Old 08-09-2020, 06:47 PM #1
4runnerfever67 4runnerfever67 is offline
Real Name: Brad
4runnerfever67 is on a distinguished road
Real Name: Brad
Intermittent shaking
For a while now my 4runner has been shaking at high speeds starting at 65-70 mph intermittently. Sometimes it is worse and other times it seems like it barley shakes at all. When it does shake I notice that the transfer case shifter shakes alot and i can feel it through the pedal and wheel. My tires are like new and wheels should be good. What other components should i check for? Could wheel bearings, tie rods, or ball joints cause shaking like this? Seems odd to me. When driving and doing anything else below 65 mph it drives good.
2000 4runner limited, 3.4L engine, auto trans, 4WD multi-mode transfer case, rear diff lock, 17" wheels, 2" lift, 32" tires, 199mm Tundra Brakes.
4runnerfever67 is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 10:44 PM #2
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
LBJís... steering column... then other front end wear items
Mtbtim aka Timmy the toolman has a video on how to diagnose and DIY fix play in the steering column, if your brave enough!
I replaced many parts on the front end and finally it was getting rid of play in the steering column crash/slip joint that took care of the wobble/vibration
Replace your LBJís if you havenít just cuz itís easy and might just save your rig !
Steering Play Fix - YouTube
T4R noob... '98 4WD Limited, Warm Grey, 172k, Double Locked, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 11:51 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice Bad Luck is just really nice
Real Name: Patrick
I'd check front and rear upper and lower control arm bushings, steering rack bushings, and pull the rear drums off to check for oil leak from a rear axle seal failure. It wouldn't hurt to get your tires balanced either.
2000 Limited V6 Auto E-Locker
Old 08-10-2020, 04:14 PM #4
Mituk Mituk is offline
Mituk is on a distinguished road
great points in the previous posts, and I think they cover about all the possibilities - outside of the tires/wheels being in balance, comes down to any component that could develop play in the movement of the front end. That would definitely include:
- Ball joints - upper and lower(common)
- play in the tie rod ends(common)
- upper/lower control arm bushings(less common, but higher miles, likely)
- steering column(no personal experience there)
- Steering rack play - bushings could come be a factor here
- Alignment - usually not a source of a shake, but can make it worse
I'm having a hard time thinking of anything else . . .. so in other words, nothing new from the previous 2 posts. . . doh!
Good luck - highly recommend Timmy's youtube channel if you haven't checked it out.
Cheers
Dave
Mituk is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 04:38 PM #5
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Tires can still be a problem, don't rule that out.
'16 Honda Odyssey
good , mph , shakes , shaking , wheel
Help new and Shaking phili 3rd gen T4Rs 7 09-23-2014 07:00 PM
Shaking in 2wd ColoradoMTNlivin 3rd gen T4Rs 2 04-09-2014 01:02 PM
Shaking between 30-45 MPH - Please help!!! henduford 4th Gen T4Rs 5 03-19-2014 08:35 PM
Bad bad BAD shaking... Then it goes away. A.Wilson013 3rd gen T4Rs 48 03-18-2012 12:07 AM
shaking at 65-75 mph jamr1 3rd gen T4Rs 3 10-03-2008 07:40 PM
