Old 08-19-2020, 12:29 PM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by Devbot View Post
Oh, I thought we were talking a whole couple quarts or something. It could've been a tad over, can't really recall right now but I am gonna be due in the next month or two so I'll double check then
It usually takes me 5.7 to get to the full mark on the dipstick when I change the filter as well. 5.1-5.3 when I just change the oil. I get free oil at work so I change the oil every 3k miles and filter every other oil change.
Old 08-19-2020, 01:20 PM #32
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Been using the YZZD3 filter and 6 qts of oil, spot on the full line for 20 yrs.
Old 08-19-2020, 03:11 PM #33
Same here, though not for 20 years! (though 6 qts overfills mine by 0.1 to 0.2 quarts)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-19-2020, 04:43 PM #34
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
if I have understood correctly, Marvel Mystery Oil is mostly a detergent ???
Assuming I get all of the liquid oil out of the crankcase, and only the "baked on" black remains, how long is it safe to run MMO + 5W-30 ? Weeks? Months ?
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 08:36 PM #35
Look up the msds or mds for it. It will give you all the ingredients by percent.
Stoddard Solvents is mineral spirits.
Old 08-19-2020, 09:20 PM #36
Real Name: Mark
Real Name: Mark
Gotta be filter, you using YZZD1 "standard length" ? Both my Runners that way 6qt-Full line.
Been using Rotella T4 1 gal jugs, use 2qt measuring cup.
Old 08-19-2020, 09:56 PM #37
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
MMO is just mineral oil and white spirits, and in that order. I have yet to hear of any negatives coming out of running MMO long term besides pre-existing leaks getting worse, purely because it will thin out your oil and these people in question didn't compensate for it - Marvel even warns about this on the bottle, if I recall. Mind you, you should be addressing any significant oil leak already before you go adding snake oils to fix other problems. I can personally say I ran it constantly on my last truck and never had any bad come from it.
In regards to time it'll probably take a couple full oil change intervals before you notice any difference, but that's preferred - better to slowly dissolve it then go fast and hard, knock a chunk loose and get it stuck between a rocker and lifter.
You could also look into other additives like Seafoam or Gumout, that are advertised as being oil additives (on top of fuel additives) and contain things like naphtha or PEA, which works great against carbon and cooked oil. Or, as previously mentioned, BG EPR. Never tried it myself but people have praised it for decades.
Old 08-19-2020, 10:18 PM #38
TimGFL TimGFL is offline
TimGFL is on a distinguished road
I had to pull the intake manifold off my '96 today and, boy are the intake ports gummed up... at least an eighth of an inch thick. Would MMO engine flush help clean that out, or would it be better to use the regular MMO in the gas? Or both?
TimGFL is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 11:08 PM #39
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you're looking to clean the carbon off your valves and ports, look into RedLine SI-1. Stupid good stuff. I ran a few bottles through upon getting my 4runner, and by the time I went through my knock sensor fiasco and took off the manifold a couple months later my valves didn't have a single speck on or near them. Also a big fan of the new BG44K Platinum, though I just use the fuel additive, not the "whole service package" gimmick. Gumout used to make some great cleaners (One n Done, All in One 2x Concentrate) but they've been discontinued and you gotta try and snag them off eBay or the like. Marvel advertises adding MMO to fuel to help free up injectors, but not much more beyond that, iirc
Just my $0.02
Old 08-20-2020, 01:55 PM #40
It is the D3 filter, but I do use a Fumoto drain valve (skid plates!) and might be missing the last little bit in the pan during the drain process.
Old 08-20-2020, 09:10 PM #41
Real Name: Mark
Real Name: Mark
Ok, I take it Fumoto threaded nipple extends into Pan, good to know,
I'll know I need to cut some thread off.
engine , flush , marvel , mystery , oil
Marvel Mystery Oil in Last 3 Oil Changes BamaDrewski 3rd gen T4Rs 35 03-29-2017 11:03 AM
BG Engine Flush / Transmission flush scrhew 3rd gen T4Rs 19 09-11-2013 05:44 PM
Marvel Mystery Oil TN_GIJOE Classic T4Rs 13 04-07-2012 07:54 AM
Marvel Mystery Oil & 5th gear whine lululalalu Classic T4Rs 3 05-05-2011 05:39 PM
Liquid Wrench vs Marvel Mystery Oil vs WD-40? 4RunnERD General Discussions 17 04-28-2011 05:22 PM
