Old 08-11-2020, 11:36 AM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Ignition key does not turn
The ignition key will SOMETIMES turn and SOMETIMES not. 1996 T4R, SR-5, V-6 automatic tranny. Shift lever in park. 195 K miles on vehicle. I assume that the key is worn down ? Amazon has cylinder and key for only $25, but is this one of those things that it is better to buy a new ignition lock from the stealer ?
How difficult is it to replace ? Special tools needed?
Also, I think I have a "dead short" in the tail light wiring system. The tail lights did not come on and I found a blown 10 amp fuse. I replaced that fuse and when I turned on the lights, it blew another fuse. "Dead short" somewhere ?
Thanks guys
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 12:27 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks guys
At the risk of sounding rude, have you tried searching on here about ignition cylinder replacement? https://www.google.com/search?newwin...4dUDCAw&uact=5
Old 08-11-2020, 12:51 PM #3
Thank you, Bad Luck. I guess I was looking in the wrong place. Your link was a big help.
Old 08-11-2020, 01:08 PM #4
Thanks guys
Start with removing/inspecting your trailer light wiring conveter. It should be found behind one of the rear interior quarter panels in the hatch area. (even OEM changed sides over the years - you'll just have to check both sides)
Replacements are cheap on etrailer.com if that is your problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-11-2020, 01:41 PM #5
Real Name: Patrick
Real Name: Patrick
You're welcome bud. I always use google to search the forum. I find that it pulls up more accurate results.
Old 08-11-2020, 07:31 PM #6
KamKoz KamKoz is offline
Real Name: Kameron
KamKoz is on a distinguished road
Real Name: Kameron
I had the same issue over the past year and a half. Randomly, I could not get the key to work in the cylinder, leaving me sitting in the car, trying to jiggle the key for a hour to get it started. I used some triflow lube as recommended by numerous online searches and at first it literally made things worse and I thought I had made the wrong decision. After some time of putting the key in, jiggling and removing, I ended up having a huge amount of metal shavings pull out into the the grooves of the key. At one point the entire length of the key was filled with these shavings and from there I kept cleaning it and reinserting. Since spending around an hour that day as stated above, I am issue free since and it is noticeably more smooth starting the vehicle. I know someone recently posted about this issue as well and how they used compressed air, wd40 and gun oil to solve their issue. When researching this issue, the main fix seemed to be getting a new key from the dealer but since mine was chipped and the dealer wanted something like $160 for a new key. It seems rare to need to replace the cylinder itself but I did encounter that on a few post when looking into this.
'99 4Runner Limited 4WD 3.4L @200k -- Imperial Jade Mica -- 265/75R16 Milestar Patagonia M/T. OME 881, LC coils/shocks -- ARB Rear Air Locker -- JBA Upper Control Arms
KamKoz is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 08:17 PM #7
HiLife HiLife is offline
Like phattyduck said it could be a bad trailer harness or trailer light converter.
Simple check I did when I went through that was, unplug the converter and harness. Then change the fuse. One by one plug the unplugged back and check the fuse. When the fuse blows you found your issue.
My issue was smashed and grounded trailer light harness which blew the trailer light converter. I had to replace both.
Old 08-12-2020, 03:13 PM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I cleaned mine with WD-40 and an Compress Airblower with a Basketball inflation Needle. Just spray some WD-40 with the straw, insert the key a few times, blow it out, repeat a few times. Now do the same thing with the key inserted and turned.
Finally lube with some Tri-Flo or Gun Lube and call it good.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
ignition , key , lock , stealer , turn
Ignition Key won't turn!! ToyDiehard 4th Gen T4Rs 27 11-11-2021 10:57 PM
My key won't turn in the ignition Tanner Maintenance/Detailing 18 02-05-2020 01:33 PM
'98 4Runner Ignition key won't turn Kennysmoke 3rd gen T4Rs 8 10-18-2019 07:37 PM
Ignition won't allow key to turn? mickeyt 3rd gen T4Rs 12 12-09-2017 01:58 PM
Ignition Key Will Not Turn Steve340 3rd gen T4Rs 7 01-02-2013 09:54 AM
