Old 08-09-2020, 02:51 PM #16
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by snydmax View Post
CEL - “check engine light...” you won’t see any codes with an obd2 scanner unless this is on. I had no CEL initially, but it finally came on after idling for about 30 minutes es while we looked things over and then I drove it home, +/- 10 miles... the light came on before we made it to the house
Mine sounded terrible at idle, had no power, at “cruise” speed, no load, not on the throttle, it was less noticeable but I could definitely tell it was still misfiring.
The odor of fuel was also very prominent, easy to smell while the truck was idling and we were trying to diagnose... this was due to the fuel being dumped into the cylinder that was not being combusted as there was no spark.
I decided to stop and buy a set of plug wires and a coil on the way home that night, already had a set of plugs to put in, as it was getting late and wanted to see if it was something “easy.” Code confirmed my suspicion and we had her back on the road next morning.
I’d be very apprehensive to continue your journey with these symptoms, you could turn a minor repair into a major failure
Ah shit, I don't really know what else to do. I can stop and swap the coil to see if that's it
Old 08-09-2020, 02:56 PM #17
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Bad stuttering/sputtering under any load (Help, out of state)
P0300 and p0303 are misfire... if it were you I would hit up the next parts store you come across and start pulling plug wires, plugs, coils.
Time lost there will be made up quickly of you get the problem solved and can travel at full speed
I had an obviously meted plug wire boot
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 02:57 PM #18
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
You may cook your cat(s) with all that fuel dumping through the exhaust
Old 08-09-2020, 03:09 PM #19
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Finally got codes, still limping carefully. 450 miles to home
p0300 p0303
P0303... cylinder 3? Start there by checking coil/boot/plug. If your not smelling a fuel rich exhaust, could be an air/fuel/vacuum/injector issue rather than electrical
If your not misfiring on cylinder 4 as well, it’s more likely the boot or plug at cylinder 3... does that make sense?
Old 08-09-2020, 03:32 PM #20
Missfire detection is poor on our rigs. I had a bad coil on the 97 Puppy Hauler and she drove it 20 miles home from Reading PA with it shaking at intersections and having that off exhaust tone from dropped cylinders.
It was a bad coil and driving it from my house to my garage where I worked on my stuff it only shown a missfire code turning into the driveway 2 miles down the road.
You will melt your cat if you don’t solve this soon.
I’d buy a new coil and a new wire set that includes the coil boots and install the complete wire set and the coil for the cylinder that fires number 3 cylinder. It’s where I’d start.
Old 08-09-2020, 08:02 PM #21
jross20's Avatar
jross20's Avatar
Alright guys I swapped the coil pack for cylinder 3 and that seems to have fixed everything!!!
Woohoo!
Thank goodness! Big thanks to everyone who chimed in. As soon as I get home I'm ordering 3 OEM coils and an OEM injector (just for a backup) haha!
Old 08-09-2020, 08:56 PM #22
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Woohoo!
Awesome! Glad your back and running
Old 08-10-2020, 02:09 PM #23
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Pending codes can be in the ecm (and read with an appropriate scanner) without check engine light being on.
p0300 p0303
P0300- ENGINE MISFIRE DETECTED
P0303- CYLINDER #3 MISFIRE DETECTED
Cylinder #3 is the middle one on the passenger side of the engine. My bet would be a bad ignition coil. Higher engine rpm's generally have a stronger spark than lower engine rpm's.
EDIT: Late to the party. I didn't see there was a 2nd page for this thread lol I'm glad you got it figured out!
Old 08-11-2020, 04:02 PM #24
jross20's Avatar
jross20's Avatar
Yeah we are all good now, I've got three denso coil packs coming in today. Nipping this problem in the bud for another 20 years hopefully haha.
Probably going to order a spare injector just in case as well....
codes , fuel , home , load , miles
Stuttering and stalling Vooryjoni 3rd gen T4Rs 5 10-25-2019 07:48 AM
Sputtering / Misfiring in Neutral under load Misho 3rd gen T4Rs 5 10-12-2017 11:35 PM
Stuttering upon acceleration Jhacker1 Classic T4Rs 4 08-03-2012 03:08 PM
New 2011 T4R Engine Stuttering TroutBoy 5th gen T4Rs 4 11-17-2010 12:19 AM
Slight stuttering problem... crazeazn Problems & Warranty Issues 2 04-20-2006 08:35 AM
