Old 08-22-2020, 01:39 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The cheapest thing you can do to improve body roll is to replace all four sets of sway bar end link bushings. I do recommend poly bushing here as you do want them stiff, these 4Runners have a lot of body roll once they age. I'll list some other low-cost things to improve on-road handling (I consider my 4Runner an on-road build):
Sway bar end link bushings - $30. Energy Suspension sells a good kit that works well.
Sway bar bushings front and rear - $30. Once again Energy Suspension has good kits.
Steering rack bushings - Stick with rubber. New bushings help with steering slop but poly bushings will transfer vibrations from the front wheels to your hands while driving. They are difficult to replace though.
Shocks - OEM Tokico blacks are the smoothest on-road shocks you can buy. Same goes with OEM springs like the 99 talls. Almost every other aftermarket shock and spring is made for offroading in mind, not on-road driving. Rear OEM Tokico's can be had for $42 each: Shock Absorber - Toyota (48531-80693) | Toyota Parts.
I would save the money and not buy the Addco sway bars. The bushings alone will make a huge difference.
326WHP 347TQ
Old 08-22-2020, 02:48 PM #17
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
So what about the UCA's? I am also curious if changing these out would improve ride quality. I replaced my LCA bushings (Whiteline) and ball joints (Toyota OEM). Wondering if doing the same to the uppers would help some also or if its more worth it to buy aftermarket UCA's. I heard replacing the ball joints on the uppers are a pain too. Got about a 2.5" coilover lift and 1" BL.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 10:57 PM #18
BigDummy BigDummy is offline
BigDummy is on a distinguished road
That's some great feedback, thank you.
I ended up getting Tokico Trekmasters on Shox.com. I halfway expect them to not be fulfilled, I just ordered them last night. I also bought the OEM 2001 springs front and back and new KYB tophats.
I installed the wheels / tires off the 2020 Tacoma Premium with wheel spacers and did 10 miles with 6 of those on freeway. I will take them off and re-torque the spacers before I drive it next. Way better ride with the tires alone. 265/60/18s still give enough sidewall to take bumps and the Michelin Defender is just such a superior tire to my old Toyos. Time remains to see if I regret going to spacers or not.
Imgur: The magic of the Internet
I've tried embedding pictures but it doesn't seem to let me with imgur.
BigDummy is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 10:42 PM #19
Shox.com just cancelled my order for the Trekmasters so I went with OEM from Camelback Toyota.
This makes me rethink getting the KYB tophats a little bit, as now I will have OEM shocks and springs but KYB tophats... Just seems like OEM tophats are way too much.
Speaking of which, I am trying to find the TRD Supercharger Throttle Body O-Gasket PTR26-35041. It looks like that part has gotten really expensive for what it is ($35+) but the URD version is $9. Anyone have luck with that?
I am also looking at doing the ISR mod and trying to decide if the deckplate mod actually does anything.
Old 08-27-2020, 01:08 PM #20
Modify your stock gasket or get the URD one, your choice.
Do the ISR and/or deckplate for engine sound and engine bay beauty, not power. You might get a couple of ponies along the way, but it isn't the point...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-27-2020, 01:15 PM #21
Real Name: Jerod
Real Name: Jerod
The ISR mod does next to nothing other than make more noise. The deckplate mod does made a large difference, about +10 HP and +17 TQ. This is Speedy's dyno run on an N/A 4Runner, the gains are even more if you are supercharged:
Project SportRunner
326WHP 347TQ
Old 08-27-2020, 08:26 PM #22
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Project SportRunner
Wow really?
Wait... Shouldn't the torque be at 220+?
Old 08-27-2020, 08:49 PM #23
Real Name: Jerod
Real Name: Jerod
Originally Posted by jross20 View Post
Wow really?
It would be if it was on an engine dyno, but that would require pulling the engine just to put it on there. This is measured at the rear wheels so it's after turning the transmission, driveshaft, differential, axles and wheels. It equates to around 15% driveline loss.
But yes, it really does add that much power. I've done it to my supercharged engine back before I did anything crazy to it and it really speeds up the 4Runner at WOT. At just partial or moderate throttle the gains are not as noticable since the stock airbox flows enough air for those scenarios.
Add in an oiled drop in filter and you can gain up to another +9HP/+9TQ, that's what the dyno showed the gains are over a paper Toyota filter on my supercharged engine.
326WHP 347TQ
bushings , front , rear , spring , work
Best Shocks for comfort on road? shadow247 3rd gen T4Rs 11 06-24-2020 01:49 PM
Wanting some feedback Itssslance 5th gen T4Rs 3 03-11-2018 04:19 PM
Best $400 to improve off-road capability? 4OYOTER 4th Gen T4Rs 28 11-12-2017 09:47 PM
Best shocks for on-road comfort? Ed_C 4th Gen T4Rs 8 06-01-2015 02:57 PM
Dynamatting the doors to improve door feel & road noise tx 4runner 5th gen T4Rs 28 03-27-2010 08:26 AM
