Old 08-16-2020, 01:21 PM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Marvel mystery oil engine flush
Has anyone used Marvel Mystery Oil engine flush ???
I have looked it up on youtube and Google. Opinions vary widely but most people claim it works very well to clean an engine when poured in the crankcase.
Considering using it in my 195K , 3rd gen V-6 engine.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 01:38 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I've never used it myself, but my feelings on any sort of engine flush/ seafoam etc. type thing is that unless you have a specific problem that there is reason to think doing it might fix, it's a pointless risk. Do you actually have a specific problem that you think a MMO engine flush will fix?
Skulking is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 02:14 PM #3
HiLife HiLife is offline
It depends. Have you looked into your cylinder head area? That cleaner may work well but, the cleaned material has to go somewhere if it's extra dirty. Maybe plugging some oil passage, oil pump screen or oil filter.
It's better and safer to do multiple short oil changes to clean out an engine if it's dirty on the inside.
Old 08-16-2020, 02:17 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I constantly run a quart of MMO at all times, put in about 4qt of Rotella T6 and 1qt of Marvel. According to Marvel themselves it should cut the 5w40 to roughly that of 5w30 in that amount (believe it also says so on the back of the bottle how to calculate it). My initial reason for doing so was to help clean out some cooked oil in my valvetrain and generally clean out the system, and it's worked pretty well for it but it did take a 1-2 full OCI's to see any change.
Some people also use Gumout Multi-System in the oil but I've yet to do so. I believe it's only something like 1oz per 1qt or something real minuscule so I haven't tried it in that sense, but it does make a great fuel cleaner so maybe worth a shot.
Old 08-16-2020, 02:33 PM #5
BG109 is a great engine flush. Pour it in, ten engine at 1200rpm for a few min and then drain oil and change filter.
Old 08-16-2020, 03:00 PM #6
I agree. BG is the bomb!
Would you follow that up with MOA and 44K?
Old 08-16-2020, 03:37 PM #7
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
I’ve had good success with sea foam and bg products but bg did work better faster but is more expensive then sea foam either works but my routine is 500 miles before oil change add the product into the crank case followed by bg44k into the fuel tank at about 100 miles till refill this goes quicker if you drive like Jason Bourne at the wheel of an Italian taxi then change out oil good for 10k
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 03:42 PM #8
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
^^^ this is what I use every 3rd OCI
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 03:46 PM #9
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
Any reputable “engine cleaner” which I think is what we are talking about here, will warn against using their product in a dirty engine. Anything from removed buildup clogging something down the line to causing leaks due to removing carbon buildup around seal areas.
The slower approach is safer... I prefer BG 109 (aka EPR “Engine Performance Restorer”) but I’d suggest you do a few shorter oil change intervals with a good synthetic to start the cleaning process before using a true “engine cleaner”
Old 08-16-2020, 03:53 PM #10
Yes, I changed the oil and filter just after I bought the truck 8 weeks ago, and after a week the oil was far too black to suit me. I looked in the oil filler cap and I saw a far amount of hard black substance. Truck has 195 K on it.
A Mexican friend of mine, who is professional small engine mechanic is encouraging me to drain the oil, install a new cheap filter, and fill the crankcase with 1 gallon of diesel fuel and 1 quart of oil. Then run the engine at 1,200 RPM for 5 minutes. Then immediately drain, put fresh 5W-30 and a OEM Toyota filter on. PS: I am getting the idiot light at idle RPM's BUT NOT AT 1,200 plus RPM's.
I know very little of what might be best. Diesel fuel flush Vs. Marvel Mystery Oil flush OR do the diesel fuel 1st followed by Marvel flush ???? Hoping that knowledgeable T4R posters can steer me in the right direction.
Old 08-16-2020, 04:11 PM #11
Hmm, I know diesel oil is oily buy, would 1 quart of oil and 4 quarts of diesel provide enough on an oil film safely in the main and rod bearings area? I wouldn't trust that theory.
If it works yay, it's a huge headache if it doesn't. Safer to do short oil changes still.
Old 08-16-2020, 05:51 PM #12
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Using diesel is a common way to clean out transmissions and oil sumps, though I've only heard of people letting it sit overnight or through the weekend, not letting it run. But I'm also talking about what I've read online, I don't personally know anybody to do this. Personally I'd just use something like MMO - if it royally screws your car you can raise hell with them. Not so much if you pour a bunch of diesel in there.
Gasoline and diesel are both excellent solvents, but so is MMO. All Marvel Mystery is, is a shitload of detergents suspended in an SAE 5 weight oil.
Old 08-16-2020, 06:58 PM #13
MMO is mineral spirits and a light aromatic oil.
I’ve used a qt of ATF in my Saturn on occasion.
I like the BG109 the best and have plenty and have the suppliers business card.
Old 08-16-2020, 07:19 PM #14
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Have you run that oil pressure test yet? I’d gladly buy the gauge to end the suspense.��
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 07:37 PM #15
No, not yet. I did buy a new oil pressure sensor sending unit and a large 24mm socket to remove the old one and install the new one. I'm on limited retirement money and I must buy things in stages.
Currently, I'm chasing a problem with the engine stalling at normal hot idle speed.
Looking for any possible vacuum leaks. Right this minute, the ****ing truck will NOT run if I take my foot off the gas pedal. Until I can fix that problem, everything else must wait.
Please, have patience with an old man who knows next to nothing about auto mechanics
engine , flush , marvel , mystery , oil
Marvel Mystery Oil in Last 3 Oil Changes BamaDrewski 3rd gen T4Rs 35 03-29-2017 11:03 AM
BG Engine Flush / Transmission flush scrhew 3rd gen T4Rs 19 09-11-2013 05:44 PM
Marvel Mystery Oil TN_GIJOE Classic T4Rs 13 04-07-2012 07:54 AM
Marvel Mystery Oil & 5th gear whine lululalalu Classic T4Rs 3 05-05-2011 05:39 PM
Liquid Wrench vs Marvel Mystery Oil vs WD-40? 4RunnERD General Discussions 17 04-28-2011 05:22 PM
