Old 08-11-2020, 02:16 PM #1
89T4runner's Avatar
89T4runner 89T4runner is offline
89T4runner is on a distinguished road
89T4runner's Avatar
1998 4runner steering question
Hi all!
So I have tried searching several times for someone with the same problem as mine but have come up with nothing so I figured I would start a thread and ask.
Awhile back my girlfriend purchased a 1998 4runner as her first vehicle. It already had some stuff done such as a full OME lift kit including OME shocks front and rear, 881s and 890 springs as well as those ebay blue uniball UCAs.
Now the thing I always notice when I drive it, is that the steering wheel is very easy (feels light) when turning left but very hard (feels heavy) when turning right. It drives me mad everytime I'm in it. When she got it, it hadn't been aligned after the lift, so I replaced the inner and outer tie rods and got it aligned hoping that would help but it didn't. Oh also I put new oem LBJs within a week of her getting it and it has poly steering rack bushings.
Any ideas on what could be causing those steering problems? Any suggestions would be very appreciated, thank you!
Sent from my SM-G965U using Tapatalk
1989 4runner 'Marilyn', 3.0 5 spd, ball joint spacers with KYB monomax, OME springs with 5100s, 33x12.5 duratracs, 4.88s, ARB fr, open rear, smittybilt fr, trailgear rr.
2000 4runner SR5 sport w/ elocker, Fox 2.0s fr, tundra 5100s with OME890 rr
89T4runner is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 04:23 PM #2
How does the steering feel when its up in the air? Any idea on the condition of the rack? (it almost sounds like the power steering valve is only opening in one direction) Was the alignment shop able to get all the specs 'green'?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-11-2020, 10:03 PM #3
89T4runner's Avatar
89T4runner's Avatar
I havent had it in the air and turned the wheel since I put in the tie rods but I believe it felt normal. Everything aligned perfectly in the green as well The main thing I can think of is the steering rack/fluid. The PS fluid is kinda nasty and I've been meaning to flush it. I think a rack replacement will be coming soon I just wanted to see if anyone has experienced anything like this before we drop the cash on an oem rack. Maybe flushing the fluid may unstick a valve? Should I try cleaning out the mesh filter in the reservoir?
Old 08-11-2020, 10:06 PM #4
itskohler's Avatar
itskohler itskohler is offline
itskohler is on a distinguished road
itskohler's Avatar
If there's power steering fluid in there you might want to do a fluid exchange and put ATF back in there.
98 Limited - 2010 Triumph Daytona - 2017 GTI
itskohler is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 08:50 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's worth a shot to flush it and clean the power steering reservoir. Recommended fluid is any Dexron III compatible transmission fluid. It sounds to me like a stuck valve as well which will likely require a rack replacement, but flushing before replacement will guarantee that a new rack (if required) will see nice new fluid rather than gunky burnt old fluid.
Old 08-12-2020, 12:39 PM #6
^^^ That sounds like a good plan. New fluid (full flush), clean the screen in the reservoir (get a new o-ring) and see what that gets you. Any normal ATF should be fine in the PS system. I use my old Dexron III stock and save the good/expensive stuff for the trans.
4runner , aligned , lift , ome , steering
WTB 1998 tan steering wheel 4XRNR Want to Buy/Trade 0 11-26-2017 04:08 AM
WTB Power Steering Line 1998 4runner Dous Want to Buy/Trade 0 05-22-2012 07:28 PM
WTB: 1998 T4R Parts - Steering Wheel, Cowl Seal Pmoney79 Want to Buy/Trade 0 07-05-2011 10:12 AM
