Old 04-07-2021, 11:12 AM #16
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Maybe I missed it somewhere in the thread but, why did you go the way of cutting off the factory connector and then hard wiring the new head unit in? If the connector was cutoff by someone else or damaged, why not just get a new section of harness from a junkyard or a part out and splice that in? This just seems like the hard way to go about this.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 12:13 PM #17
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I agree, if you are just replacing the head unit, but keeping the stock JBL speakers, amp, subwoofer, etc. I’ve read that it’s possible to retain the rest of the JBL system with a new head unit, but then you’d still have a relatively crappy system. The stock speakers are junk, and the amp and head unit aren’t much better.
I did it because I used an external amp and wired the speakers from the amplifier. My head unit is basically just a pre-amp, with a tuner and cd player attached. I only used three of the fourteen (?) wires in the factory harness. I wired the remote amp turn-on myself.
Also, with my last head unit that is now 25+ years old, there wasn’t any other way to do it. It was a “dead head”, meaning it had no internal amplifier. It had no speaker outputs, just amp outputs. There was also no way to retain the steering wheel controls with the old head unit.
It was basically free to do it the way I did it. I just had to use some connectors and wire that I already owned. How much time, effort and money would it take to find a section of harness from a junkyard, functionality unknown, and then splice fourteen (?) wires?
In my opinion, the way I did it was the simplest. It wasn’t hard at all. I can’t put the stock JBL system back in now, but I am never going to do that. The JBL system is low quality compared to the system I now have.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 03:51 PM #18
Mudflaps's Avatar
Mudflaps Mudflaps is offline
Real Name: Chris
Mudflaps is on a distinguished road
Mudflaps's Avatar
Real Name: Chris
Thanks to all of you for the abundance of help and answers. I should have this knocked out in an hour or two.
Thanks everybody
*My clock still works*
Mudflaps is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 03:54 PM #19
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
In a nutshell, bought the truck used, can't find any comparable model year 4runners in the local junk yard with said plugs, the metra aftermarket replacement OEM plugs are not toyota color coded, so I had to translate the colors.
Old 04-13-2021, 08:03 PM #20
Tha Krazy One Tha Krazy One is offline
Tha Krazy One is on a distinguished road
Here is the color coding for 3rd gen audio. This is for the standard audio 4runners, not the factory amplified ones.
Stereo woes-toyota-audio-jpg
Tha Krazy One is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 02:25 PM #21
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
FINALLY, THANK YOU TO EVERYONE THAT HELPED.
FINALLY GOT THIS DEBACLE OF A STEREO INSTALL COMPLETED.
Seriously, I couldn't have done it without yall. I'll post pics as soon as I get my interior reassembled
Old 04-22-2021, 12:43 PM #22
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Glad you got it fixed! I hope it was worth it, my audio install was but I didn't touch the speaker wiring at all so was more just taking stuff apart and putting in sound deadening than having to goof with wiring harnesses.
326WHP 347TQ
aftermarket , antenna , find , power , stereo
ABS woes 4Rnr4Evr 4th Gen T4Rs 7 08-04-2016 11:58 AM
06 Limited stereo woes -- LCD issue 84ability 4th Gen T4Rs 5 08-04-2016 09:30 AM
WTB: Aftermarket Indash Stereo w/Nav (2003) (CAN TRADE MY CURRENT STEREO) 034RUNNER Want to Buy/Trade 1 01-19-2012 12:13 PM
Newer OEM stereo to replace 1998 stereo performance mp3 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-02-2010 07:22 AM
Best Buy Woes Slider Off Topic 18 10-04-2007 09:04 PM
