Old 08-15-2020, 12:16 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Where are the jack points?
Where are the jack points for 3rd gen T4Rs? I searched but only found threads for 5th gen 4Rs. If anyone has pics please post them. Thanks so much.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 12:20 PM #2
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
midcoma is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 12:39 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Find a solid spot and call it good.
Old 08-15-2020, 01:59 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If you are lifting just one front tire, the lower control arms also work. Just be aware and careful of the lower ball joint bolts. For the rear tires, the differential is the easiest spot and lifts both at once.
326WHP 347TQ
Old 08-19-2020, 11:37 AM #5
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Pretty sure you can lift anywhere on the frame I think.
Old 08-19-2020, 06:59 PM #6
nathanroyse nathanroyse is offline
nathanroyse is on a distinguished road
I just lift mine from anywhere on the frame or the middle of the rear axle
nathanroyse is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 11:06 PM #7
TimGFL TimGFL is offline
TimGFL is on a distinguished road
If I recall correctly, the frame on my 1996 has little arrows notched into it where the lift points are.
TimGFL is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 02:05 AM #8
tersch tersch is offline
tersch is on a distinguished road
Ohhh that's what those are! I was poking around underneath yesterday and noticed 5-6 notches in the frame on each side. Didn't know what they were.
tersch is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 02:58 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Anyone have photos of these arrows?? I am curious as I never saw those on any of my frames. ( probably because of rust)
Old 09-06-2020, 10:43 PM #10
biggestmexi biggestmexi is offline
biggestmexi is on a distinguished road
Is my jack a baby jack or something because it barely reaches the frame. I have a regular aluminum 3 ton jack but barely lifts if hitting the frame.
biggestmexi is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 11:26 PM #11
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
There is no such thing as a "regular" jack. Are you saying that your jack is almost fully extended when it reaches the frame? If so you probably have a low profile jack or just a jack with a low lift height. If it's an older jack, and it won't go any higher, but it doesn't seem to be mechanically limited it could just be low on hydraulic fluid.
Skulking is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 07:52 PM #12
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
the only arrows I have ever seen are the ones on the plastic cover on the drivers side. covers up the shift linkages and fuel filter area. does a great job of keeping salt/junk out of there. is a pain to put back on when doing maintenance so I'm guessing they just get tossed most of the time.
Old 09-08-2020, 10:44 AM #13
HappyHooligan's Avatar
HappyHooligan HappyHooligan is offline
HappyHooligan is on a distinguished road
Originally Posted by midcoma View Post
What if my truck is carrying some extra eight? What do I do?
_________________
2000 Sport
2882/5100 906/5100
HappyHooligan is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 03:08 PM #14
Why would the recommendations change?
If I'm jacking up the front on mine (aftermarket skid plates), I use a slightly different position... but otherwise everything else is the same.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-08-2020, 04:24 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok.. I never saw the jack arrows. Those points are standard frame jacking points.
As your 4 tires are the contact points for the vehicle weight distribution when driving down the road.
You can see that the Jack points are near the axles.
gen , jack , pics , points , post
1990 4Runner Jack Points jay333 Classic T4Rs 3 03-11-2020 07:20 PM
Where are the best floor jack points on our 4Runner? sant6236 4th Gen T4Rs 24 03-17-2019 01:00 PM
new to DIY... jack points for front? amalik 3rd gen T4Rs 6 10-03-2013 10:26 AM
high lift jack points on 0'3 alex56 4th Gen T4Rs 4 01-09-2011 09:33 PM
Proper jack points for garage jack? ciaz 5th gen T4Rs 3 02-01-2010 03:14 PM
