Old 08-12-2020, 06:12 PM #1
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
[resolved] '99 rear wiper (only) not working
[edit: broken leads in the rear hatch wire loom. see my self-reply below.]
seems to be a well-covered issue per several searches across the various generations, but my symptom is more isolated than what i've found in the dozen+ threads i've gone through. thoughts and suggestions welcome.
  • it's a '99, and manual if that matters.
  • rear window wiper has worked in the fairly recent past (this calendar year)
  • rear wiper does not actuate at all in any steering column switch position (intermittent, on, burst) with key on ON (engine not running)
  • rear window does raise and lower via the dash rocker switch with key on ON.
  • washer fluid (rear) does work (key on ON)
  • rear defroster light turns on when i press the button. it's difficult to say whether it actually heats or not. it didn't become warm to the touch before it automatically turned off.
what i've tried so far:
  • did the window reset by lowering all the way, holding the button in for 1 sec (and also, separately 15 sec), then raising it and continuing to hold the button for 1 sec (also followed another suggestion for 15 sec)
  • window child lock switch is 'off' (not engaged). i did toggle it a few times
  • cleaned dust and dirt off the window itself and out of the track, having read that even the slightest limiting to its fully closed position results in problems, however since the fluid pump dispenses this suggests the window is closed sufficiently
  • removed the rear hatch trim, then separated the molexes and reattached them
  • removed the wire loom grommets (top and bottom) and peeled them back fairly far to inspect the leads (no visible damage)
any thoughts? thanks
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 10:06 PM #2
Real Name: Leif
Real Name: Leif
solved. thanks to @mtbtim 's vid about cracked leads in the rear hatch wire loom, i completed a two-part fix. i spliced six leads (three were entirely severed, and three more had cracked insulation and it was only a matter of time for them). i also had to replace the blown fuse caused by the fatigue-failed +12v lead bridging to GND. the fuse in question for my '99 is the #4 "MPX-B" 15A in the engine bay. it also controls the door locks, and thus it proved specifically diagnostic.
Last edited by photoleif; 10-25-2020 at 01:11 AM. Reason: clarification, add links
Old 10-25-2020, 03:30 PM #3
HiLife HiLife is offline
Thanks for posting back and following up with the fix.
rear , wiper , working
Rear wiper not working? Alphadawg 4th Gen T4Rs 6 11-01-2013 10:40 PM
Rear wiper not working Whips 4th Gen T4Rs 2 06-20-2012 10:16 AM
Rear wiper not working bobbyavidity 4th Gen T4Rs 9 04-16-2011 07:46 PM
2001 remote not working, rear wiper/defog not working theedudenator 3rd gen T4Rs 1 02-06-2011 01:10 AM
rear wiper not working 1990runner Classic T4Rs 3 12-20-2004 10:41 AM
