Old 08-20-2020, 12:54 AM #16
HiLife HiLife is offline
Did you go over your welds that you did on the front clip r&r?
Maybe the hit was so hard it broke some of the spot welds?
Could be that everything is tight when the truck is on a level with no body stress.
If you were to dip the front passenger side like you were going through a pot hole or dip, that would put that side under stress and maybe expose a broken weld?
Old 08-22-2020, 03:05 PM #17
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
I jumped on the bumper and it doesn't do it so can't tell. Disconnected the sway bar, it isn't that. Just replaced the lower ball joint and it is still doing it so it isn't that. Maybe the upper ball joint? I'd be surprised if it took the impact since the bump stops would absorb the force and transfer to the lower ball joint.
I got someone to drive backwards slowly in the parking lot and slam on the brakes beside me and it makes the noise. It sounds like it is coming from just above and behind the wheel. That could be an echo off the wheel well from somewhere else though. A significant hollow sounding suspension rattle, like if you were standing beside it on the street when I went over some bumps you'd definitely hear it and think there is something wrong.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 04:08 PM #18
Maybe something metallic dropped into one of those holes in the closed section part of the frame?
Old 08-22-2020, 04:24 PM #19
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
Upper control arm bushings shot maybe?
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 08:59 PM #20
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
I had to take my struts and sway bar off then lift it in the air and start prying with a giant bar to find it was a lower control arm bushing.
Make sure the dent in the trans pan doesn't block the trans from sucking up oil, I think it picks up off the bottom(??)
Wedgy is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 09:48 PM #21
Mark_BC's Avatar
Mark_BC's Avatar
Did it make metal on metal clanging? I do see that the bushing has a small tear in it, from what I can see of it, but I'd be surprised if it made that much noise.
Tomorrow I'll be removing the LBJ and strut again to swap the originals back in so the upper and lower arms should be free to pry on.
Old 08-23-2020, 02:23 PM #22
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Are you 100% sure it's coming from the front? Check your upper bushings on your rear shocks. If they rot out they make an awful metal on metal sound when going over bumps.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 08:32 PM #23
Mark_BC's Avatar
Mark_BC's Avatar
Yes for sure the front. I just pulled out the strut and LBJ again and the control arms were free. They seemed fine. Tie rod seems fine too. I think I can rule out the front suspension. Differential seems OK. Amazing how it can sound like the front end is going to fall off when you hit a bump then everything's tight when you go underneath.
Old 08-23-2020, 08:38 PM #24
Can you simulate a pot hole hit on the lca/uca with a rubber mallet/plastic face hammer? Still quiet?
Old 08-28-2020, 01:27 AM #25
Mark_BC's Avatar
Mark_BC's Avatar
I brought it into the shop and it took the guy 2 hours to find it. It was the body mount behind the front wheel. The bolt was loose. I guess the guy who straightened the frame loosened it and forgot to tighten afterwards. It wasn't rattling until this impact which I guess shifted things and made it start rattling.
Now it's nice and tight over the bumps, ready for my trip next week.
Old 08-28-2020, 01:30 AM #26
Mark_BC's Avatar
Mark_BC's Avatar
Originally Posted by sleepydad View Post
it's always something obvious once you find it but it has nothing to do with the suspension. it's because you have a preconceived notion that it's the suspension and your just overlooking what is really busted/crack?
You win the prize. I have a rusty old sway bar for you, should you accept. Shipping may be prohibitive.
Old 08-28-2020, 01:43 AM #27
That sounded like a doozy. Glad you got it figured out!
1997 Toyota 4Runner
big , bumper , hit , pothole , suspension
2015 TRD Pro - Broke front spring? (broke while parked in garage) rustbeltboss 5th gen T4Rs 20 02-24-2021 11:53 AM
Trying To Figure Out New Front End Noise MaddoxPics 5th gen T4Rs 7 08-29-2019 02:33 PM
4wd is broke and dealer can't figure it out. 24poepoe 5th gen T4Rs 37 05-25-2018 11:45 AM
too stupid to figure out suspension.. chewyspark47 4th Gen T4Rs 13 04-19-2018 02:06 AM
Suspension done, trying to figure out what size tire AZ4runner08 4th Gen T4Rs 24 02-01-2014 02:33 PM
