08-15-2020, 11:29 PM
What to take from 1999 Toyota Camry
Hey guys,
My grandpas Camry with over 400k miles finally gave out. He’s taking it to a scrap yard so is there anything useful for my 2001 4Runner I can scavenge before it goes?
08-16-2020, 02:34 PM
Originally Posted by brillo_76
Camry's are a completely different chassis and engine lines. As far as I know nothing is compatible between the 2 vehicles.
The 4 runner and the Tacoma have some similarities. Engines and frames along with engine skids etc..
Some of the ignition coils may be the same. Many relays, flashers, bulbs, switches, should work too.
Steering wheel maybe?
08-16-2020, 02:41 PM
Dont know about compatibility. Electrical stuff light bulbs wire harness, relays, fuses, fuse box, hvac hoses. battery cable connectors, wires can be useful or improvisable. .
edit; nuts and bolts
08-16-2020, 03:05 PM
Good idea about the switches. Maybe I can use some to wire in some auxilary lights, my compressor, or something else.
08-16-2020, 03:33 PM
nuts, bolts, expensive plastic clips, ECU might be money, if it has a fog switch on the turn stalk, many turn stocks are compatible with other models and manufacturers.
08-16-2020, 04:05 PM
door lock actuators, console box lid hinges, window switches
matching set of all door locks, and the ignition lock with keys goes for $200 on ebay
1999 used Camry parts
https://www.ebay.com/sch/i.html?_fro...0&rt=nc&_pgn=1
08-16-2020, 07:14 PM
As others have said nuts and bolts. Unless you already have a big bin of metric nuts and bolts its almost a necessity when it comes to fixing older vehicle. Unless you live right next to a parts place which a lot of us do not
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
08-16-2020, 07:28 PM
Some of the camrys have a nice negative battery terminal to match the 4Runner positive. Nice to have if you ever replace or upgrade the negative cables.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
08-17-2020, 11:47 AM
Real Name: 3 Bears
Real Name: 3 Bears
I assume its running good, if thats the case grab all ecm's computer stuff...wont fit the 4 runner but could resell on fleabay.
relays, fuses nuts and bolts. Its always good to have spares of those around.
I would look around on fleabay and see what else sells good. I know one hassle for me for my 4runner was finding good driver side seat belt
08-17-2020, 02:34 PM
Real Name: Jon
Real Name: Jon
Mostly you can always buy new seat belts from Toyota OEM...
Great thoughts on the other things. I figured the OP only wanted compatible parts.
08-17-2020, 02:41 PM
Real Name: 3 Bears
Real Name: 3 Bears
yep...$$$$$$
08-17-2020, 05:21 PM
Rear seat/back, set em' on the back porch....
