Old 08-13-2020, 07:51 PM #1
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
How fast does the radiator fan spin?
Hey guys I am almost done rebuilding my york 210 compressor. It is an engine driven compressor so I have to run a pulley out of the engine somehow. I originally planned on putting a pulley behind the fan. My question is:
What is the ratio between engine speed and fan speed?
Once I have this I can figure out the pulley ratios.
Thanks!
ArmArak is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 07:58 PM #2
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
why not just measure the fan pully it's about 5 inch from what I remember.
plcfcng is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 08:36 PM #3
ArmArak's Avatar
ArmArak's Avatar
Ya I'll measure the fan pulley to figure out what size pulley I need on the other end. But I need to know the speed because I want to tune it so that when my engine rpm 700 so is the compressors.
Old 08-13-2020, 08:50 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Measure the crank pulley and the fan pulley and that will tell you the ratio.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 09:57 PM #5
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
Alumarine is right measure the crankshaft pulley. This your Compressor is a super charger or A/C. The Super Charger pulleys I have see look smaller than the water pump pulley so this could be difficult. I think the manufacture should have some suggestions.
Old 08-13-2020, 10:35 PM #6
ArmArak's Avatar
ArmArak's Avatar
It's the AC compressor off a 1960's mustang. Im converting it to use for on board air. Maybe I can weld on another pulley to the crankshaft pulley. Then I can connect that extra on to the compressor.
IDK that was just a thought. Any ideas?
Old 08-14-2020, 10:00 AM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Pretty sure if you try welding to the stock Crankshaft Pulley aka Harmonic Balancer the heat will likely compromise the rubber middle section and the thing could fly apart. There are aftermarket solid pulleys, URD SuperGrip Crankshaft Pulley for 3.4L Toyota Trucks - Underdog Racing DevelopmentUnderdog Racing Development / URD - Aftermarket Performance Parts & Accessories for Toyota Trucks[/url] but those are aluminum and I don't know if that can be done.
My Backyard Frame Swap
Old 08-14-2020, 10:10 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You're likely to throw a pulley out of balance by welding anything onto it. It's also going to be really difficult to get anything you want to weld onto a pulley perfectly centered. You'd be better off trying to line up the compressor with one of the belts that are already there and then get a longer belt.
Old 08-14-2020, 11:54 AM #9
ArmArak's Avatar
ArmArak's Avatar
That sounds like a good idea. I'll go and dig around to see what I can make work today.
Thanks!
compressor , engine , fan , pulley , speed
360' spin, I was very lucky. peter78 General Discussions 28 05-14-2020 08:18 PM
Oil Viscosity / How Fast Is Fast? DreamsOfDirt 5th gen T4Rs 8 09-08-2019 07:35 PM
Took her out for a spin tonight diaz7412 3rd gen T4Rs 3 05-14-2018 12:36 PM
A spin on DRL disable... LINY4Runner 3rd gen T4Rs 21 06-20-2013 11:10 AM
Front shafts spin in 2WD? 4R_in_Uzb Problems & Warranty Issues 7 09-22-2007 01:43 PM
