Old 08-14-2020, 08:17 PM #1
swampycu swampycu is offline
swampycu is on a distinguished road
Weird problem with my 4runner
So, I have a 96 4runner that I have owned for about 5 years now and it has really given me no problems up until now other than a head gasket leak I fixed about a year ago. its only got 184k miles, so not even crazy high mileage. I have also scoured this site and others and cannot find anyone describe exactly what I got wrong.
The problem: the car randomly dies while running and occasionally will not start. If it wont start, it turns over, just won't fire. The fuel pump seems to be running as I can hear the faint whine. when it dies, there is no warning and no unusual driving conditions. Sometimes it will run for an hour with no issues, other times in dies within 15 minutes. It also never throws a CEL code.
What I have replaced so far:
Vapor canister
fuel pump and strainer
fuel filter
Throttle position sensor
Mass air flow sensor
Idle air control valve
I have also looked for loose wires and cannot find any
At this point I have no idea what to try next. Part of my problem is that it does not seem to be consistent. As an example, I ran it for an hour yesterday, started it multiple times and ran it around the neighborhood - no problem... I go out today and it sputters and dies immediately, then after a few tries it starts and runs for about 5 minutes then dies and will not start back...
Any advice is greatly appreciated.
Thanks
Brian
1996 4runner... 33in tires, sonoran steel lift, arb front, winch, skid plates, sliders, and manual hubs
swampycu is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 08:43 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Vapor canister
fuel filter
Thanks
Brian
It's not throwing a CEL, but have you actually hooked it up to a scanner and tried to pull codes? You should be able to pull pending codes as well even if it hasn't actually thrown a CEL yet.
Do you know what the age of your plugs, plug wires, and ignition coils is? Not saying that is the problem since I would think it would take more than a bad plug to cause the engine to shutdown, but it would be good to rule those out.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 09:00 PM #3
Yes, I have a scanner and have hooked it up multiple times. No codes saved in the system.
The plugs are not too old as I have replaced them since owning it and really haven't put many miles on it in since. I am not sure about the coils. My thought was that if it were these, it should be throwing a code. Is this correct?
Old 08-14-2020, 10:49 PM #4
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Somethings gotta be loose. Just a thought. My cousin has a 00 TR4 that he brought to my house one day and after an hour or so of parked, he went to start the car. Couldn’t start at first. He tried firing it up and finally started. After a minute or so it sputtered and died. He said his battery cables were loose. I thought to myself how can cables be related to engine dying. Sure nuff I took him to O’Reillys and bought new battery connectors along with a new battery. The problem was that the post circumference on his battery was too small for the connector. Installed and wallah she’s alive again. Not saying it’s the same problem but worth checking if they are nice and tight
cashflow50 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 01:21 AM #5
HiLife HiLife is offline
Next time it just turns over and over and doesn't want to fire, have a partner/friend spray engine starting fluid in the intake.
If it fires right up, you know where to look next.
Old 08-15-2020, 07:20 PM #6
nissanh nissanh is offline
A car stalling without a code is most likely is your fuel pump. Do what "hiLife" said above. You can also listen for the pump when it stall next time.
Old 08-15-2020, 07:30 PM #7
cashflow50's Avatar
cashflow50's Avatar
He mentioned that he already replaced the fuel pump and strainer. How long ago don’t know, but he did say he changed it
Old 08-15-2020, 08:32 PM #8
thanks for the replies.
All the parts listed above have been replaced since this issue started 2 months ago and I have driven the truck ~10 miles since then. Its been a long process of buying a couple parts, waiting for them to come in, figuring out a time to work on it, replacing them, seeing that it doesn't fix the problem and try to figure out a next step.
I thought it was the fuel pump too, but the problem didn't change after replacing it. Friday when it wouldn't start after my latest round of parts, I could hear the whine of the fuel pump while it was turning over. I worried it might be the wires in the tank, but when I replaced the pump, they looked good with no corrosion. my next step was going to be to drop the tank again and replace those wires, but after hearing the pump working and no firing, I dont think thats it.
I have checked the battery connection and they are tight, but I do have some corrosion. maybe that's causing issues?? ill try taking those connections off tomorrow, cleaning it up real good and see if it makes a difference. I think the battery itself is good as it never has a problem turning over the truck no matter how long i try to get it started.
In the back of my mind, I am worried I have some intermittent wiring issue, and that feels like an impossible thing to track down.
Old 08-25-2020, 08:17 PM #9
pelantire pelantire is offline
pelantire is on a distinguished road
Have you cleaned the grounds to the motor block? Fuse box grounds?
pelantire is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 08:15 AM #10
billyblunk3 billyblunk3 is offline
billyblunk3 is on a distinguished road
Did you change the fuel pump with an OEM one? I had a shop change mine about 4 years ago and they used aftermarket which gave me constant problems like you are describing. Ended up needing fuel pump and sending unit from Toyota. Not to mention they hooked lines up backwards to my evap canister flooding it.
billyblunk3 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 08:48 AM #11
Coondog#1 Coondog#1 is offline
Coondog#1 is on a distinguished road
I have a 96 that would randomly die. Had a missfire code. P3000 or something. Eventually pulled the ECU and popped it open and some of the capacitors were busted and leaked into the board. Did some research and it was a problem in older Lexus cars mainly. Replaced the capacitors and resistors I think they were called. soldered them in and cleaned board with alcohol. Hasn't missed a beat in 3 years. I've read about it in other 96s too.. Worth a shot.keep us posted
Coondog#1 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 12:40 PM #12
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Agree with this. Clean all grounds and ground wires with rubbing alcohol and give those battery terminals a nice baking soda bath to break down that battery acid. By the way, if your battery is leaking acid it's about to fail.
The grounds to clean are: battery to fender ground, passenger's side cylinder head to ground (may also be on the upper intake plenum), engine diagnostic port to intake plenum ground strap (this one gets really dirty) and if you can do it, ECU to ground.
The sensors that can cause the engine to stall are: Idle Air Control valve, Mass Airflow Sensor, Crankshaft Position Sensor and Camshaft Position Sensor. Not saying you have to replace these but hoping it helps in your search after cleaning the grounds.
326WHP 347TQ
Old 08-27-2020, 05:27 PM #13
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
As gamefreak mentioned, check your grounds, especially the ones to the ECU. Usually if engine turns off suddenly, without warning it may be an electrical problem, possibly due to rust.
It happened to me and my dad while driving on the I95 near Boston one day to work.
It turned out to be a rusted ground wire that broke off! They dont call it a rust belt for nothing!
Here are the diagrams for 3RZ and 5VZ engines. I didn't see which one you have, but check the points with the triangles.
Weird problem with my 4runner-3rzfe-ground-points-jpg  Weird problem with my 4runner-5vzfe-ground-points-jpg
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading.
1000kms range w/ subtank
pavelvoivoda is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 10:58 AM #14
762NATO 762NATO is offline
762NATO is on a distinguished road
Any updates - did you ever solve your starting issue?
762NATO is offline   Reply With QuoteReply With Quote
air , dies , fuel , problem , start
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
Weird problem, help please. Aileron 4th Gen T4Rs 6 10-29-2015 04:53 PM
Weird Problem Champ1415 3rd gen T4Rs 4 05-21-2012 12:29 PM
Weird AC Problem 4running1990 Classic T4Rs 7 08-18-2010 11:30 AM
weird problem...help please Michael Problems & Warranty Issues 3 11-18-2003 08:00 PM
