Old 08-19-2020, 09:12 PM #31
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Drcoffee View Post
During my research to fix my truck, I came across discussion where this could be a possible issue. If the retainer is not perfectly round, which you cant verify just by looking at it, Or a hair sized scratch occured during install or removal, yes oil can leak by it. These retainers are only $12. For me, after doing this 4 times, I wasnt thinkIng it was so much, I hope to do it again. So I sealed every possible spot it could leak from. Did it need it? I dont know. But I wanted to be sure.
Gotcha. Well, my buddy Wei is having a leak problem on his driver side. We did everything the same on the passenger side and no leaks.
Just when I thought I couldn't learn anymore about this job, problems like this arise that get the gears turning in my head again. I thought it was perfectly safe and smart to reuse the retainers and ABS tone rings to save money, but like i said, now I'm second guessing myself.
I just pulled the ABS sensors on my 98 and sure as shit my gear oil has gotten past on the driver side but my passenger side is bone dry. I did this job 2 1/2 years ago and put approximately 17,000 miles on it since then. On both sides, just like on my buddy Wei's rig, we reused the retainers. So, why is it leaking on the driver side but not the passenger side. If reusing the retainers was not a good choice, logic says both sides should be showing signs of leaking, not just the driver side.
Anyway, safe to say I'm bummed to learn this. I've given this money saving advice to lots of people and now I'm starting to think this might have been poor advice. I'm going to get Wei over my place and we're both going to install new inner retainers and go ahead and put a new seal in as well. If this doesn't stop the leak on both of our driver sides, we'll pull the axles again and try the FIPG on the outer circumference of the seal and see if that stops it.
I updated the pinned comment for the Rear Axle Seal/Bearing Replacement (ABS Rearend) and I'm now suggesting people to reuse the ABS tone rings and outer retainers but buy new inner retainers. Until I get this figured out, I don't want anyone else having issues reusing the retainers for the inner placement.
Old 08-19-2020, 10:21 PM #32
psea17 psea17 is offline
psea17 will become famous soon enough
naaaa! don't feel bad! we all know this generation of 4runners has problems with leaking seals. they didn't all follow one video. im INCREDIBLY APPRECIATIVE OF YOUR VIDEOS!
I'm going to do this in stages. first fipg on the inner seal where the seal meets the housing. I'll give it some time, recheck it and report back. my rear brakes/drums are just about toast. so it can't do much more harm. if that doesn't do it, I'll do the same on the seal side of the inner retainer ring.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 05:07 PM #33
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
@Drcoffee theory was right. I pulled my driver side axle today and removed the inner retainer and ABS tone ring. I did a careful examination of the inside diameter of the inner retainer and there is noticeable gouging to the surface. It's obvious the retainers, ABS tone rings and inner races for the bearings are made of a softer metal than the axle itself. Gear oil most likely got past the metal to metal connection of the inner retainer and axle via the grooves left in the retainer from the removal process. I did take measurements of the inner diameter of the old retainer and the new retainer and got the same measurement, 39.8mm. So, it's not that the old retainer has stretched out some. The problem is the grooves that are left in the inner surface of the retainer that allow a pathway of gear oil to get past and accumulate in the axle housing cavity that will ultimately contaminate the bearing washing out the grease and eventually make it into the brakes.
After 2.5 years and 17k miles, some gear oil made it's way through but not a ton. But, it was enough to contaminate the bearing and a little bit made it into the brake drum. It wasn't the usual huge mess of gear oil we see. There was just some sludge on the inner side of the drum from the gear oil mixing with the brake dust. Should I have replaced the brake shoes? Yeah, I should have but I sanded them down a bit and called it good. I did repack the bearing with some Redline CV-2 Synthetic grease. I pried off the bearing cover, cleaned up the residual mixture of grease and gear oil, and then cleaned it out further with brake cleaner. I worked the fresh grease in the bearing, spun the axle, and was able to work some more of the dirty grease out. I packed some more in and spun it repeating this process until the grease looked pretty clean. Like @Dr Coffee said, I think there's a chance you could overpack it so I would spin the axle, wipe off excessive grease and repeated that until the spinning wasn't causing a build-up of grease to work itself out.
OP, I think you should forego swapping out a seal and applying FIPG. I'm pretty certain the pathway for the grease to get past the seal was because of reusing a retainer at the inner position. When you pull your inner retainer off, you'll see and feel the slight gouging I'm talking about.
Spinning the passenger side axle and looking into the axle housing cavity via the ABS sensor port, I can see a very tiny amount of clean looking gear oil on the ABS tone ring. So, after 17k miles, it has leaked very little. But, I'm going to pull that axle soon too and put a new inner retainer on.
I did confirm that 4mm of polished axle showing is a good measurement to go by. The witness mark on my inner retainer was closer to the inside by a 1mm so 4mm would put the seal lip dead center on the polished shoulder of the retainer. At first I thought the polished shoulder was 10mm in length, but after closer inspection, it's only 9mm long. But, anyone doing this job should verify they have a good mating of the axle seal and inner retainer by performing the sharpie test.
OP, sorry for the bad advice. I truly thought I was giving good advice for reusing both retainers. The concern in the past was always a proper mating of the seal and retainer but I never even thought that the gear oil could sneak past the metal to metal connection of the inner retainer and axle shaft. Like I said, I thought I knew everything about this job, but I learned that my advice to save people money on the parts was a bit flawed. There's obviously no penalty to reusing the ABS tone rings and outer retainers but there's potential problems with reusing the inner retainers.
Old 08-23-2020, 12:30 PM #34
No apologies needed! Easy fix. Will buy new rings and just to be safe, new seals on the chance they formed to the old inner retainer rings.
got snow in my caming area yesterday! from strong thunder storms. pretty incredible weather for a drive along the Mogollon Rim (mo-ghee-on).
Hopeful we got this solved! Appreciate everyone's input!
Manual Transmission
Old 08-24-2020, 09:05 AM #35
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I used new inner retainers and still had a leak. I'm not saying that re-using old retainers is or isn't another path for fluid to leak through, but in my case it was an axle housing/axle seal mating/sealing issue.
If someone was going to reuse the retainers then using axle/gear oil FIPG on the mating surface of the retainer and axle would probably be a wise decision. Just my thoughts on the subject, and I appreciate you taking into consideration everything in this thread and changing your recommendations to reflect the issues that some people have been having. Love the videos and keep on keeping on bud
Old 08-24-2020, 10:13 AM #36
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'm not ruling out what your situation was might be mine as well but from what I saw with the retainer I reused, gear oil definitely could have gotten past the metal to metal connection with the axle shaft. Common sense would say I do what you did along with replacing the inner retainer to cover all my bases, but I really want to know for sure what the culprit was and I can only do that by changing one thing at a time. I do remember that my driver side did have a previous axle seal replacement but I can't remember if mine was one of the one's I've seen where a sloppy mechanic or DIYer gouged the axle housing with a hooked puller or other tool. If the retainer swap I did doesn't fix the issue for me, I'm going to replace the seal and use some red FIPG for some extra insurance. Thanks for contributing to this discussion.
I'm going to mention your situation with the seal and how you addressed it in pinned comments for all three videos we've shot for this repair.
Old 08-24-2020, 01:27 PM #37
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Revisiting this because I found out this weekend that the driver side rear axle seal on my friends 3rd gen was leaking. We changed both sides about 4 years ago.
Want to make sure I understand the this correctly:
1. For those that suggested using FIPG to seal the mating surfaces of the seal & axle housing (red arrow) and the inner diameter of the inboard retainer where it contacts the axle (green arrow), are the arrows pointing to the correct locations you were referring too?
2. Is the green arrow the inner retainer that was suggested to be replaced?
Rear Axle Seals & Bearings-rear-axle-2-jpg
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 01:49 PM #38
Real Name: Patrick
Real Name: Patrick
1) Arrows are in the correct place.
(For those that may not be able to see the diagram the location is the outer portion of the axle seal and the corresponding area of the axle tube where that seal would install. For the inner retainer, furthest from the hub and closest to the axle splines, I would apply the FIPG to the inside of the retainer as well as the polished portion if the axle shaft after installing the bearing, outer retainer, and ABS ring. After inner retainer installation and proper placement is verified I would also apply/smear a bead of FIPG where the retainer and axle shaft meet on the inboard side of it.)
2. Green arrow is pointing at the correct retainer. (For those that can not see the diagram it is the inboard retainer closest to the axle splines and furthest from the hub.)
Old 08-24-2020, 02:02 PM #39
fourfive's Avatar
fourfive's Avatar
Thanks! Will likely do all of the above.
Old 08-24-2020, 04:21 PM #40
fourfive's Avatar
fourfive's Avatar
Are the part numbers for the inner & outer retainers the same?
Old 08-24-2020, 05:55 PM #41
Real Name: Patrick
Real Name: Patrick
Same part number for inner and outer retainers
Old 09-02-2020, 02:22 PM #42
can someone point me to what type of sealant i should use to seal where the retainer ring meets the axle (and where the inner seal meets the axle housing)?
thanks!
Manual Transmission
Old 09-02-2020, 03:13 PM #43
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
thanks!
*Toyota FIPG 1281 - (For Transmissions, Transfer Cases and Differentials)
Amazon.com: Genuine Toyota Fluid 00295-01281 Formed-in-Place Transmission Gasket - 3.5 oz. Tube: Automotive
Old 09-02-2020, 11:50 PM #44
MagusWyatt's Avatar
MagusWyatt MagusWyatt is offline
MagusWyatt will become famous soon enough
MagusWyatt's Avatar
Yes, left and right, inner and outer are all the same part. 42423-20010
Edit: Sorry, missed the second page. Didn't think this got answered.
1998 SR5
MagusWyatt is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 09:48 AM #45
Real Name: Patrick
Real Name: Patrick
thanks!
Amazon.com: Permatex 81182 Gear Oil RTV Gasket Maker, 3 oz.: Automotive About $10 on amazon vs $23 for Toyota FIPG if you're okay with not using OEM.
axle , grease , oil , rings , seals
Anyone Need '00-02 Axle Seals/Bearings? Tyler James Inc 3rd gen T4Rs 1 09-06-2018 11:14 AM
Rear axle seals, bearings, and brakes NegroTundra 3rd gen T4Rs 50 06-30-2018 11:31 PM
Leaky rear axle bearings/seals? 2ndhandyotaman 4th Gen T4Rs 1 11-27-2017 01:57 PM
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
FS 3rdGen Rear axle bearings-Outer seals & brake hardware $60+S&H Turners Falls Ma. rodskwad For Sale: T4R Items 0 10-26-2013 06:47 PM
