Old 08-09-2020, 03:24 PM #1
Mudflaps's Avatar
Mudflaps Mudflaps is offline
Real Name: Chris
Mudflaps is on a distinguished road
Mudflaps's Avatar
Real Name: Chris
Stereo woes
Hello
I'm taking the route of hard wiring (yeah, not my preferred method ) my Alpine KTP445A amp & my Alpine HD149BT stereo in my 2001 Limited. I have totally wired this thing to where it should be but I'm wondering now if this ever-so-vague "1987-up" s^@t that is all I can find is accurate or not. I wired everything properly and now I'm not getting ANYTHING from the aftermarket.
Can someone PLEASE FOR THE LOVE OF GOD give me a copy of a wiring diagram that is WITHOUT FAIL correct? I have the FM/CD/Cassette with factory amp.....
I have been trying and trying to google and search function an answer but everything I can find is confusing or inconclusive...Including what the hell I am supposed to do for my power antenna (do I wire the pink/blue with the black/white and tie it into the aftermarket "power antenna" wire?
HELP
*My clock still works*
Mudflaps is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 06:32 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I dont have a diagram but, did you remove the factory amp? My head unit wouldn't work with it and didnt have any sound but, once I took the amp out of the system, it worked fine
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 01:39 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Based on my memory of doing this install 7 years ago (in a 1997 4R), ^^this is true.
I remember working from the instructions provided by Crutchfield. They seemed good at the time, for my vehicle.
pluton is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 03:13 PM #4
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
Yes, I did that, and replaced it with the aftermarket in-dash amp. I tried the stereo without the amp in between it and the speaker wires as well to no avail.
Old 08-10-2020, 09:02 PM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Here is the 2002 EWD. Your 2001 should be the same.
http://www.teamtoyota4x4.org/archivi...mci/052rap.pdf
Describe your issue in more detail. No sign of power or it powers up but no sound? If no power ay all, check BOTH fuses ACC and DOME. Do NOT just look. Use a meter or swap in a known good one. Also check the fuses (in-line or built-in) on your new unit.
My Backyard Frame Swap
Old 08-10-2020, 11:30 PM #6
ambush ambush is offline
ambush will become famous soon enough
Alpine manual - PAGE 52
I am not sure where you are stuck. The install is straight forward if you got the aftermarket wiring harness. Please refer to ALPINE install manual starting on page 52:
http://support.alpine-usa.com/produc...HD149BT_EN.pdf
Everything else should fall in place. If not, please take pix of your wiring please
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 04:38 PM #7
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
Okay, I'm sorry to dig up an old post, but I still am stuck right where I was before. I'm really struggling here, NONE of the HUNDREDS of wiring diagrams I've seen correlate to the wiring in my truck. I'm baffled
All im trying to do is reconnect this factory plug set
Stereo woes-oemplug-jpg
The problem is, every single wiring diagram I've seen doesnt match. For instance, the wiring diagram above features a red and black wire. Mine does not. I don't know what to do about the "power antenna" wires......I'm just totally lost here. Can someone PLEASE help me out here?
This is the wire color scheme my truck has, which of course plugged into the factory amp which is removed.
Stereo woes-dumbwires-jpg
For what it's worth my factory toyota stereo was a 86120-0c040
Any body who can help me will have my undying gratitude.
Old 04-05-2021, 08:36 PM #8
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I'd skip the wiring diagrams.
See it for yourself and you'll know the truth.
So you are trying to re-use existing speaker wiring and power/ground, right?
If so, I would pull each speaker and see what color wires go to each, then connect those to the new amp. So here I am saying skip the connector, cut the correct two colors one speaker at a time and wire into amp.
Then with ignition in On position, I would use a voltmeter to figure out which wire is the hot and ground unless you want to wire those new from battery. If you go that route, use a fuse right at the battery on the hot, safety first.
The only wire left to connect now is the Signal wire, this one receives positive 12v when ignition is on only and signals to the amp to turn on, when you have ignition on and head unit turned on.
You will understand your radio wiring much better this way and can impress your friends.
That's it. Questions?
Old 04-05-2021, 09:08 PM #9
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
In the 2001 4Runner, the power wire is gray, the constant power wire is blue/yellow, the ground wire is brown, the remote amp turn on wire (added by me between the head unit and the amp) is blue, the illumination wire is violet and the dimmer wire is white/black. I found the color guide at my.prostreetonline.com.
In my car stereo, the amp is powered directly from the battery and grounded to the chassis.
I cut the connectors off the factory wiring harnesses and connected the wires I needed to my head unit individually. I only used four wires in my whole system that are “Toyota” wires.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 04:34 PM #10
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
OKAY, THIS IS THE INFORMATION I HAVE BEEN LOOKING FOR. YOU TWO ARE THE HEROES OF THE DAY. I'll be sure to be a good one and check back in with a field report.
Thanks guys.
Old 04-06-2021, 06:29 PM #11
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's how I helped my brother wire in his amp and head unit. We had no experience wiring a Honda but once you eliminate the 8 speaker wires, power, and ground the rest gets pretty easy.
326WHP 347TQ
Old 04-07-2021, 08:47 AM #12
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
Okay, All of this makes sense. Eliminating all the speaker and power/ground wires makes one at at time does make it easier. My only question is, as far as the power antenna (pink/blue & black/white) wires go, what do I do with them? or the other "toyota" wires....Are there any of the others that I need?
I've almost got this figured out
Old 04-07-2021, 10:24 AM #13
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
once you've ID'd everything you need, tested it and you know it works, then at a minimum tape off the unused leads. better is clip and tape off if you have lots of slack and no specialized connectors you care about trying to use later.
in terms of what you need, well i assume you need at least four speakers, gnd and two power leads. do you have a sub? test to be sure that sound comes from every speaker in relatively the same loudness. i don't mean twiddle the balance, but more like, if two are active and two are passive, you may have a wrench in the works. once you are satisfied with the sound coming out all of the speakers, and it works properly, tape off and bundle the unused leads. label them if you know what they are by that point in time. depending on how many you have left, stuff them in some wire loom or at least secure with a couple cable ties so they can be stowed back behind in that tangle of crap back there.
what to do with the antenna wire? that's up to you. do you listen to AM/FM? if so, connect it. if you don't, you may turn the unit on and the antenna automagically goes up and stays up. mine did, and so i connected the antenna wire temporarily so the antenna mast went down, then cleanly clipped and wrapped the antenna motor positive in the fender.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 10:32 AM #14
ads2539's Avatar
ads2539's Avatar
I don’t know from experience, but I would assume that if you have a power antenna and want it to go up and down, you should hook up the antenna wire. In my 4th gen, I just plugged the actual antenna into the back of my head unit, with a splitter of sorts to attach both antennas into the head unit.
I have never used the illumination/dimmer wire(s).
As far as I know, there are no more “Toyota” wires. I have a lot of wires not hooked up to anything, especially with all the stock speaker wires. Assuming the industry standard colors, I have only used the red, black, yellow and blue wires.
Old 04-07-2021, 11:07 AM #15
Simmer Simmer is offline
Simmer is on a distinguished road
I wired mine in and both the factory dimmer and the power antenna work just fine.
I need to actually pull my bezel off, I could pull my head unit out and take a few pics and check which wires were for antenna for you. If I recall correctly the antenna was orange and had a loop on one end. I also used metra block plugs both on the factory side and head unit side for what that's worth.
Simmer is offline   Reply With QuoteReply With Quote
aftermarket , antenna , find , power , stereo
ABS woes 4Rnr4Evr 4th Gen T4Rs 7 08-04-2016 11:58 AM
06 Limited stereo woes -- LCD issue 84ability 4th Gen T4Rs 5 08-04-2016 09:30 AM
WTB: Aftermarket Indash Stereo w/Nav (2003) (CAN TRADE MY CURRENT STEREO) 034RUNNER Want to Buy/Trade 1 01-19-2012 12:13 PM
Newer OEM stereo to replace 1998 stereo performance mp3 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-02-2010 07:22 AM
Best Buy Woes Slider Off Topic 18 10-04-2007 09:04 PM
