Old 08-14-2020, 01:29 PM #16
phattyduck phattyduck is online now
Originally Posted by plcfcng View Post
If you want to take it to a Dealer ship that's up to you steering racks are pretty straight forward job any good shop can do it. I would make sure the bushing get changed when they do it. It may need inner and outer Tie rods with that kind of mileage.
A new OEM rack comes with new inner tie rods and bushings.
Originally Posted by aontkos View Post
Why has this statement been ignored?! You guys are almost as bad as the original mechanic!
Assuming you have an automatic, this is a classic symptom of a cracked flex plate, which DOES NOT require an engine rebuild. I would inspect the flex plate and go from there.
At least two of us have already pointed that out.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 08-14-2020, 01:33 PM #17
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Well thanks Patty a steering rack is something I have not had to tackle on my Gen 3s. As far as the lifter stated before they are self adjusting they are not. They are a solid disk that when there is where to part of the valve train they need to be adjusted by exchanging the disk.
plcfcng is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 01:47 PM #18
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
A new OEM rack will come with the two bushings which are mounted in the rack, but you need to buy the "Gear Assembly Insulator" part number 45517-35010 separately as it does not come with the rack. It doesn't need to be replaced with the rack, but it's much simpler to replace it as preventative maintenance than to need to replace it later.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 02:02 PM #19
Checked my pics - yeah, looks like it. I swapped over poly bushings when I did my rack a few years back...
Old 08-14-2020, 02:14 PM #20
When I bought my new OEM rack, I needed to buy that piece as a separate item. I know that at least the energy suspension poly steering rack set comes with that piece which was the way I decided to go since the entire poly rack set cost less than just that one piece from a dealer.
Old 08-14-2020, 05:27 PM #21
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by Doc3g View Post
I inquired about fixing the steering and or replacing the engine and he pretty much told me he doesn't want anything to do with it and that it is time to "close the hood on it" because putting an engine in it is just going to lead to a whole bunch of other problems.
Basically he's saying that he doesn't see himself making more money from you so he would rather work on other peoples' cars. LOL what a dick.
Old 08-15-2020, 01:43 AM #22
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Originally Posted by ArmArak View Post
Or just do a v8 swap and call it a mod!
I've seen some videos of them, but it's out of my league skill-wise even if I had the time, though if I could find a reputable person to do it I would definitely consider it.
Originally Posted by Toyotadirtdevil View Post
A friend of mine just had his engine replaced by Yota1 in California and it was close to $7 grand. Now he also replaced all the hoses, alternator, and a lot of other stuff.
That seems really steep. I see crate motors for a couple of grand and I can't believe that there is $5k in labor involved? I guess I was expecting to pay around $5K with the motor and labor.
Originally Posted by Devbot View Post
A bad steering rack means it's "time to close the hood on it"??
What a crock of shit
I'd take it to someone else. The steering racks on these rigs do tend to leak with age (like the majority of cars) but it's NOT the end of the world, provided it isn't something else, like your valve covers which are much more common. My rack was replaced around the 200k mark, personally. Though the knocking is interesting - you should take a video and post it here when you get the car back
Even if it IS your engine knocking, and it was at the end of it's life, 5VZ crate motors were pretty cheap last I checked
I'll try to make a video and post it tomorrow, thanks for the idea.
Originally Posted by ambush View Post
RIGHT!
i have 577k miles on mine and it runnnnns im telling you like a top.
The knocking could be the lifters out of spec or like it was mentioned, flex plate. They are self adjusting lifters if i remember correctly so manually doing it would be $$$. just change your oil and go with with SHELL T series 10W30 Syn blend and let it ride!
Someone else has mentioned changing the oil weight as well. Does someone mind giving me the cliff notes version of what changing the oil weight would have to do with a knock?
I appreciate the replies from everyone, I'm going to try to call Duggy's on Monday and see if they will have a look at it.
Also, I'm not sure if these symptoms will hint at anything but every once in a great while (I think it has happened twice in 4 years), if I really get on the gas and run through the gears and then pull up to a stop, the truck will stall. It starts back up but runs like an old carbureted car that is flooded for 20-30 seconds and then it is fine again.
The other thing is that if you are on really on the gas accelerating (like when merging on the highway) there is a bit of a cyclical surge in power that comes and goes in 2-4 seconds intervals. It feels like hitting the power band on a dirt bike, where you have a little extra "boost" for about 3 seconds and then it goes away for about the same duration and then repeats this cycle.
Doc3g is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 11:10 PM #23
ambush ambush is offline
ambush will become famous soon enough
So the weight change helps coat the lifters/cams/pistons etc. When an engine wears, it rubs cylinder walls and is just out of spec than what it was from when it was new from the factory. There could be different reasons (location of vehicle, ownership maint., etc.). Anyone please jump in to add or subtract.
Now your knock as mentioned before could be the FLEXPLATE. Please check that. If it is not, then as mentioned change the weight of the oil.
Again, I literally changed my oil last week using SHELL Rotella 10W30 in my high high mileage truck + FRAM oil filter. It DOES NOT KNOCK or smoke. It was maint. well by the previous owner. I crank and now I go! No lie.
As far as your acceleration, it may be the same as mine. Check your CAT. It could be clogged with NO check engine light. Mine had zero lights. You saw my pics of the CAT??? it was 100% clogged and I had zero acceleration as I tried to change lanes or pass up hill. A clogged cat can RUIN and engine in the long run.
I hope this helps!
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 01:17 AM #24
OK, thanks for the tips. I'll have to find a post on how to check the flex plate and let you know what I find out. Here is a video I just made of the sound. It is actually more audible in the cab than it comes off as in the video, so you need to listen rather intently to hear it. I then put the parking brake on and recorded underneath and on both sides of the engine from the top. Definitely seems to be more from the passenger side. Afterwards, I put it in neutral and recorded again and you can see the knock goes away.
Another interesting thing is that the knock is RPM-dependent, as it definitely speeds up when you increase the RPMs.
https://www.youtube.com/watch?v=5tJa...ature=youtu.be
Old 08-16-2020, 11:18 AM #25
AvatarT4R AvatarT4R is offline
Real Name: Jaime
AvatarT4R is on a distinguished road
Real Name: Jaime
Pretty sure the guy is saying he doesn't want to swap a motor out, which a fair amount of mechanics don't do these days. Kind of like finding a paint shop to do an entire repaint....many wont do it. Both claim there isn't enough money in it for the effort.
AvatarT4R is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 12:32 PM #26
T4R2014's Avatar
T4R2014's Avatar
Sure, but at least quote what you think would make the job worth it. If he walks away then fine. Everyone has a price. Saying "I don't want anything to do with it" over a motor swap on a relatively simple vehicle points me to two thoughts: 1. he knows OP won't spend what he wants to get for that job, or 2. He is a jiffy lube monkey at best.
Old 08-17-2020, 12:23 AM #27
Does anyone have any thoughts on the sound in the video? Does this sound like what a flexplate typically does?
