Old 08-12-2020, 06:05 PM #1
marshull marshull is offline
marshull is on a distinguished road
keep blowing alternator fuse
2002 4runner, SR5, 2 WD
Was having an issue where I was slowly losing power. The clock was diming, I began to lose acceleration, tach dropped to 0, then I heard a click like a circuit breaker popping then everything was fine. Took it to the parts shop and they tested battery and alternator. They said the battery was fine but the capacitor on the alternator was faulty. I put in a new alternator and as soon as I connected the positive cable to the battery, the alternator fuse popped. Went to the junkyard and cut out an alternator plug just in case there was an issue with the old plug (it didn't help that I snapped the connector off of the old plug). Used a wire brush to make sure all of the connectors were good and put in a new fuse. As soon as I connected the positive cable to the battery, there was a slight spark and the fuse blew again. I don't even get a chance to start the car or turn the key.
I am thinking that with the issue with the old alternator, it fried out a wire somewhere. I have no idea even where to begin testing the wire for breaks. Should I just buy a whole new wiring harness?
marshull is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 06:35 PM #2
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
this might be a long game of cat and mouse to troubleshoot. i had a bad alt once, and some of the same symptoms... loss of power, tach low, impending sense of doom. is your replacement alternator brand new? you hooked up the battery and immediately the fuse blew... with the engine off? or was that upon starting?
i doubt there's an issue with the heavy-gauge wiring that goes from the battery to the fusebox, but you might want to just check that out -- make sure it's tight. the alternator fuse... you're meaning the big one in the fuse box? 120A? that is a crapton of current, so something on the far side of that is drawing over that 120A, which is insane. is there anything new, recently installed? nearly any cable (2 ga or smaller) that's being asked to carry 120A is going to be fried. you might just get a bright light and shine it around near the alternator to see if there's any visible burned cable.
i'm suspecting a short (gee really) to ground, and that could well point to an issue with the alternator cable. with the battery positive cable disconnected, i'd check continuity and resistance between the battery positive cable and various points.
i realize this is a lot of shots in the dark, but it at least might help you isolate something.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 07:12 PM #3
Only thing new is the alternator. Well, new to me at least. Yes, the fuse is the pita bolted in one. The 120a. I connected the neg cable, then as soon as I touch the positive terminal to the positive pole on the battery, it sparks and I blow the fuse. Never get a chance to turn the key or start the car.
When I pulled out the old alternator, I noticed the bolt where you screw the wire to it was kind of fried looking and the insulation around the wire feels brittle. Like it cooked for a bit.
The neg is grounded to the frame right next to the battery, I unscrewed it and ran a wire brush on the spot of the frame and the bolt to make sure it had good contact. Guess I can give it the once over and make sure it really is grounding.
Old 08-13-2020, 08:18 PM #4
Well, I am at a loss. Everything is grounded fine. I don't see any wires that are showing any other issues.
Admittedly, I am not a serious car guy, much less an electrical guy. I know enough to get myself in trouble and thats about it. If it is mechanical, I just pull out the broken thing and put in a non-broken thing and that's about it. But I am confused. As I see the wiring, the positive connection on the battery has 2 wires. One is the thicker main cable and then a black smaller wire. The smaller heads into the fuse box. The white wire that comes out of the fuse box heads to the alternator. The 120amp fuse is in between the black wire coming from the battery and the white wire running to the alternator. So for the 120amp fuse to blow, more than 120amps has to be moving from the battery to the alternator. What in the world could be causing that without the alternator even running or the key even turned on? I am just really confused.
Old 08-13-2020, 08:46 PM #5
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Sounds like something in the new alt. is shorted out. Where’d you get it? Check carefully the copper stud on the new alternator, it could be touching the case somehow.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 10:15 PM #6
It is a rebuilt from ORielly. Is there a way to take it in and have them look at it and see if there is an issue? I guess I could pull it out and remove the cover to look it over for anything obvious.
Old 08-13-2020, 10:23 PM #7
HiLife HiLife is offline
Ha, depends on the counter guys there. All locations should have the alternator/starter tester. Seems like you have to twist their arm to do it.
Don't know why most just "dont have" the Toyota plugins as there are lots of toyotas on the road.
Old 08-14-2020, 01:10 AM #8
So I can just bring the alternator in? Thought they would have to test it on the car while it was running.
Old 08-14-2020, 01:26 AM #9
ambush ambush is offline
ambush will become famous soon enough
IT IS the ALTERNATOR
Hey electrical is funny on cars. I guarantee if you even decide to get a reman or another "new" one over the counter you will be changing it out again. I promise.
Go back to the junkyard and get an OEM one from a wrecked 4runner, Tacoma or Sienna! DENSO is the only one that will not give you problems. I PROMISE. Take that retail foolishness back.
Now if you want to really protect yourself after you reinstall, install your BIG 3 and fuse your ALTERNATOR to POWER as well..
this is what I did....
I added 150 AMP fuse just for my nerves. If if blows, it will hit that first before it hits the oem one in the fuse box.
PLEASE go OEM or if you can wait order one from Rockauto if you are going spend that type of $$
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 01:33 AM #10
They can do both. They have a hand held to test on a running car.
And they have a inside the store counter mounted machine that spins the alternator and tests the output.
If one location says they cant do it, just go to another location.
Hard to find a motivated enough counter guy to do the testing correctly.
Old 08-14-2020, 01:14 PM #11
Gonna second the other poster here. Oreilly rebuild? Junk. Make sure it is an OEM or Denso reman. ONLY.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-14-2020, 02:14 PM #12
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
To echo others, it sounds like the "new" item isn't good - the alternator. If it's instantly popping the fuse as soon as you touch the positive cable to the battery, with nothing on and the vehicle turned off, it sounds like an internal short somewhere within the alternator. One way to quickly rule out the wiring that you suspect is to completely disconnect (remove, even) the alternator, then reconnect the battery. If the fuse still blows, it's obviously not the alternator. If it doesn't blow, maybe you can find a schematic online for the alternator and use an ohmmeter to check for shorts internally.
thennen is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:02 PM #13
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
I am pretty certain that you must re-install the POSITIVE cable 1st and then the negative. Doing it the wrong way can fry certain sensitive electronics.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 11:06 PM #14
Turned out to be the alternator. I pulled it out and took it back into Oreilly for testing. The guy put it on the machine and it counted down 3-2-1 and fail. He scratched his head then checked the cables and hit test again. 3-2-1 fail. Got a "new" one and dropped it in and no problems. Going to have to agree that the Oreilly rebuilds are crap. Considering that the one that failed was a replacement for another that failed after a month which was a replacement for another that failed after 3 years.
Seriously looking at doing the "big 3". The post is pretty well laid out and seems to really future proof the engine/alternator. Guess I have my next project lined up.
Thank you everyone for your advice and help.
Old 08-15-2020, 01:32 AM #15
Glad you figured it out and didn't blow too many alt fuses.
Those fuses are expensive.
alternator , battery , fuse , plug , wire
New alternator blowing main fuse Superhero 4th Gen T4Rs 10 09-02-2019 07:41 PM
A/C fuse keeps blowing elderkin Classic T4Rs 2 08-30-2009 04:01 AM
Fuse Keeps Blowing Ken D Problems & Warranty Issues 5 01-23-2007 10:10 AM
blowing fuse nick4runner Classic T4Rs 0 05-16-2006 04:40 AM
The Fuse Keeps Blowing The E-Train Maintenance/Detailing 2 04-14-2006 04:48 AM
