Old 08-18-2020, 01:04 AM #1
BigDummy BigDummy is offline
BigDummy is on a distinguished road
Wanting to improve on-road comfort, looking for feedback
Hi all, I have a 2001 SR5 4x4 that is on its stock suspension with 155k miles, I have owned it since 60k miles in 2006, and I plan on owning, or at least keeping it in the family, it for the next 15 years as well. Driving is 99% paved, 1% gravel roads sometimes in bad shape.
I want to reduce excess rebounding, body roll, generally improve composure, and reduce noise.
Shocks - Tokico Trekmasters front and back. It looks like they were discontinued but I found a few places that claim to still have them. If they aren't available, I was thinking OME. The OEM Tokico's are another consideration if the Trekmasters fall through. My current shocks are shot so anything will be a huge improvement.
How long do springs last and how do I know if mine are bad? Even if they "work" a 19 year old spring won't ride like a new one, right?
I like the idea of doing a 5th gen 4Runner rear spring (orange/pink) which would put me about a 1.5" over stock with a firmer spring. I would then want an inch up front so probably OME 880s or 99 talls? Seems like those are the only real options I can find, plus spacers if needed. Seems like everything else rides higher.
Any other options for springs I am not considering that are in the spirit of minimal lift improved ride? I would consider coil overs if they are worth the extra cash for on-road performance.
Bushings:
Many of my bushings are shot. All the aftermarket sets I am finding are polyurethane. Are there any parts that really benefit from being rubber? Seems like body mounting bushings in particular could benefit from being rubber. Steering rack I would liked tightened up so poly there makes sense. The others I am less sure on. The rear control arm bushings, for example, seem like a great place to isolate vibration, but also a way to keep everything firm to begin and provide better performance, overall I would lean rubber though. Sway bars though I think would benefit from poly for my purposes. Has anyone taken a hybrid approach on replacing their bushings?
Diff drop:
If I do a 1-2" lift or so, would I need to do a diff drop?
Front UCA:
Do uniball UCAs provide improved ride quality if I only lift 1-2"? At what point do they become recommended? I am thinking I can skip them, but maybe there is maintenance I should be doing while I am doing other things?
Sway bars:
I was going to do the suspension and bushings first and see if that got me where I want the rig to be. If it was still too loose, then add The Addco one's seem a good upgrade if I go this route.
Sound Deadening:
I have 100 pounds of the stuff ready to install as I take body panels off for stereo work and then eventually the rest of floor. I also need to replace the lock on my rear tailgate (was rear ended a year ago and just finally got a paint matched tailgate), so good time to access that!
Tires:
Going with Highway All-Seasons. Thinking something like Michelin Defenders. I see the 2020 Tacoma Premium 18" comes with them, but those wheels appear to be +35 offset. They are also 7.5" thick wheels (.5" thicker than mine), so another .25" (6.3MM) each side of center. So if I got a 1" (25.4MM) spacer that should get me within 1MM of original interior part of wheel, about 20MM past where the tire currently is. They are 265/60/18 so same height as my current 245/75/16. I found a local deal on a 2020 Tacoma Premium take off I want to grab if this would work. I currently have some unevenly worn, older Toyo All Terrains on it, so this should be a massive upgrade if they fit.
Seats:
I hate the seats in this thing. Still doing research. I think a replacement will go further than a re-foam and new leather. Seeing some BMWs, Audis, Lexuses (Lexi?) being swapped.
Any feedback on all of this would be appreciated.
BigDummy is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 09:03 AM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
If your goal is the best road manners possible I would stick with stock height or 99 tall springs at the most, replace control arm bushings with oem rubber and use poly bushings on the sway bars and steering rack. I like poly bushings and have everything poly on mine but it definitely makes the ride more harsh, so go with rubber there and on the body mounts as well.
The stock springs are likely pretty worn out so I would bet that just new springs and shocks would be a huge improvement, especially with the body roll. I would pick 99 talls with oem shocks, you wouldn’t need a diff drop with that setup
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 09:15 AM #3
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
So far I've been disappointed by every shock I've tried. I'm hoping to try out a progressive shock soon, perhaps the dobinson.
I will say that I absolutely do not recommend ome shocks, way too stiff. 5100s are too stiff as well, imho
Old 08-18-2020, 01:16 PM #4
So I like what I read about progressive valving but I am having a hard time figuring out who is progressive / linear.
King and Fox are progressive.
Bilstein and Icon are digressive.
Eibach I see a fair number of forums saying they are progressive, but I can't find anything on their website.
The Tokico Trekmasters I can't find anything.
OME I see a number of websites saying they are progressive but can't find anything in official material, same as Eibach.
Old 08-18-2020, 01:23 PM #5
If you want comfort, avoid any springs that are stiffer than stock. '99 talls are good. 5th gen rear springs will give you a lift, but are stiffer than stock (good if you are going to tow or carry weight, not the best for comfort if you are empty). Don't mess with any diff drop, extended swaybar links or anything like that. A 1" lift (say, '99 talls) is still a 'stock' height! That said, if you like the current ride height (if you are around 20" from center of hub to fender), you can keep your stock springs just fine. If your ride height is much below 20", you can start hitting bump stops during normal driving which is very uncomfortable...
Most comfortable shocks will be OEM Toyota. KYB is another good choice for comfortable stock replacement. I chose bilstein 4600's for a slightly stiffer and controlled ride many years ago and run 5100's now.
Keep all suspension bushings stock rubber for max comfort. Poly swaybar bushings will be fine.
Good quality street oriented tires at the right pressure will help too. (no load range E all terrains!) So you are on track there.
I have Addco bars on mine for street use (I disconnect the front offroad). Do just the rear first and see if you like the improvement. The front is much stiffer than stock which can be good or bad, depending on personal preference and driving conditions.
Seat comfort is very personal. I didn't like my old stock base (non-sport) seats, but the sport cloth seats fit me pretty well. You can swap seat foams left to right with some effort to gain some more 'mileage' from your current seats.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-18-2020, 07:35 PM #6
jross20's Avatar
jross20's Avatar
Also, based on what I can find and read, the diff drop isn't really a drop, but a "re-angle". Not worth it at all under 2-2.5 I think. To me, it's best to avoid it, honestly you don't want to lose down travel.
I have some charts I need to post, shows a lot of information about shocks that I've found.
Old 08-18-2020, 07:51 PM #7
spartacus's Avatar
spartacus's Avatar
Durobumps are great too for pot holes and such.
Old 08-19-2020, 11:46 AM #8
jross20's Avatar
jross20's Avatar
Actually, I have them in the rear and...I had to be that guy, but they are way too stiff. Really jarring. Maybe I'm expecting too much?
Old 08-19-2020, 09:15 PM #9
I'd be interested in seeing that.
Old 08-20-2020, 08:36 AM #10
jross20's Avatar
jross20's Avatar
Yeah I'm surprised no one has posted such. At least I can't find any threads with this information.
I'll try to remember to post it today.
Old 08-20-2020, 09:31 PM #11
tx_shooter's Avatar
tx_shooter tx_shooter is offline
tx_shooter will become famous soon enough
tx_shooter's Avatar
I went with Kings and the ToyTec Superlift springs in back a few months ago. The ride is much smoother and handles weight very well. My wife has even commented on how well the 4Runner rides now.
tx_shooter is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 10:17 PM #12
I think I got a good deal. $600 brand new pull offs of a 2020 Tacoma Premium. But spent $200 on 1" spacers (will be here next week, will post pictures once I can install them). So basically paid retail for the tires and got the wheels for free. Will be the first time I've ran spacers on anything, will be interested in seeing if they blow my wheel bearings.
Unusual Activity Detected - Free Shipping on Orders Over $99 at Summit Racing 2x of those.
Old 08-21-2020, 12:42 AM #13
pilotguy757 pilotguy757 is offline
Real Name: Jon
pilotguy757 is on a distinguished road
Real Name: Jon
I don't mean to knock your purchase of spacers, as those probably will work, but ideally you want something that has the lip that replicates the factory hub so the wheels have something to be centered on. Without the lip it can cause vibrations depending on the wheel.
I went with BORA. 4 Years strong at 2"
https://www.motorsport-tech.com/4DCGI/updateprice_truck
pilotguy757 is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 08:54 AM #14
jross20's Avatar
jross20's Avatar
Big moneyyy! Haha. How do the king's handle small bumps? Harsh or soft?
Old 08-21-2020, 07:09 PM #15
tx_shooter's Avatar
tx_shooter's Avatar
I spent the extra for custom valving from Filthy Motorsports with extra travel plus remote resis in back with adjustable dampeners. I caught myself running 40 mph down a dirt country road a few weeks ago without evening thinking twice about it. I started to back off at 60 mph mainly because the rig felt loose on the dirt; not because the ride was harsh.
My only regret is not doing this upgrade the day I bought my 4Runner.
bushings , front , rear , spring , work
Best Shocks for comfort on road? shadow247 3rd gen T4Rs 11 06-24-2020 01:49 PM
Wanting some feedback Itssslance 5th gen T4Rs 3 03-11-2018 04:19 PM
Best $400 to improve off-road capability? 4OYOTER 4th Gen T4Rs 28 11-12-2017 09:47 PM
Best shocks for on-road comfort? Ed_C 4th Gen T4Rs 8 06-01-2015 02:57 PM
Dynamatting the doors to improve door feel & road noise tx 4runner 5th gen T4Rs 28 03-27-2010 08:26 AM
