Old 08-14-2020, 07:33 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Is it time to replace the thermostat?
My T4R will be 24 years old in October. It has 178k miles. To the best of my knowledge the thermostat has never been changed. Should I have it replaced?
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 08:14 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
as long as it's still functioning I would leave it alone.
if the radiator is still original I would replace it.
there are some other items on these truck that tend to cause issues after 20+ years. lower ball joints, radiator, rear axle seals.
almost anybody can do a radiator replacement, it's super easy. protects you from overheating and doing engine damage.
2,Cents
Old 08-14-2020, 08:23 PM #3
Satter's Avatar
Satter's Avatar
2,Cents
Thanks! Actually my radiator cracked over a year ago and was replaced. Gotta timing belt change too. The stealership said the water pump was fine and didn’t need replacing. I know the old saying “if it’s not broke don’t fix it”. But this truck is old and I’m just trying to stay ahead of things.
Old 08-14-2020, 08:27 PM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
and it seems like once you touch it then the water pump will leak.
I know what you mean on therm and I remember driving older trucks like chev, ford where therms went bad. I have never seen a toyota one go bad in the 25 years of driving these trucks. maybe other have seen them fail but it seems like a bullet proof part to me.
drive it and love it.
Old 08-14-2020, 09:55 PM #5
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
I looked into replacing my thermostat and I discovered, to my displeasure, that it is one hell of a big job. At least according to Haynes Repair Manual, you would have to remove the radiator and most of the front part of the engine, including the timing belt.
As for me, I'm going to let sleeping dogs lay.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 09:59 PM #6
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
That's for the water pump. Thermostat you just have to drain the coolant and remove 3 nuts on the thermostat neck and it's right there.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:08 PM #7
Oops. Yep, you're right. I looked up oil pump and thermostat on the same day and I got confused. Sorry.
Old 08-14-2020, 10:36 PM #8
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
I concur
cashflow50 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 12:11 PM #9
Satter's Avatar
Satter's Avatar
Well, Scotty Kilmer’s latest video got me thinking about me thermostat. That’s why made the thread.
Car Dealership Scam Caught on Camera, You Won't Believe This - YouTube
Old 08-15-2020, 02:01 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The 2nd Gens with the 22RE and 3VZ-E engines has issues with thermostats. The 5VZ-FE's are solid and you shouldn't have to mess with it. It's a wax activated system where the wax becomes more pliable when hot, it's pretty fool-proof and reliable.
326WHP 347TQ
178k , changed , knowledge , miles , thermostat
How to and replace thermostat in 5th gen v6? mountainair26 5th gen T4Rs 8 10-21-2022 10:24 AM
How often do you replace the thermostat? Satter 3rd gen T4Rs 5 06-24-2020 06:03 PM
How Do I Replace a Thermostat on the V6? fdbyrne 4th Gen T4Rs 12 12-05-2017 01:53 AM
Is thermostat hard to replace? Atreyus 3rd gen T4Rs 29 04-20-2016 07:53 PM
Thermostat Housing Leaking After Rad Replace Dirt Sailor 3rd gen T4Rs 5 08-30-2015 09:49 PM
