Old 08-17-2020, 12:12 AM #16
ambush ambush is offline
ambush will become famous soon enough
Originally Posted by Traveler74 View Post
No, not yet. I did buy a new oil pressure sensor sending unit and a large 24mm socket to remove the old one and install the new one. I'm on limited retirement money and I must buy things in stages.
Currently, I'm chasing a problem with the engine stalling at normal hot idle speed.
Looking for any possible vacuum leaks. Right this minute, the ****ing truck will NOT run if I take my foot off the gas pedal. Until I can fix that problem, everything else must wait.
Please, have patience with an old man who knows next to nothing about auto mechanics
An engine needs 3 things: Fire, Air, and Gas. Check to make sure your plugs/wires are getting fire then check your MAF sensor and throttle body (use cleaners), then last but not least your FUEL filter.
My bet right now, MAF or Throttle then throw this in the mix, fuel filter clogged.
Do a smoke test. Get a cigar and blow its smoke into the throttle. As you give it gas have someone or you look into the engine to see where it could be leaking (smoke).
I hope this helps!
PS:
Check your AIR filter!! If that is DIRTY or clogged, I bet it can cause it shut down too..
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 12:21 AM #17
About the flush...
I have never been one for flushes unless it is for a radiator that is clogged. Dealers love to offer that service (high powered flush) to unknowing car owners and in the long run it is a cash cow when the there are issues with either the engine or transmission.
To be honest, our trucks should not need a flush. Just more frequent drain and fill. As mentioned above, Rotella Synthetic Blend is AWESOME.
Drain and fill. Use a good oil filter (Fram, Bosch, OEM Toyota, Purlator, K&N, etc.).
Old 08-17-2020, 01:34 AM #18
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
It’s all good. We’re friends here, just want to see you get it sorted.
We all have growing pains with new vehicles and most turn out ok.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 09:29 AM #19
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
I hope this helps!
PS:
I put a new air filter in and cleaned the MAF with CRC MAF cleaner. The only thing which seems to make sense right now is a dirty throttle body and/or the IAC. Truck starts right up but when it gets warmed up, THAT is when it shudders and stalls.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 11:02 AM #20
Well we are here to help. Keep messing and let us know what changes you see or dont see.
Old 08-17-2020, 02:25 PM #21
Thank you, Ambush. I appreciate it. Half the time, when I'm working on the truck , I feel I'm in over my head, but I'm learning … SLOWLY !
I still have not located the grounding point for the alternator. I haven't the vaguest idea of where to look. OR is the alternator grounding point the engine block ???
Old 08-17-2020, 02:29 PM #22
Best place to ground alternator is to the BODY of the truck. Clean area of paint and locate it there. Check my pix as I have done the BIG 3 upgrade.
Old 08-18-2020, 04:03 PM #23
Kanoe's Avatar
Kanoe's Avatar
You've got it. The alternator grounds to the engine through it's mounting hardware. There is no special or separate ground on the alternator.
-2001 Echo D.D.
Old 08-18-2020, 04:12 PM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Devbot View Post
I constantly run a quart of MMO at all times, put in about 4qt of Rotella T6 and 1qt of Marvel. According to Marvel themselves it should cut the 5w40 to roughly that of 5w30 in that amount (believe it also says so on the back of the bottle how to calculate it). My initial reason for doing so was to help clean out some cooked oil in my valvetrain and generally clean out the system, and it's worked pretty well for it but it did take a 1-2 full OCI's to see any change.
Some people also use Gumout Multi-System in the oil but I've yet to do so. I believe it's only something like 1oz per 1qt or something real minuscule so I haven't tried it in that sense, but it does make a great fuel cleaner so maybe worth a shot.
You're only using 5 quarts of oil? I'm surprised that's getting you to the full mark on the dipstick
Old 08-18-2020, 08:14 PM #25
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Yes sir believe I read it on here actually that it should be 5qts when I first bought the car. How come, what do you run/what's correct?
Old 08-18-2020, 08:36 PM #26
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
For the 5VZ-FE per the manual for an oil change with no filter replacement it is 5.2 quarts and for an oil change with a filter replacement it is 5.5 quarts. Obviously the more important thing is that you are in the correct range on the dipstick, but those are the numbers that Toyota says should put you in that correct range.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 08:53 PM #27
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Oh, I thought we were talking a whole couple quarts or something. It could've been a tad over, can't really recall right now but I am gonna be due in the next month or two so I'll double check then
Old 08-18-2020, 09:38 PM #28
2runnersnyynyg 2runnersnyynyg is offline
2runnersnyynyg is on a distinguished road
Are you getting codes? Check engine light?
I’ve seen failing injectors cause a stall once high idle goes down after start up. Would suck to have to do just after purchase but with nearly 200k can’t be ruled out.
2runnersnyynyg is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 10:55 PM #29
The oil low pressure light has gone out. No "check engine" light.
When I changed the oil, and filter, I needed 5 1/4 quarts.
At least temporarily the idle stalling problem has been cured. Had a semi-large hole on the underside of the flex air hose just prior to the throttle body.
I have no way to check for codes.
Last big problem is an engine noise which just started, AFTER I installed the new alternator. Will remove the belt and see if the noise stops.
Old 08-18-2020, 11:34 PM #30
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Any auto parts store will scan codes for free, but that being said I highly recommend picking up a $20-50 OBDII from Amazon or HF. An actual unit, not a little ELM transmitter that pairs with your phone. They pay for themselves within a few uses.
In regards to the noise, sounds like the belt isn't tensioned properly.
engine , flush , marvel , mystery , oil
Marvel Mystery Oil in Last 3 Oil Changes BamaDrewski 3rd gen T4Rs 35 03-29-2017 11:03 AM
BG Engine Flush / Transmission flush scrhew 3rd gen T4Rs 19 09-11-2013 05:44 PM
Marvel Mystery Oil TN_GIJOE Classic T4Rs 13 04-07-2012 07:54 AM
Marvel Mystery Oil & 5th gear whine lululalalu Classic T4Rs 3 05-05-2011 05:39 PM
Liquid Wrench vs Marvel Mystery Oil vs WD-40? 4RunnERD General Discussions 17 04-28-2011 05:22 PM
