuel pump!, fuel will give you false readings.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 10:51 PM #8
Well I already did what 19963.4 recommended. Cold engine, took all 4 plugs out, wide open throttle and got a reading of 200 on each. On a warm engine I got 225 on each.
Does the fuel pump discontinued make such a big difference?
Old 08-10-2020, 03:17 AM #9
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
those reading are fine. If your looking for a problem you can start looking else where. Plug readings are important they should be mostly white a little tan is ok on the porcelain section under the electrode. I am surprised that all your readings are all the same for each cylinder.
plcfcng is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 10:47 AM #10
Are you sure that gauge works properly?
Old 08-11-2020, 12:14 AM #11
Yup...was used not too long ago on another vehicle with totally different readings
Old 08-11-2020, 12:19 AM #12
I turned the engine over the same amount of time on each cylinder... 5 times
Old 08-11-2020, 01:48 AM #13
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
The readings are good I still don't know where your going with this other than just seeing the health of the engine.
Old 08-11-2020, 12:45 PM #14
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That is a very healthy engine! Has a lot of miles left in it.
326WHP 347TQ
Old 09-19-2020, 12:39 PM #15
Malcolm99's Avatar
Malcolm99's Avatar
Fuel in the cylinder would give you a false high reading for a compression test, and as you move from one cylinder to the next you will be dumping more and more fuel in the cylinders, you must disconnect the fuel pump when doing compression tests, but I'm sure your fine as the numbers are consistent which is the most important part..
disconnect , ignition , iphone , i’ll , plug
compression test and a leak down test cost? judoant 3rd gen T4Rs 23 05-24-2018 04:34 PM
5VZ-FE 3.4L V6 Compression Test mtbtim 3rd gen T4Rs 3 01-02-2018 04:29 PM
compression test question amalik 3rd gen T4Rs 9 05-27-2014 07:38 PM
How to run a compression test? a216vcti 3rd gen T4Rs 8 02-07-2014 07:14 AM
Supercharged Compression Test #'s / Question .bg. 3rd gen T4Rs 14 10-18-2013 11:34 AM
