Old 09-03-2020, 02:21 PM #46
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Was about to make a thread on this, but I figured I could ask here seeing as this is an active thread on the same general topic.
The rear seals, bearings and retainers were all replaced on mine 3 years ago. Flipped retainers and was grease tested. Grease test showed right in the middle. No leaks.
Now, in a month or so, I am getting ready to install a 4.10 locker with the accompanying locker housing. I have new axle seals and the axle o-rings ready to go on the new housing.
My question is, would I need to play with the retainers at all? I am merely just taking the axles from the old unit and transferring it onto the new housing, so I believe the retainers should still be in the correct position to make a seal on the new housing.
Regardless, I was still planning to perform a grease test to verify, but I just wanted some input before I begin. Thanks.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 09-03-2020, 03:09 PM #47
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
In theory it should be in the same spot, but grease or sharpie test to verify.
Old 05-04-2021, 11:59 AM #48
psea17 psea17 is offline
psea17 will become famous soon enough
Quick update. I redid both rear axles w/ new seals and a new inner retainer rings. I used the FIPG on the outside edge of the seals as well as the inner face of the inner retainer ring where it wraps around the axle. 3 weeks. no leaks. going to do some light wheeling tomorrow and see if there are any leaks. fingers crossed!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 03-17-2022, 01:49 PM #49
another update. no leaking seals since replacing the retainer ring and using the sealant. have towed 4k lb trailer overlanding too (repeatedly).
Manual Transmission
Old 03-17-2022, 10:17 PM #50
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Great to hear the fix has held up.
axle , grease , oil , rings , seals
Anyone Need '00-02 Axle Seals/Bearings? Tyler James Inc 3rd gen T4Rs 1 09-06-2018 11:14 AM
Rear axle seals, bearings, and brakes NegroTundra 3rd gen T4Rs 50 06-30-2018 11:31 PM
Leaky rear axle bearings/seals? 2ndhandyotaman 4th Gen T4Rs 1 11-27-2017 01:57 PM
Q: Replace axle bearings&seals or find assembled axle? Mutant 3rd gen T4Rs 12 09-14-2017 10:35 AM
FS 3rdGen Rear axle bearings-Outer seals & brake hardware $60+S&H Turners Falls Ma. rodskwad For Sale: T4R Items 0 10-26-2013 06:47 PM
